KrypteK PC Modz Posted January 13, 2016 Share Posted January 13, 2016 Hi modders! My name is DJ known as Kryptek PC Casemodding a modder from the Philippines. First, I built this rig for my client. Secondly, LUCIAN is the name of the rig from the champion/character of League of Legends (Project Lucian). And lastly, this build is a RGB Theme, what I mean is full of RGB lights. Specs: Processor: Intel i5 4690k Motherboard: MSI Z97 Gaming 5 Ram modules: 2x Avexir Raiden Series 2x4gb 2133mhz GPU: MSI GTX 960 Tiger Edition OC (this gpu is temporary) HDD: Seagate Barracuda 3TB SSD: Samsung 850 EVO 256GB PSU: Corsair RM850 Case: Coolermaster MasterCase PRO 5 CPU Block: Swiftech Apogee XL GPU Block: EK Thermosphere Fittings: 16x Acrylic Compression Fittings Silver 14mm OD Rotary angled fittings: 4x 45deg silver, 7x 90deg silver Tubes: 4x Acrylic Tube 14mm OD Reservoir: PRZ D65 x L220mm Fat Res Radiators: 2x Black Ice Nemesis 240L Pump: XSPC D5 pump with EK D5 x-Top Acetal Pump Top Fans: 3x Thermaltake TT Riing 14 RGB LED Lights: Deepcool RGB Extension Sleeves: PRZ Sleeving Custom PSU Shroud and GPU Backplate Link to comment Share on other sites More sharing options...
Sunday Morning Posted January 13, 2016 Share Posted January 13, 2016 Hi modders! My name is DJ known as Kryptek PC Casemodding a modder from the Philippines. First, I built this rig for my client. Secondly, LUCIAN is the name of the rig from the champion/character of League of Legends (Project Lucian). And lastly, this build is a RGB Theme, what I mean is full of RGB lights. Specs: Processor: Intel i5 4690k Motherboard: MSI Z97 Gaming 5 Ram modules: 2x Avexir Raiden Series 2x4gb 2133mhz GPU: MSI GTX 960 Tiger Edition OC (this gpu is temporary) HDD: Seagate Barracuda 3TB SSD: Samsung 850 EVO 256GB PSU: Corsair RM850 Case: Coolermaster MasterCase PRO 5 CPU Block: Swiftech Apogee XL GPU Block: EK Thermosphere Fittings: 16x Acrylic Compression Fittings Silver 14mm OD Rotary angled fittings: 4x 45deg silver, 7x 90deg silver Tubes: 4x Acrylic Tube 14mm OD Reservoir: PRZ D65 x L220mm Fat Res Radiators: 2x Black Ice Nemesis 240L Pump: XSPC D5 pump with EK D5 x-Top Acetal Pump Top Fans: 3x Thermaltake TT Riing 14 RGB LED Lights: Deepcool RGB Extension Sleeves: PRZ Sleeving Custom PSU Shroud and GPU Backplate Hi Tol ... wah maganda ... Cant Wait to see your project pare Link to comment Share on other sites More sharing options...
