ST.o.CH Posted March 12, 2016 Share Posted March 12, 2016 Looking good your build. Link to comment Share on other sites More sharing options...
Iraklis Posted March 28, 2016 Author Share Posted March 28, 2016 Today i got back the case from the plexi shop. They did a fantastic job and i am really happy with the result. Cheers Iraklis Link to comment Share on other sites More sharing options...
Warren_kwa Posted March 30, 2016 Share Posted March 30, 2016 Keep up the good work! Link to comment Share on other sites More sharing options...
Iraklis Posted April 2, 2016 Author Share Posted April 2, 2016 After many modifications i managed to mount the plexi on the case. There are some minor adjustments i need to do on the following days, but i think that the result came out pretty good. I managed to take some photos before i leave my work to show my progress. Cheers Iraklis Link to comment Share on other sites More sharing options...
Iraklis Posted April 13, 2016 Author Share Posted April 13, 2016 I drilled the hole for the power button on the front of the case. Now one strong candidate for the color is this one CheersIraklis Link to comment Share on other sites More sharing options...
Iraklis Posted April 15, 2016 Author Share Posted April 15, 2016 Hello everyone. Today i had some time to work with the power switch. As you can see below i have used a different kind of sleeve is this build. You can find it on gardening supplies stores. Its a gardening tube for watering the plants with drops. Its very cheap and durable and it also gives a very good result. Cheers Iraklis Link to comment Share on other sites More sharing options...
Amix Posted April 15, 2016 Share Posted April 15, 2016 Good work mate.Keep it up! Link to comment Share on other sites More sharing options...
E x e Posted April 16, 2016 Share Posted April 16, 2016 cool idea, nice metal sheet work there, good luck Iraklis Cheers Link to comment Share on other sites More sharing options...
Iraklis Posted April 18, 2016 Author Share Posted April 18, 2016 Good work mate.Keep it up! cool idea, nice metal sheet work there, good luck Iraklis Cheers Thank you. I went for some shopping today. I bough some adhesive skid protector so i can move the base easily and avoid scratches. I also looking for these switches (the ones that disengage the batter from the laptop). If anyone knows how they called id like to share that information. Cheers Iraklis Link to comment Share on other sites More sharing options...
Iraklis Posted April 22, 2016 Author Share Posted April 22, 2016 So... can anyone guess whats the part i am working on is going to be ? Link to comment Share on other sites More sharing options...
