Jump to content
Project Blue Snow
Gvox191
Project Blue Snow has been in my mind for about a year now. It got its name from the idea of having a HEAVILY modded Coolermaster case that is painted white with blue accents and lighting. My plan is to hardline water cool it with clear pipes and blue fluid. Pictures will be posted as the build evolves.
Link to comment
  • 2 weeks later...
There has been a slight change of plans. Instead of using clear Acrylic hardline tubing, I will be using clear Primochill flexible tubing. This is mainly because of the tight bends that would more than likely kink the acrylic tubing. As of right now no other plans are changing the build log will start soon at the moment I am still gathering components.
Link to comment
  • Create New...
Important Information
