Chris Howell Posted May 19, 2016 Author Share Posted May 19, 2016 Finishing the Brass Panels After waiting for a little while to get access to a milling machine, I decided to grab some engraving bits for the Dremel and do it myself. I already had my font and the antiquing fluid to finish the panels. So here goes... I used a paper template to guide my engravingThe engraving bit set that I had ordered. Worth noting that this is a first time for meMid-progressAnd when result when I was done. Fairly happy with my frst attempt. I'ts reasonably neat!I quite like the contrast of the polished panel against the rough textWhen I was done, I moved onto antiquing the panels with this stuffI filled a baking dish with a 1/10 solution of fluid and water.this shows the panels just as I added them inThe panels after 2 minutesThe panels after 5 minutes! They went dark super quicklyThis is what they looked like straight out of the solution. And actually the colour is totally awesome. This would be perfect for some kind of destroyed/apocalyptic style buildI returned the next day and found a lot of the cool colour had flaked off, leavng a black and copper style colourFINALLY - I used steel wool to rub away sections of the surface to reveal the shiny brass underneathThe colours are washed out in this photo, but here are the side panels. I can't decide if I prefer the weathered panels or the completely polished ones.I gave the brass bolts the same treatment. 2 black (left) and 2 after the steel wool (Right)Next Up - I glued the threaded spacers onto back of the brass panels and left them overnightA Close Up Link to comment Share on other sites More sharing options...
Chris Howell Posted May 19, 2016 Author Share Posted May 19, 2016 Assembling the case With the panels finally ready, I was able to build the case and get it ready to receive components! Very exciting times Let's took a look at the thing assembled for the first time. The Front viewLeft sideRight SideBackTopI'm really happy with the crisp edges and how well the panels lined up with the lid and baseThe slots at the back are begining to call out for components for sure So! - I'm nearly there. I'll be ordering my components very soon. Over all I'm really pleased with how it's looking. The lack of visible screws and simplicity of the panels makes it look like a real console - rather than a PC case conversion. There is also a certain charm that the real brass and real wood have that I can't capture on the camera. The pine still smells great and the thick brass panels are cold to the touch and give the case a really solid feel.I'm really looking forward to getting some components in there and will update back here soon!. Link to comment Share on other sites More sharing options...
