MonsterMawd Posted March 19, 2016 Author Share Posted March 19, 2016 Thank you for watching and commenting St.o.CH I debated about which color to paint the Scythe GTs for EK's 360 XTX Radiator. Decided to leave the fan blade hubs their factory grey and paint the frames GULF Blue, which works together and helps break up all of the orange. Clear coat applied Link to comment Share on other sites More sharing options...
DarthBeavis1 Posted March 20, 2016 Share Posted March 20, 2016 I love the color choice and top-notch painting! Also, nice detail in the work-log including how-to such as removing and retaining the C clip on the fan. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 21, 2016 Author Share Posted March 21, 2016 Thanks DB! Re-assembled the GTs yesterday with these replacement C-clip Retainer Rings that fit Gentle Typhoon fan axels, http://mnpctech.com/case-mods-gaming-pc-liquid-modding-custom-computer-mnpctech-overclock-cooling-fan-grills/ball-bearing-pc-cooling-fan-external-retaining-ring-or-c-clip-pliers-clone.html I use two micro flat head screw drivers to snap the c-clip over the fan motor axle / shaft Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 22, 2016 Author Share Posted March 22, 2016 EK's 360mm XTX radiator has convenient port on bottom for draining your loop. I'm using a Koolance Drain Valve with two of their swiveling 90 degree "snake" extensions.(Bitspower also makes a nice drain valve) Koolance Drain valve (4 way Splitter won't be used in this build) I'm using two of these Koolance swiveling 90 degree "snake" extensions. The others were used in Origin PC build, http://mnpctech.com/genesis-the-evolution-of-the-mod-munky-staff-project-with-origin-pc-genesis-full-tower.html Link to comment Share on other sites More sharing options...
Allyson | PaO_ Posted March 23, 2016 Share Posted March 23, 2016 Awesome job! Congrats Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 27, 2016 Author Share Posted March 27, 2016 I really like your build, and thank you Only had few minutes yesterday to work on my build. Decided on Black wire fan grills for the GTs. I like the look. I guess some would call them "old school" when compared to vast array of fan grills available today, btw All of the machined aluminum parts for Deep Silver's Homefront: Revolution Gaming PC are getting finished, so I'm dividing workshop time between both builds. What a contrast lol, from "don't scratch the paint!" on "what is the best grit to score this finish"on Homefront. I also swapped out the Black factory thumbscrews for Mastercase SSD trays to machined knurled silver aluminum. Link to comment Share on other sites More sharing options...
Warren_kwa Posted March 30, 2016 Share Posted March 30, 2016 That gauge and toggle switch! Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 4, 2016 Author Share Posted April 4, 2016 Thank you Warren! I had to take break from my own project to finish another commitment here, but I find my cpu and waterblock for this build Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 14, 2016 Author Share Posted April 14, 2016 My apologies for lack of updates! I had to take break from my personal build to finish this build for Corsair's booth at PAX East next weekend, http://mnpctech.com/corsair-380t-homefront-the-revolution-gaming-pc-case-mod-by-mnpctech.html Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 20, 2016 Author Share Posted April 20, 2016 Having your own small business makes it difficult to ever go anywhere and have FUN....lol... I'm now juggling my time between my build and this one for Computex, http://mnpctech.com/deepcool-genome-gamerstorm-mid-tower-atx-gaming-case-review.html Link to comment Share on other sites More sharing options...
