Jump to content
  • 3 weeks later...
  • Replies 45
  • Created
  • Last Reply
I am alive. Thank you for being patient. I had to halt progress on my build to fulfill commitments for Computex. Over the past 3 weeks I bought on 4790K for $225 shipped and $300 for reference GTX 980 on Ebay auctions. Fyi: Prices on used 980s are falling on Ebay as people upgrade to 1080s. I have one more build to finish, and I'll back on the track with this one!
Here is the PC I created for Deepcool's booth at Computex, http://mnpctech.com/deepcool-genome-gamerstorm-mid-tower-atx-gaming-case-review.html
deepcool_gamerstorm_mnpc1_case_genome_mn
  • 4 weeks later...
I realized I missed the deadline, but I will keep updating this project log
The extended holiday has bought me some time to work on my build. I recently scored EK water block for the Gigabyte OC force motherboard. It directly cools Intel Z87 southbridge (PCH), PLX PEX 8474 PCIe lane splitter as well as power regulation (VRM / MOSFETs) module. This will also compliment the stainless steel liquid lines nicely.
Gigabyte_oc_force_GA_Z87X_OC_force_coole
  • 2 weeks later...
Thank you!
it hurt to make the 3/4" hole into the paint to route the 316 stainless steel pc liquid cooling tube from the front radiator, but it just makes sense this way. I need to pick-up a bottle of the GULF Blue paint, so I can touch up the exposed steel in the hole. I modified one of the INLET/OUTLET black rubber grommets from NZXT Phantom to finish the mid section hole. Last night I bent the first SS tube of the loop. The stainless steel compression fittings are my own design. I wanted fitting that discreet in size and matched the tubing.
buy_stainless_steel_tube_pc_liquid_water
Mnpctech Stainless Steel 1/2" OD Compression Hardline Fitting
overkill_mnpctech_stainless_watercool_ha
  • 5 weeks later...
Dressing up the 120mm Typhoon GT fan with machined overkill grill with Blue anodized washers for M3 screws, http://mnpctech.com/screws-anodized-m3-m4-30mm-35mm-40mm-red-blue-green-gold-ek-alphacool-hardwarelabs-corsair-xspc/
anodized-blue-screws-pc-alphacool-ek-rad
120mm machined aluminum Overkill Ring fan grill, http://mnpctech.com/pc-computer-cooling-fans-grills-custom/
coolermaster-corsair-pc-cooling-custom-f
  • 3 weeks later...
  • 2 weeks later...
Cool, Please post photo after they're installed!
Finished painting the video card waterblocks, bridges, and backplates with Porsche 917 GULF Racing Factory Blue Paint.
Dismantled GTX 980 Koolance Waterblocks
koolance-video-card-waterblock-GTX-980-1
Basecoat Primer on Koolance GTX 980 waterblock
Basecoat Primer on Koolance GTX 980 waterblock Bridge
Koolance GTX 980 waterblocks with Porsche 917 GULF Racing Factory Blue Paint
  • Create New...
Important Information
