MonsterMawd Posted September 26, 2016 Author Share Posted September 26, 2016 On Saturday I received my DDR sticks, 32GB of Corsair Vengeance. The sticks were Black, so I hit local home improvement store and found a great aerosol substitute paint for the Porsche Gulf Racing Blue, it's Harbor Blue enamel paint by Rustoleum. I'm using these to create a DIY video guide to painting DDR heat spreaders, too! Link to comment Share on other sites More sharing options...
MonsterMawd Posted October 1, 2016 Author Share Posted October 1, 2016 DDR heat spreaders are finished, Video Guide Link for Taking Apart & Painting DDR Link to comment Share on other sites More sharing options...
MonsterMawd Posted November 1, 2016 Author Share Posted November 1, 2016 Have you guys heard of Ensourced? Somebody refered me to this guy for custom cable sleeve ordered and extension cables with paracord. Really Nice Quality & GREAT PRICES. I initially thought Burnt Orange would work with my color theme, but didn't look right, so thinking of matching the Stainless Tubing instead, so I bought these three variations of Grey.... Hmmm 8 pin GPU Paracord individually sleeved cable in "Smoked Grey" "Charcoal Grey" paracord "Graphite Grey" paracord Link to comment Share on other sites More sharing options...
Ryan Pace Posted November 10, 2016 Share Posted November 10, 2016 I like the "Smoked Grey" the best for a color match. This is one awesome looking build. Link to comment Share on other sites More sharing options...
MonsterMawd Posted January 6, 2017 Author Share Posted January 6, 2017 Thank you! Back at the workbench today, I created a PSU shroud for my Cooler Master Mastercase 5 build. It's made from 1/8" thick cast acrylic with embedded magnets I found on ebay, I drilled holes and glued on two legs with weld-on acrylic cement for easy on/off installation. Next step is painting the shroud gulf racing blue and draping over the orange stripe onto the shroud. Link to comment Share on other sites More sharing options...
Ivan Milan Posted January 8, 2017 Share Posted January 8, 2017 Can't wait to see the finished product! Link to comment Share on other sites More sharing options...
MonsterMawd Posted January 21, 2017 Author Share Posted January 21, 2017 Thank you for being patient with this build, I'm trying to find time between my other PC build commitments, this Thursday I did get the Mastercase PSU shroud painted to match the chassis. Here is the plate with and without the gulk racing stripe and just after applying the gloss clear coat Link to comment Share on other sites More sharing options...
MonsterMawd Posted January 23, 2017 Author Share Posted January 23, 2017 I'm watching Ebay for a vintage GULF pin to mount over the LED, so it's illuminated from behind. Here is some of the progress photos of SLI bridge mod over the weekend. Replace green nvidia logo with transparent orange acrylic window, Link to comment Share on other sites More sharing options...
MonsterMawd Posted January 24, 2017 Author Share Posted January 24, 2017 a video update today! Link to comment Share on other sites More sharing options...
xtian1 Posted January 26, 2017 Share Posted January 26, 2017 Awesome work on the entire case mod and on the SLI Bridge! Link to comment Share on other sites More sharing options...
