unequalteck Posted March 9, 2016 Share Posted March 9, 2016 2016 Project Unequal! New casing, new WC parts Old hardwares. SPECS CPU : Intel Core i7-4770k Mobo : ASUS Maximus VI Extreme LGA1150 RAM : Corsair Dominator Platinum 8GB DDR3 1866Mhz x2 SSD : Samsung Evo 840 250GB / Mushkin Chrono 256GB HDD : WD Scorpio 1TB GPU : Palit GTX980Ti Reference 6GB GDDR5 PSU : Corsair AX760 80+ Platinum Chassis : Cooler Master Mastercase 5 Previous casing Corsair Obsidian 450D got a big scratch on side window Special thanks to Cooler Master Malaysia for getting me this chassis Classic front panel Accessories box by CM WC parts. Mostly using Barrow, a very good quality China manufacturer (suspect is OEM of bitspower) Motherboard taken out from old rig Dusty PSU My beloved gtx980ti Cleaning rads and fans Plasticizer inside waterblock Planning loop Bending PETG tubing using heatgun Finally got a good bend after a few tries Have to evenly distribute the heat throughout the bend area From GPU to CPU This bend is taking my life Pump going to put under the midplate. Broken valve, going to change a new valve. Link to comment Share on other sites More sharing options...
unequalteck Posted March 26, 2016 Author Share Posted March 26, 2016 2 holes to connecting the pump Only managed to find 10mm drill bit at nearby hardware shop And the hole diameter is about 21-22mm Have to use file to file until the diameter which can fit in the fillport, when filing it looks like i'm masxxrbatxxg and the process took about 90mins Initial planned loop Pending front panel and PSU cover design. Need some input! some small updates while waiting for parts. good thing about PETG tubes. u can use this cutter to cut, finishes much more better than using jigsaw rough measurement from fill port to pump. Blue screws to replace the original screws new arrival for some fittings thermaltake riing RGB for 360mm radiator bought all these to do full modular sleeved cable gonna be a long progress Cooler Master top kit and window side panel finally can install top kit and complete the remaining tubing. but still.....problematic position just nice but unable to fill in coolant. position of reservoir have to shift downward and redo the bottom connection connected both fillport to pump top Link to comment Share on other sites More sharing options...
unequalteck Posted April 4, 2016 Author Share Posted April 4, 2016 heatshrinkless sleeving method EPS 8pin completed the remaining tubing close up shot bleeding process reservoir with UV light on bubbles gone! front panel done cutting sprayed matte black to match the frame acrylic block to hold the aluminum front panel black transparent acrylic and vandal switch TT riing underneath. will install on 360mm radiator 24pin sleeving done connected to mobo Done wiring for vandal switch. Have to use 24awg wires as the housing is too small for 18awg wire. Tested and confirm it's working! Fixed the aluminum on front panel Test run system Front panel T-virus alike reservoir <3 Link to comment Share on other sites More sharing options...
Nick Farquharson Posted April 9, 2016 Share Posted April 9, 2016 Sleeving on your cables looks fantastic!!! Link to comment Share on other sites More sharing options...
unequalteck Posted April 22, 2016 Author Share Posted April 22, 2016 The most headache part. Cable management. Completed! Link to comment Share on other sites More sharing options...
