Jump to content
StarKiller Base
Anthony B
  • 3 weeks later...
So a quick update last night the ball feel off the little stand and had a weak spot on it so is fell in on its self in some spots in going to try to blow the ball up inside it and try to slowly open it back up and finish adding the first layer in the weak spots then all I have to do is wait for it to dry then keep adding layer I think 4 or 5 layers will work. I bought 4 tubs of plaster and some thinker paper wish me luck  :thumbup:
Link to comment
  • Create New...
Important Information
