PindaPower Posted April 10, 2016 Share Posted April 10, 2016 Hello everyone,I'm new to the forum but have really enjoyed all the other people and amazing build.I own my PPG (PindaPowerGamin) Corner Desk mod and I like to share it with you.It begin with all the (extra) stuff form all the hobby projects. The desk was to small and room expansion is not that easy . So when it begin to be a but pain problem, I decide to make my first modding build. After looking at other mods, I found that the "desk mod" are the most beautiful and practical. So it became my goal to build a desk that fit in my room. With some online idea's, is came-up and designed a desk that would be housing two computer in somewhat limited place. With the move of the computers, I would create more working space and many future projects. No time for waiting, let's check out the progress. ------------------------------------------------------------------------------------------------------------------------Old desk ------------------------------------------------------------------------------------------------------------------------The Design------------------------------------------------------------------------------------------------------------------------Sneak-peak result Link to comment Share on other sites More sharing options...
PindaPower Posted April 10, 2016 Author Share Posted April 10, 2016 Hardware1. ‘Main-PC’ (left-side)Intel I7-4770KAsus Z87-DeluxeATI R9 290X2 x Kingston Fury Black 8GBM4-CT128M4 SSD 128GBWestern Digital WD10EADS HDD 1TB2 x Liyama LXB2483HSU-B1Cooler Master V series 850 ATX23 (Full-modulair)2. ‘Server-PC’ (right-side)AMD Athlon II X4 640Asus M4A78LT-MSamsung Spinpoint M8 500GBKingston KVR13N9S8H/4Cooler Master Silent Pro M2 850W/1000W3. AccessoryLogitech G400SCooler Master Speed-RX LargeRazer Kraken 7.14. Water cooling stuffEK-FC R9 290X – NickelKoolance Drain Valve 10mm (1/2 OD)2 x Akasa 5-poorts ventilator cable6 x Bitfenix Spectre 120mm rood led10 x 10mm 1/2OD - G1/4Alphacool VPP655Bitspower Water Tanks Z-Multi 150DangerDen DD-M6 Brass CPU BlockEK-Coolstream PE 360 RadiatorFeser Tube UV2 x Lian Li PW-IS40AV85AIO I/O-panelMesh panelFirst Day I now that I here not stuff to make most off the parts. So with some consultations off friends, I found a company that could make all the aluminum parts. The down side was that there machines can't make the part in my dimensions. So they helped my to change the plans a little bit. One off the changes was that the separate parts that are 'glued' at the bottom. The rest will stand in right position by small block on the upper-plate. Link to comment Share on other sites More sharing options...
PindaPower Posted April 20, 2016 Author Share Posted April 20, 2016 The components are in, YES. Now everything is in, I'm going to make holes. So I can test if everything fits, to be anodized and put together. The stuff are in: Let’s put the part together With some extra holes for the I/O panel With some extra stuff Now the for this result, part by part The CD-ROM is this temporary Link to comment Share on other sites More sharing options...
PindaPower Posted April 21, 2016 Author Share Posted April 21, 2016 I received all the part back in one nice black color. It’s looking beautiful. As you can see in the photos, I didn’t make my own desk-legs. For the chassis I wanted to use my old office, but I didn’t know what I would find beautiful. Beside the legs, they’re going to be a glass plate. The choice was to place it on or under the desk. These picture are to show my testing method :happy3: The choice has been made to get a big glass plate on top of the desk, rather than under the desk. So I'm going to arrange/buy the glass plate and continue the assembly to complete the desk. Link to comment Share on other sites More sharing options...
PindaPower Posted April 23, 2016 Author Share Posted April 23, 2016 It is now visible how the project is getting its final shapes. Meanwhile I made same holes in the bottom plate for the desk, to attachment the legs. The legs have been shortened, sanded and painted black. Its looking a lot better. Now getting the hardware to fit in, cutting the tubes and getting to continue on the other side. After that is the leak test. After some time I decided that I didn’t like the screws/bolts, so I colored it black. IT’S LOOKING SO NICE. See if you can find the screws/bolts Link to comment Share on other sites More sharing options...
PindaPower Posted April 23, 2016 Author Share Posted April 23, 2016 Continue the work on the second pc (server pc). The light strip has arrived and I had to painted it black. Time to finish up the project Next post is last post before show-time Link to comment Share on other sites More sharing options...
PindaPower Posted April 23, 2016 Author Share Posted April 23, 2016 Yes, time to finish up the project and enjoy the result ------------------------------------- ------------------------------------- Link to comment Share on other sites More sharing options...
PindaPower Posted June 24, 2016 Author Share Posted June 24, 2016 The end of my buildlog More pictures (flickr) More video (youtube) website Link to comment Share on other sites More sharing options...
