Jump to content
Arcis Modz
Hey Guys, ARCIS MODZ here, this is my 2nd year in the cooler master case mod contest.
This casemod is inspired by the Fallout 4 Game. I'm going to use a custom liquid cooling system in this build. I will also be doing some light modification on the Motherboard. So please stay tuned and hope you guys enjoy the project.
Hardware List:
Below is the list of parts/hardwares to be used in this build.
Specs:
CPU: I7 6700K - ✓
MoBo: Asus ROG Impact VIII - ✓
RAM: -
GPU: Asus Strix GTX 980ti  - ✓
SSD:
PSU:
CASE: HAF Stacker 915F
Water Cooling:
CPU Block: EK Supremacy CPU Block Nickel Plexy -  âœ“
GPU Block: EK-FC980 GTX Ti Strix - Nickel -  âœ“
Rad: EK-CoolStream SE 240 (Slim Dual) -  âœ“
Pump/Res Combo: EK-XRES 140 DDC 3.2 PWM Elite (incl. pump) -  âœ“
Fittings: EK-HDC Fitting 12mm G1/4 - Black -  âœ“
Fittings: EK-AF Pass-Through G1/4 - Black -  âœ“
Hard Tube: EK-HD PETG Tube 10/12mm 500mm  -  âœ“
Coolant: EK-Ekoolant Pastel YELLOW  -  âœ“
MODS and Misc:
Fans:
Led Lights: White LEDS -  âœ“
Sleeves: ARCIS MODZ cable sleeves -  âœ“
Hardware Shots:
13010760_10208080443581483_8446169029360
13001057_10208081099317876_1079717302975
13010808_10208081099477880_4571982501498
12990913_10208081099757887_4744817130796
13015110_10208081100157897_7784128232461
13055508_10208101412425691_4310390716314
13062492_10208101412585695_5523327480852
Link to comment
  • Create New...
Important Information
