Marinus Posted June 3, 2016 Author Posted June 3, 2016 Cutting plexiglass for doorsTip: For a clean cut I use masking tape.Ready for paintFirst results After gray color I was paint with top layer of sky blue. Stay tuned ^^
Marinus Posted June 7, 2016 Author Posted June 7, 2016 Finished control board Next step: Make a door for "chamber" After that I have to make mold for screws. I don't have a rubber for a mold but I can do this with clay. Polyester resin. Cheking if everything is ok
Marinus Posted June 8, 2016 Author Posted June 8, 2016 Next step was fine painting. The most improtant thing is to prepare perfectly surface for painting.First step is to fill surface with body fill and after that fine grind with sand paper and water. Repat with body fill and fainest sand paper. End phase is to paint surface with air brush gun. Results with led lighting effect
Marinus Posted June 8, 2016 Author Posted June 8, 2016 PC components ^^Mother Board : Gigabyte Z97X Gaming3 s1CPU : Intel Core i5-4690KCPU Cooler : CoolerMaster Hyper 212 EVORAM : 2 x Kingston ValueRAM 8GB 1600MhZ Graphic Card : Gigabyte GTX 960 GDDR5 4GBSSD : SanDisk X400 256GBHDD : 3 x 250 GB (FOR NOW)Power Suply : Seasonic SS-620GM2 EVOFan coolers : 3 X CoolerMaster Sickle Flow 120 mm 2000 RPM (2 Red, 1 Blue)Fan Controler : Aerocool F4XT 4x 5,25Ë LED_____________________________________Monitors : 1 x Dell Professionl P2314H 23Ë 2 x Samsung 2032 BW 20ËMouse : Speed Link GAMING PrimeKeyboard : Speedlink Bedrock
Marinus Posted June 10, 2016 Author Posted June 10, 2016 Now time is for wall decoration, sculpting foam and make stone textures. Working atmosphere at 1 AM
Marinus Posted June 11, 2016 Author Posted June 11, 2016 Sculpting more details on the wall After sculpting wall nex step is to "coat" styrofoam with tile adhesive. Now, time is for ading some paint on wall ^^ First is paint all deep hols with black color.Adding colorsThe colors what I'm using for paint, and for finish adding a green colors fore nice look I had a wisitor
Marinus Posted June 13, 2016 Author Posted June 13, 2016 Guys I will write description after sleeping, becaouse I'm wake 20 hours.Good night! My project is done! Geting a messures for a power supply caseI use a plywood board 4mmDoing holls for componentsHere I'm adding a rust testure effect with polyester Drilling a hole for HDDPS Case after paint job. Base color and red is top colorChamber is ready for components Last details on power control boardPait to black colors for a base color Head of screws ready for a painting Testing a red color pipe for a overlook. Adding rust effect with orange, brown and black colors
Marinus Posted June 13, 2016 Author Posted June 13, 2016 Addin whit glue to fix on the walljust for testing
Marinus Posted June 13, 2016 Author Posted June 13, 2016 Time is for paint a top of chamber, First is to pain all top with black color for base.Adding metallic look with three metallic colorslitlle scretches just for weahtering effects on the acrylic glass.paint brush on the borders of top for old lookAnd final look in my garage.
