KrypteK PC Modz Posted May 10, 2016 Share Posted May 10, 2016 Hey guys! I'm DJ Madrid known as KryptekModz a local case modder from the Philippines, it is my first time to join this kind of international event. My build is a little inspired with gundam toys. Astray, I caught that name on a gundam toy. And I know that I got only a few weeks to finish this build, I hope that I can make it to the finals. Here are the specs. Processor: Intel i5 6600k Motherboard: Asus Maximus VIII Ranger Z170 Memory modules: Avexir Red Tesla 4x4GB 2666mhz GPU: Asus GTX 970 Strix DCUII Case: Cooler Master MasterCase 5 Pro PSU: Thermaltake DPS G Platinum 1200watts SSD: OCZ Trion 150 240gb Custom Water Cooling: Radiator: Bitspower Leviathan Xtreme 360 Pump: Bitspower D5 MOD Package (Black POM TOP S + MOD Kit V2 Matt Black) Tubes: Bitspower None Chamfer Brass Link Tubing OD12MM Shining Silver CPU Block: Bitspower CPU Block Summit EF ICE Black (Intel, Acrylic) GPU Block: Bitspower VG-NGTX970ADIIS Acrylic Top With Stainless Panel (Clear) Reservoir: Bitspower Water Tank Z-Multi 200 V2 (Clear Body & POM Version) Fittings: Bitspower G1/4" Matt Black Enhance Multi-Link For OD 12MM Thank you very much to my sponsors: - ASUS PH - Avexir - OCZ - Cooler Master PH - Thermaltake - Bitspower International Co. - PinoyRigz - Baguio Modders Inc. So before we proceed to modding, let me take a quick post of the chassis. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 10, 2016 Author Share Posted May 10, 2016 Cont.. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 12, 2016 Author Share Posted May 12, 2016 So this is my initial sketch for the build, I'll add more details once it almost done. Added the wing panel Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 12, 2016 Author Share Posted May 12, 2016 Update.. Disassembling the chassis to make a inverted motherboard position. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 12, 2016 Author Share Posted May 12, 2016 Little update, Im showing you the motherboard ang gpu that I will be using to the build. That's all for now, just wait for my update of the chassis. Have a great day! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 12, 2016 Author Share Posted May 12, 2016 Ok, I just finished the motherboard bracket. Next, I will cut the back panel tomorrow. Stay tuned! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 13, 2016 Author Share Posted May 13, 2016 Cutting time... I know I have to do more and I got a few weeks to go! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 13, 2016 Author Share Posted May 13, 2016 alright! before I take my lunch, I just live a little update for the back panel. Good afternoon! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 13, 2016 Author Share Posted May 13, 2016 Last post for today. Cutting the back panel cover... I used 4.5mm acrylic sheet. Alright! Have a great weekend! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 14, 2016 Author Share Posted May 14, 2016 Back panel update.... Link to comment Share on other sites More sharing options...
