Mr. Miyagi Posted April 15, 2005 Share Posted April 15, 2005 Ah, another [H]er. Welcome to the forums. Link to comment Share on other sites More sharing options...
Osiris Posted April 15, 2005 Share Posted April 15, 2005 Wow! _ferry_ you should call that the stacker XXL.(Awesome work) Link to comment Share on other sites More sharing options...
darude_boy Posted April 15, 2005 Share Posted April 15, 2005 you could lock a dwarf in that haha Link to comment Share on other sites More sharing options...
JayDee Posted April 17, 2005 Share Posted April 17, 2005 Fantastic mod - I love how you are handling all the wiring. I'm in the process of ordering the parts for my project and I am also using two Cooler Master cases - In my case (not punny), errr, cases, I'm using two Centurion 5's. Cooler Master makes great stuff! (should be safe to say that on this site ) JayDee Link to comment Share on other sites More sharing options...
_ferry_ Posted April 19, 2005 Author Share Posted April 19, 2005 Past sunday i've ben polishing the PSU, and made some kind of cover for it, there is some space now between the fan ande the grill. So i hope there won't be noise of air fowing trough the grill. The PSU+ cover for it. Don't look at those fingerprints and tape When i did a test fit the cover was way to high for it, i guess you can see that black piece of the frame below the PSI slots. It pretents adding high PSU's. So i decided to mount the PSU 2cm more in the case. Ofcoourse you will have a space around the PSU if you do that. I've got an idea for that Today i've cutted down the sidepanels: Do'nt mind the different intensity, i just quickly added 2 CCFL's for the show. These are the things witch will fill up the hole between the case and PSU, 2 plexi and 3 of alu, the 3'th one is the version witch will be on top, like the standaard mounting plates. But now with the holes 6mm lower. All i did today was cutting down those sidepanels. cutting out the pieces above i will do next time because i'm having a headace now Link to comment Share on other sites More sharing options...
merovingian Posted April 19, 2005 Share Posted April 19, 2005 Simply Amazing! Link to comment Share on other sites More sharing options...
-=Draven=- Posted April 19, 2005 Share Posted April 19, 2005 There's simply no words to describe this. Link to comment Share on other sites More sharing options...
_ferry_ Posted May 4, 2005 Author Share Posted May 4, 2005 Finaly an update, ive been busy with some other things in the resting piece of my social life But i've been working on it. Bu i've done things witch are hard to see, like fine adjusting the upper case on the lower one, made some drawnings and new idea's and stuff like that. I've also bought a new camera, so i had to learn working with it as you can see at the pictures. Both the PSU's. Dont mind the bad white balance. Note the alu profeles on the edge, they are now on the right side. It fits perfect The backside of the PSU's. I'm going to hide them Notice the distance bolts, i'm going to mount a alu plate on it with some kind of grill witch will hide the PSU's and radiator. I'f i could describe it better in english i would do, now you guys should wait for new pics Damn, wat a cable mess Link to comment Share on other sites More sharing options...
Mr. Miyagi Posted May 4, 2005 Share Posted May 4, 2005 Looking awesome! Can't wait for more! I don't know what I would do with that many cables. Link to comment Share on other sites More sharing options...
_ferry_ Posted May 12, 2005 Author Share Posted May 12, 2005 Finally some time for updating, i worked on the sidepanels. I had the idea of finishing the rear, but i had to work out some things, and i need some money to purchase the stuff for it. The side like it used to be Taped, al the lines are 19 degree, the same as the italic font i used. Well, you might have never expected a rotating disk for this, but it works great :rock: I used a 1mm disk, it didn;t bite into the aluminium, and lines were very straight, i think because a large disk can't make small turnings. Still with the tape on it. Note that the corners should be finished with some fine dremel tools or some sandpaper. The resting piece of the sidepanel will be used for something like this. I want to make something that looks like a air intake, made of plexi. To give you an idea: This is 1 of the milion sketches i made during my training period. The pieces witch are sensored will be shown soon i hope so Link to comment Share on other sites More sharing options...
