Jump to content
[SPONSORED] Project JIZZ - Cooler Master MasterBox 5
KrypteK PC Modz
Hey guys! I'm DJ also known as Kryptek PC Modz from Ph. First of all I would like to thanks Cooler Master Philippines for letting me use their new chassis which I'll be using for this build.. Actually this is a quick build also so that their are no modifications on the chassis (maybe soon). :D
And before we start building, I just wanna share my specs for this build.
Specs:
Processor: Intel i5 6600K @4.6Ghz
Motherboard: Asus Maximus VIII Ranger Z170
GPU: Asus GTX Strix 970
RAM: Avexir Red Tesla 4x4GB 2666mhz
SSDs: OCZ Trion 150 240GB & Samsung 840 PRO 128GB
PSU: Thermatake Toughpower DPS G 1200w Platinum (Full sleeved)
Case: Cooler Master Masterbox 5 White
Water Cooling
CPU Block: Bitspower CPU Block Summit EF ICE Black
GPU Block: Bitspower VG-NGTX970ADIIS Acrylic Top With Stainless Panel (Clear)
Reservoir: Bitspower Water Tank Z-Multi 200 V2 (Clear Body & POM Version)
Radiator: Bitspower Leviathan Xtreme 360 4xG1/4" Radiator
Fittings: Bitspower 12mm OD, T-Block, Drain Valve, Air Exhaust & Extender
Tube: Bitspower None Chamfer Brass Link Tubing OD12mm Shinning Silver
Add-ons: Bitspower Logo Aluminum Thumb Screw for M3 (White)
Fans: Thermaltake Riing RGB and Riing White 120mm
Also I would like to thanks to all my sponsors who's making this possible.
Thank you for viewing! :D
Link to comment
  • Create New...
Important Information
