Megadeblow Posted February 4, 2017 Author Share Posted February 4, 2017 On 2/2/2017 at 1:20 AM, Ne1ld0 said: Oh, I forgot to ask now that Tron 1.0 is complete, how loud/annoying are your power inverter(s)? I'm only using one that has a sound controlled feature and it gets annoying pretty quick with that high pitched constant noise. Also, if you used 2 power inverters, is one for exterior and one for interior lighting? If so, would love to see pics with each turned on individually. Well, I cant hear the inverters, all i can here are fans and the pump, normal sounds The battery packs I have used did have a louder buzz, but once all hidden away inside a case they too will be very hard to hear when fans and pumps are going. Yeah using 2x, one for the outside and other on the inside, I can have a couple of light up modes then. Link to comment Share on other sites More sharing options...
Megadeblow Posted March 19, 2017 Author Share Posted March 19, 2017 I uploaded a vid that you might like to see, all about this build and some future plans for it, Now swapping out the RGB lighting that behind the logos with some EL tape for a perfect even backlight. Link to comment Share on other sites More sharing options...
Megadeblow Posted March 29, 2017 Author Share Posted March 29, 2017 Final Updates! Large EL panel to replace the RGB back-lighting as it was very uneven. CoolerMaster headset and Keyboard modded to match the case. Link to comment Share on other sites More sharing options...
Megadeblow Posted March 29, 2017 Author Share Posted March 29, 2017 Link to comment Share on other sites More sharing options...
Megadeblow Posted April 19, 2017 Author Share Posted April 19, 2017 Tron cycle update! While at the Makerfaire event I bumped in to some nice guys from 3D GBIRE, they had some Ultimakers out on demo and kindly said they would do me a quick print, by quick I mean 15hrs lol.. anyway, this is the result and its not bad for medium settings. made some double sided EL tape by folding and gluing. This is just resting on the case, not sure where I will place it as yet, maybe on the inside.. Link to comment Share on other sites More sharing options...
