Bjarne Bak Posted August 11, 2016 Share Posted August 11, 2016 Hi Anyone knows why the front usb connectors, both the v2 and v3 is mounted upside down? The reason for me asking is that I see it as a design flaw as all USB keys fitted with a LED will point the LED downwards. That means I will have to be on the floor (or place a mirror on the floor ... which might be a purchase optional component !) looking up if I want seeing if the LED is on or off. Also all USB connectors marked with the USB symbol will fase downwards. Such a good cabinet shouldn't be delivered with such mistake as a standard. And I have checked, you can't do anything yourself as it's fixed to a small curcuit board which can't be altered. Any tech insight are welcome. Cheers ~~ BeeBee ~~ Link to comment Share on other sites More sharing options...
