Jump to content
Gears of War 4 - ZenModz ( COMPLETED ) :)
Zenator
  • 2 weeks later...
  • Replies 34
  • Created
  • Last Reply
Hi everyone, Quick update of the build.
The White you see will soon be paint red.
Laser cutting and dremel work to add texture before painting starts.
The logo is only 80mm high so a lot of the fine detals like the lines in the teeth where lost so I had to add them back. and I had to make a " F " for the " OF " with the dremel as it got stuffed up in the vectors some how. I have also linished to text to add texture to it once painted.
Teeth lines added back
Thanks again for stoping by.
Link to comment
  • 3 weeks later...
Some more hands on stuff. One very small logo size 60mm round for the top of the case. using 1mm acrylic, some printed paper with logo and thin double sided tape.
it was then sanded with some 500 grit to round of the edges to clean it up.
Later it will be panted to same as the rest of the case so it looks like a embossing finish.
Thanks again for stopping by.
Link to comment
  • 2 weeks later...
  • Create New...
Important Information
