Jump to content
[Sponsored] Project: MakeMeCooler Doraemon Build Log
Winston
Project: MakeMeCooler Doraemon Build Log – Part 1
To kick off the new year in 2017, I would like to give you an update on our latest Project: MakeMeCooler Doraemon. Build Log.
The Components
  • Processor: Intel Core i5-7600K (Kaby Lake)
       … with CPU Waterblock: 1 x Bitspower CPU Block Summit EF for Intel – (ICE BLUE – Acrylic Top Version)
  • Motherboard: Gigabyte Z270X Ultra Gaming
  • Graphics Card: Zotac GeForce GTX 1070 AMP Extreme Edition (8GB GDDR5)
      … cooled by Bitspower full-cover GPU waterblock with RGB
  • Memory: GSKill Trident-Z DDR4-3200 16GB Kit
  • Storage: Patriot Ignite – 240GB SSD
  • Chassis: Modded Cooler Master Master Maker 5
  • Power Supply: Coolermaster V850w
  • Fans: 6 x Thermaltake Riing RGB fans
  • Watercooling: ALL Bitspower watercooling components with Hard Tubing
    • Stop fittings: 4 x Bitspower G1/4″ Royal Blue Stop Fitting
    • Compression fittings: 8 x Bitspower G1/4″ Royal Blue Enhance Multi-Link for OD 16MM
    • Compression Extenders: 4 x Bitspower G1/4″ Royal Blue Rotary 90-Degree IG1/4″ Extender
    • 120mm Radiator: 1 x Bitspower Leviathan Slim 120 Radiator
    • 240mm Radiator: 1 x Bitspower Leviathan Slim 240 4xG1/4″ Radiator
    • Flow indicators: 1 x Bitspower Flow Indicator (Royal Blue)
    • Mini Valve: 1 x Bitspower Royal Blue Mini Valve With Black Handle
    • Reservoir: 2 x Bitspower Water Tank Z-Multi 100 V2 (Clear Body & POM Version)
    • Pumps: 1 x Bitspower DDC Plus Pump
    • Pump Mods: 1 x Bitspower Premium Magic-Cube Type DDC MOD TOP G1/4″ (Acrylic Version)
Link to comment
  • 3 weeks later...
  • 3 weeks later...
  • 2 weeks later...
  • Create New...
Important Information
