Jump to content
SotosLg
Hello again!! Night time now and i decided to work on the face panel door and fitting again the lcd screen after lot of fiberglass resin has dripped where the screen should be mounted!!
So, at first, i had to sand the inner section/shroud of the lcd screen!!
20170331_205627.thumb.jpg.62cebd113209ecb18bc27f27808aac9c.jpg20170331_205632.thumb.jpg.c4a65db0d1d672c40db9eb3a99361bb7.jpg
In the meantime, lots of sanding and detailing was done with two more different bits for the dremel and the lcd screen came up to fit!!
20170331_215455.thumb.jpg.aa7a8e2a59ad07b30aacb583fa221874.jpg20170331_215505.thumb.jpg.28abd6bdbcf0048ea5db84c43ab02ba5.jpg20170331_215514.thumb.jpg.bd03b28666779f0bc2b67cf35703c691.jpg20170331_215533.thumb.jpg.e409980f90340e356620d649f69a7420.jpg
Next i decided to paint it with a layer of primer to see how it's going to look!!
20170331_220147.thumb.jpg.7d183f50ef23eb624744ca88bb3e6785.jpgreceived_10155947918237067.thumb.jpeg.d35faf97d25ff8f90b8e406db7665165.jpeg
Next, i thoroughly checked the fiberglass for issues and found a very small gap between the aluminum and the fiberglass which made me a bit anxious so i thought i apply some cold weld there to fill it!! The hole there was a bubble created when i was applying the resin on the hair, so i thought to make it an advantage and then i applied there some cold weld too!!
20170331_224000.thumb.jpg.ccda8107de4b34781e0d42e8edf47c21.jpg20170331_224014.thumb.jpg.901e5faedff44257cd7367dfe4bd876b.jpg
Tomorrow i will be sanding the fiberglass as the primer could not stick properly on the un-sanded area, so next day i will be doing some minor sanding on the cold weld too!! Until then, Peace Brothers!!
Link to comment
  • Replies 106
  • Created
  • Last Reply
I would like to apologize for the days i was not posting, i had issues i had to solve, so now, lets get started!!
Face panel door is painted with primer and sanded a bit!!
S4130001.thumb.JPG.97750b559326e35eab72a36cae571e5e.JPGS4130002.thumb.JPG.ca385814266f6437f2af703dd42be442.JPGS4130003.thumb.JPG.fde91b713faf277fa7312742b006bea8.JPGS4130004.thumb.JPG.622fecc8cd56c13a0c8ecf13387ff97c.JPGS4130005.thumb.JPG.95809f6bb6dbe1235a4f92c59470f99a.JPG
So, next it was time to hit it with a thick layer of primer!!
Here as you can see, are the main tools to achieve that effect i created to the front face panel!!
Next, i painted it with a thick layer of orange color!!
S4130007.thumb.JPG.92dc2f94bb79dd37b6d1b1da042d8740.JPGS4130008.thumb.JPG.f754bb1398fba24ba2ab9509c344a2fa.JPGS4130009.thumb.JPG.773c3faa62750afcabead2d3747074ab.JPGS4130010.thumb.JPG.3c7d057cf1d664ebd4a6ba5d1e2e562a.JPGS4130011.thumb.JPG.da5703b6a2a7f29715ed50eb5efd8a54.JPG
I run into a little trouble so i had to stall it until night time, so next i applied a layer of black matt color on it and then (as it was wet) i applied a plastic bag to create that kind of effect and i must say it quite satisfying!!
S4140001.thumb.JPG.644c2b6351b24ab5ffc85d1b6ee40f0b.JPGS4140002.thumb.JPG.d4b62485a41ceb15dca959a595bc191a.JPGS4140003.thumb.JPG.231ebbc2d53c0ff2bee9a791c7d1c583.JPGS4140004.thumb.JPG.f83557816594ba678dd14a04dc81fa5c.JPG
What i'm planning next, is to assembly the whole face panel to see how it is going to look, until then, Peace Brothers!!
Link to comment
Hello again!! Today i decided to assemble the front face panel to see how it looks and i must say the result is very promising and satisfying!!
S4160006.thumb.JPG.5c3c09c67c4a2a1732a4704911283294.JPGS4160005.thumb.JPG.0bbae896e5578dd3c8504af447b92fd2.JPGS4160004.thumb.JPG.2ea7fe302c325e0bf5368e754bbd6627.JPGS4160003.thumb.JPG.b19bc1cb5855a69ebcb7ad8f7f9ea4f1.JPGS4160002.thumb.JPG.50eb8bb020ce27f91fcdb40c125e7646.JPGS4160001.thumb.JPG.dcbde38faa05a5c5806014a435446337.JPG
Along with that, i run into some serious trouble i found out few hours ago on the side panels which i have to solve very quickly!! I'll post some updates soon, until then, Peace Brothers!!
Link to comment
Hello again!! What i was talking about is that i found a crack along the effect's outline and kind of gave me goosebumps of fear!! I wanted to think of what i will do so i found out that i should amplify it with a mixture that a friend told me to!! What is it all about is liquid fiberglass mixed with two element epoxy glue and some silicon!! At first, i made it without thinning it so it was quite difficult to get it to go into the crack so i used a syringe for that purpose!! Enough talking, lets get to business!!
Here is the crack!! :(:(
S4170001.thumb.JPG.7a80c9a12771f5adff76c22309ed8a5e.JPGS4170002.thumb.JPG.dc7b288ef47dffe68a40d378099d9aac.JPG
I would like to apologize for the image quality because it was quite dark and little lighting!!
Next i took some liquid fiberglass, a two element epoxy and some silicon glue and mixed them together!!
S4170003.thumb.JPG.a8b521f93b093191ade14e81809cb048.JPGS4170004.thumb.JPG.08dbc9c8b567e12e015e47cf12bd308a.JPGS4170005.thumb.JPG.a10beb39ab36f67efd0a2c3cb1aae47b.JPG
Here is the first pass without thinning the mixture!!
The mixture is quite dry and....hot!! :o:D
Next, i decided to make the mixture thinner using aceton, the only liquid material that thins liquid fiberglass and cleans the equipment used on that material!!
So, i took a syringe with two kinds of needles attached and putted them in and outside of the crack to let some liquid go through!!
S4170008.thumb.JPG.e8414e93d0e0bc5cac80164992098822.JPGS4170009.thumb.JPG.7a4db1c5b3b862c37c85750aaafa24ec.JPGS4170010.thumb.JPG.295a48f66255b79054e2e28317d3b744.JPGS4170011.thumb.JPG.d41d34b40107a917c2972c090951bc73.JPG
What happens next, is let cure over night and add some more in the day time!! This is a good chance to figure out how i will fuse the two painting techniques i am making in this case mod as the panel will not remain as it is!! For the painting i will be using, i'll inform you later on these days, until then Peace Brothers!!
Link to comment
Hello again!! Day time and i had to fill another crack on the first side panel!! Same mixture, same procedure but no thinning!!
Next in the evening, i went to take some goodies i ordered for the "cause"!! What is it all about is two orange BitFenix fans and an EK slim single radiator!!
S4180002.thumb.JPG.4e73e7ad388367fbbd209073a5249e58.JPGS4180003.thumb.JPG.e4e9b2d33af631479670a5b11030c226.JPG
Next, i decided to take the other side panel to fix a crack!! Here again goes all the same procedure with little bit of thinning with aceton!! This part i'll let it cure overnight!!
S4180004.thumb.JPG.1a401c4b4ed9fe415f5b93eba9853ab9.JPGS4180005.thumb.JPG.93f2bdcb4171fe71a876685ea3d0d642.JPGS4180007.thumb.JPG.6d35cecb3b9d35c1cbc0112cff8c9358.JPG
What i'm planning next is to amplify the case with some iron angles we use for furniture, until then, Peace Brothers!!
Link to comment
Hello again!! Until the amplification happens, i ordered these goodies!! A semi-modular Cooler Master 750watt psu and an angled hdmi cable which i'll need for the lcd screen!!
PER.811694_2.jpg.7a1d4896c5ac6247e079b024a4538a4b.jpgPER.811694_1.jpg.e6bc1a7a32bff6a671892569a69216e1.jpgPER.811694.jpg.b5505100b2fc9d29980bd688a420e548.jpgPER.572150.jpg.12810f3f4b8e2c25a45043c1d9f8efff.jpg
Later on today, i will be finishing the lamda and the 2 logo which will be glued on the side panels!! Lets get started finishing the Freeman's computer!! He will get very angry if it doesn't!!
Link to comment
Hello again!! Today was the day that i will be finalizing the second 2 logo!!
So, lets get started!! I took the previously made 2 and marked the area of the thick acrylic!!
S4190001.thumb.JPG.3747daf4e998be1c98a606585de70918.JPGS4190002.thumb.JPG.add7256a65bc6e4cbd9b51419599a3d8.JPGS4190003.thumb.JPG.523311fa2d2741f2fc1ae71265ef7364.JPG
Now, for the cutting, i decided to try something old, i took this kind of cutting bit for the dremel and started cutting the outline of the 2!!
This bit is mostly used with a guide bolted on the nose of every dremel!!
I must say this kind of cutting is much easier and more detailing because you control the dremel and where the cutting process goes!!
S4190005.thumb.JPG.720161e267624dbcec495978ab3741d5.JPGS4190006.thumb.JPG.acffddf0311025fc385c9278c1c20d73.JPG
Next i decided to attach the two pieces together to sand them down!!
S4190007.thumb.JPG.b40362807656c3397966aeee600beb85.JPGS4190008.thumb.JPG.c8595dd28788232f4ab1a86d87936e74.JPGS4190009.thumb.JPG.933165a90c50441d7f215bbef52fc4c4.JPG
Seeing the last picture, i instantly thought to try something else, i thought to glue them together using some liquid fiberglass and then finalize them with the same liquid mixed with some putty so now i don't have to get that much detail as the material next will cover those imperfections plus it will create some kind of melted effect!!
I will continue the update in the next post!!
Link to comment
Here goes the rest of the process, i made some fiberglass mixture and added some droplets of the liquid and spreaded them along the coverage
S4190011.thumb.JPG.44a4770c98769fe9db37ba5218e36688.JPGS4190012.thumb.JPG.cad4a964a8a92775b2ac98f4323b83c1.JPG
I added some more material on top of the logo's part!!
So, now, i'll let it cure for a couple of hours or maybe overnight and next morning i will finalize the previously made lamda and the lamda for the other side panel, until then Peace Brothers!!
Link to comment
Hello again!! Last night i thought why should i bother myself with acrylic where the Freeman will be placed and not cover it with fiberglass?? Instantly i decided to do it!! My fiberglass hair was wet and used some cloth!!
20170419_015456.thumb.jpg.c7155368dc6a91bab6c37c9a626a68f8.jpg20170419_015511.thumb.jpg.f624015f945131609d1824fa517008ae.jpg20170419_015516.thumb.jpg.93fd3b6c45d54b938cecbe0f363907d2.jpg20170419_015528.thumb.jpg.abd3b54447bfff1e2859f614ca16da81.jpg20170419_015543.thumb.jpg.f1280b95f3daa499b5f6fa826390bcc8.jpg20170419_020709.thumb.jpg.244690cb0e4bbdbd23113a46734e9e92.jpg
Now i am ready to make the first mixture!!
Here is the area with some spare hair i had!!
20170419_023323.thumb.jpg.82c9f00453513fee6a1ecf0e8edea653.jpg20170419_023330.thumb.jpg.35c54b562f42db4bc7cd895c9662ddb9.jpg
I let it cure overnight and now i will go for some inspection and further enhancement!!
Link to comment
Hello again!! Here is the work made with the 5.25" bay where the Freeman will be placed!! I'm doing it that way in order to paint it just like i wanted and have that effect i have on the face door panel!! Liquid fiberglass is a tricky material, you might get itch if you don't work in a well ventilated room or area!! :D:D
S4210001.thumb.JPG.03dd8ff23b57e14ee273fd6aeb7cd1b5.JPGS4210002.thumb.JPG.d63a6b754c17521ba651cd30f9c3ede2.JPGS4210003.thumb.JPG.9809348a5ccad9eabc84e743cebbdcc8.JPGS4210004.thumb.JPG.5946c6dee8b62592e101b0898b80f171.JPGS4210005.thumb.JPG.c872bc5acd8855de8a03bafc6a57e39a.JPGS4220001.thumb.JPG.5149cfabbfdcf423b5daee50c79bd6a8.JPG
There are only few steps to finalize the whole project so the eye of the Freeman will be harsh!! Until next update, Peace Brothers!!
Link to comment
  • Create New...
Important Information
