Sergey Mnev Posted April 8, 2017 Author Share Posted April 8, 2017 And here are the new parts of the case, made of steel with a thickness of 1mm. Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 12, 2017 Author Share Posted April 12, 2017 I continue to work on the project! There are quite a lot of progress ! Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 17, 2017 Author Share Posted April 17, 2017 The parcel with the components of liquid cooling partially came. Reservoir: BARROW 270MM LFPG65-V3TGB Top: EK-XTOP REVO D5 - PLEXI Here's how the components in the case will be located approximately. In the role of the processor water block I chose: Bitspower Summit EF Ice Black (Intel, Acrylic) (BP-WBCPUIAC-BKMBKIBK) Here is a detailed overview of the water block that I did a long time ago: https://www.overclockers.ru/lab/79149/obzor-i-test-processornyh-vodoblokov-bitspower-summit-ef-i-watercool-heatkiller-iv-pro.html Preparation of the last elements for painting!!! 1. Cover of the motherboard ASUS ROG Maximus IX Formula. 2. CPU waterblock: Bitspower Summit EF Ice Black (Intel, Acrylic) (BP-WBCPUIAC-BKMBKIBK) 3. Metal rings of the reservoir BARROW 270MM LFPG65-V3TGB 4. Plastic ring og the Top: EK-XTOP REVO D5 - PLEXI And the details are ready for painting. I forgot to add a water block Bitspower GTX 1080 ROG Strix Acrylic Limited Edition (Clear) BP-WBV1080ARS-RGB5 for the video card ASUS GTX 1080 ROG Strix. Here is a detailed overview of the water block that I did a long time ago: https://www.overclockers.ru/lab/80702/obzor-i-testirovanie-vodoblokov-polnogo-pokrytiya-bitspower-i-ekwb-dlya-videokarty-asus-geforce-gtx-1080-strix.html Its plastic overlay will also be painted. Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 21, 2017 Author Share Posted April 21, 2017 Here are a few photos of the painting process. Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 21, 2017 Author Share Posted April 21, 2017 And here is the result of the painting. Part 1 Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 21, 2017 Author Share Posted April 21, 2017 And here is the result of the painting. Part 2 Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 22, 2017 Author Share Posted April 22, 2017 And here is the result of the painting. Part 3 Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 26, 2017 Author Share Posted April 26, 2017 Result of painting the casing of the motherboard and processor water block. Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 26, 2017 Author Share Posted April 26, 2017 It was the turn HyperX FURY Black Series HX421C14FB2K2/16 х 2 & HyperX Predator PCIe SSD SHPM2280P2/240G Link to comment Share on other sites More sharing options...
Sergey Mnev Posted April 26, 2017 Author Share Posted April 26, 2017 Preparing the water block Bitspower GTX 1080 ROG Strix Acrylic Limited Edition (Clear) BP-WBV1080ARS-RGB5 for the video card ASUS ROG STRIX-GTX1080-O8G-GAMING. My review: https://www.overclockers.ru/lab/80702/obzor-i-testirovanie-vodoblokov-polnogo-pokrytiya-bitspower-i-ekwb-dlya-videokarty-asus-geforce-gtx-1080-strix.html Link to comment Share on other sites More sharing options...
