Samca Posted March 31, 2017 Author Share Posted March 31, 2017 Applying the first layer of resin to be sturdy and rigid. Link to comment Share on other sites More sharing options...
Samca Posted April 12, 2017 Author Share Posted April 12, 2017 Hi guys, here's the update. The body will be finished very very soon. And i will be working on the wings next week. I used acrylic sheets to layer some armor for the body and used some rivets and allen bolts to hold them unto the body. Here's the plan for the frame: I used steel pipes for the frame. Link to comment Share on other sites More sharing options...
Mgyovanni Mods Posted April 15, 2017 Share Posted April 15, 2017 Amazing Man!!!!!! Link to comment Share on other sites More sharing options...
Samca Posted April 18, 2017 Author Share Posted April 18, 2017 On 4/16/2017 at 5:53 AM, Mgyovanni Mods said: Amazing Man!!!!!! Thanks! Link to comment Share on other sites More sharing options...
Samca Posted April 18, 2017 Author Share Posted April 18, 2017 The metal pipes are measured and ready to be weld. Sanded the mobo tray and checked if it will fit correctly. After hours of sanding, I painted the body using a primer paint to see the imperfections and to be corrected asap. The sanding made the body to achieve the curves and eliminated the sharp edges. Link to comment Share on other sites More sharing options...
Samca Posted April 19, 2017 Author Share Posted April 19, 2017 Almost there, welded the pipes together. I decided to alter the design a little bit because of the size of the mobo. But the chassis frame is still the skeletal base of the body as you can see. Drilled some holes to fit everything . And here it is, finished the chassis frame. Now it's time to assemble everything from the wings and to the other details I will use rivets to attach the mobo tray and the bracket of the parts to have a rigid and sturdy build. Link to comment Share on other sites More sharing options...
Samca Posted April 22, 2017 Author Share Posted April 22, 2017 EVGA SUPERNOVA G3 1000w and EVGA SuperSC DDR4 RAMS thanks so much EVGA. Mounting the PSU. I used 5 mm acrylic sheet. GPU mount placed at the center. I used some 3mm Acrylic sheets for the pump and res mount, Link to comment Share on other sites More sharing options...
Samca Posted April 22, 2017 Author Share Posted April 22, 2017 Thanks Cooler Master Philippines for providing the Masterfan Pro 120 RGB Link to comment Share on other sites More sharing options...
Samca Posted April 22, 2017 Author Share Posted April 22, 2017 Painted the metal frame Link to comment Share on other sites More sharing options...
Samca Posted April 22, 2017 Author Share Posted April 22, 2017 Done with bending tubes and finished the watercooling loop. I will be working on the wings and other details to finalize the build Link to comment Share on other sites More sharing options...
