Explore Modding Posted February 21, 2017 Share Posted February 21, 2017 Hi Guys! I'm here to present my entry for the Tower Mod category of Case Mod World Series 2017! The Project is based on a Coolermaster Mastercase Maker 5T. It's called "Pure Binomial" because the theme is based on the binomial between clear and non-clear parts, in fact, the front and back panels will be almost completely transparent, allowing to see the internals from different angles. It will also feature a really complex custom loop with CPU, RAM and GPU blocks, a 360mm radiator, and three 150mm reservoirs, as well as a 755 pump. So, let's begin with sponsors and then we'll head to the modsss! Seasonic - PSU Seasonic Prime Titanium 750W Coolermaster - Coolermaster MasterCase Maker 5T Aquatuning - Watercooling, cooling in general, lighting Nanoxia/CoolForce - Pass-through fittings VG Informatica Torino - Sleeved cables Apacer Global - SSDs Panther AS340 240Gb So, let's start with the pics! A new update will come soon, the watercooling loop will start to take shape so make sure to subscribe guys! Link to comment Share on other sites More sharing options...
knud Posted February 21, 2017 Share Posted February 21, 2017 Starting to look interesting One small note: the plastic clips under the graphics card (from the metal holder) are upside down. Is that on purpose? Link to comment Share on other sites More sharing options...
Explore Modding Posted February 21, 2017 Author Share Posted February 21, 2017 1 hour ago, knud said: Starting to look interesting One small note: the plastic clips under the graphics card (from the metal holder) are upside down. Is that on purpose? It is! I did that because if I mounted it normally I would have to angle it in order to reach the graphics card. Also, the bottom of that clip has a shape that allows to almost close the card into it, so it holds up and also keeps the card from waving back and forth. But I still have a long way, maybe I will adjust it in some other way Link to comment Share on other sites More sharing options...
Explore Modding Posted February 21, 2017 Author Share Posted February 21, 2017 The loop is pretty complex, I gotta say I spent several hours just thinking about the components order, to optimize the looks. I feel like those hours were well spent! Still back and bottom tubes to make, with satin tubes! Then some other structural mods and finally I'll get to detailing and painting! A couple shots with the reflex Here are some shots of the new SSDs by Apacer: Link to comment Share on other sites More sharing options...
knud Posted February 22, 2017 Share Posted February 22, 2017 23 hours ago, Alessandro Zaiti said: It is! I did that because if I mounted it normally I would have to angle it in order to reach the graphics card. Also, the bottom of that clip has a shape that allows to almost close the card into it, so it holds up and also keeps the card from waving back and forth. But I still have a long way, maybe I will adjust it in some other way Yeah, that makes sense. During my testing, it wasn't directly needed - but a good thing to keep in the back of my mind Link to comment Share on other sites More sharing options...
Explore Modding Posted March 9, 2017 Author Share Posted March 9, 2017 Little update guys! More to come next week Link to comment Share on other sites More sharing options...
Explore Modding Posted March 20, 2017 Author Share Posted March 20, 2017 Hi guys! Here I am with a pretty big update! I started to make the side panels and mod the movable front panel. Also, I fixed the floating SSDs and remade the midplate panels with a 5mm plexy for surface lighting. Even made the last tubes that were missing Link to the side window opening video: https://www.facebook.com/SaaintJimmy/videos/1422758367775659/ Link to comment Share on other sites More sharing options...
Explore Modding Posted April 13, 2017 Author Share Posted April 13, 2017 Hi guys, It's been awhile but I did a lot of progress since I have about two weeks left to complete the mod. Here are the pics of new panels, a few tubes and the start of stencil design and paintjob! I will probably do two other updates at max, before the final result so make sure to stay tuned so you won't miss the final shooting! Link to comment Share on other sites More sharing options...
Explore Modding Posted April 26, 2017 Author Share Posted April 26, 2017 Big update, we're almost at the end! Let's take a look at the pics of the progress so far This is all for now, next update will be the final results! Stay tuned and support me in the competition if you like my work! Thank you Link to comment Share on other sites More sharing options...
David Mayers Posted April 27, 2017 Share Posted April 27, 2017 You have my vote Link to comment Share on other sites More sharing options...
