Danilo The Cloud Posted March 3, 2017 Share Posted March 3, 2017 Hi! This is my build. It will be made out of wood, to be precise, Eurepean beech (common beech) wood. I chose this wood, since it is hard, dry, and, well, common, sice it is common beech, it is common. To start things of, I made a 3D model in solidworks. You can see some screenshots here. There we go. I hope you know that the first pic is a final profuct - how I hope it will view, the second one is the front view, the third one is a side view and the last one is a top view, where you can see, that the motherboard will be turned by 90°. Okay, I was going to use Maple first, as seen below, but it would need too much processing. Okay so I got my wood, the beech one, so let's do something. 1st I put some planks together, to form a side. I proceeded to glue the planks together and put the side in a press. Well, that failed, since when after 3 hours I came back, I was left to see a bent side. To be continued... Link to comment Share on other sites More sharing options...
