Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Now doing the tap radiator fan grill/guard after cutting and wrapping the grill(forgot to take pics ) KAAL_GATI is taking its shape Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Adding illumination to the MB tray with White LED strips after testfitting of MB Back panel Stay Tuned for the updates i hope you liked my work Link to comment Share on other sites More sharing options...
Gamerznation Posted May 2, 2017 Author Share Posted May 2, 2017 Final Update on the KAAL_GATI build : had names cut from a local laser shop.pasted them with acrylic glue . used a safety pin to apply as names are very thin. Every thing is fitted and working. finally had some pics of it out in the open and dark. Have a look. KAAAL_GATI. FINISHED . In DARK ROOM Link to comment Share on other sites More sharing options...
Gamerznation Posted May 2, 2017 Author Share Posted May 2, 2017 Thank You for taking your time out to check my work. I hope you like it. GGWP. over n out' Link to comment Share on other sites More sharing options...
