Wtomike Posted March 29, 2017 Share Posted March 29, 2017 Hi, I'm Mike Wang and I'm from Taiwan. This mod is inspired by Blizzard's FPS game "Overwatch" Blizzard made a short animation for Overwatch called "Dragons" The story is about two brothers, and their internal conflict about each other. Inspired by the animation, I build a Desk Mod PC. This build have an animation scene, and water cooling with Overwatch logo. Please enjoy my build. Finish!!!!!!!! Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 Hardware configuration CPU : Intel Core i7 5960X MotherBoard : MSI X99A GAMING 9 ACK Memory : G.SKILL TRIDENTZ DDR4-3200 8G * 4 quad-channel Graphics Card:MSI GTX980-Ti LIGHTNING *2 SLI Power Supply:CoolerMaster V1200W Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks to Water-cooling supplier MSI Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 1、Design Concept Through the e-sports game Overwatch theme, paired with PC components, water cooling system, and a lot of laser engraved acrylic, making a PC mod with e-sports concept. It’s It’s aiming for all games, gamer, and hardware enthusiast. Pink : Fan & Radiator Gray: Reservoir Yellow: Motherboard Blue: Power Supply Green : Hanamura Scene Exhaust vent acrylic design Tabletop acrylic design Table legs acrylic design Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 2. The building process for Hanamura Scene This part referenced the design and interior layout within the actual game scene Hanamura. Although in the video, Hanzo and Genji duel in the corridor, not in the room, considering the figures is in a closed space, and the interior model is richer, so their duel is being moved indoor. In the production process, walls and floor structures are being laser-cut, and the interiors are decorated by types of art papers and thin pieces of wood. The wood started to be dark brown, as according to the game, but it would be unnoticed with beige floor and walls, making darker it would blend it with the trim on tatami mats. After changing to a red-ish brown, the result turns out to have a bit more depth. Something worth mentioning is the curved wood straps forming the eave shape. They’re made using wood bending technique, usually used on wooden furniture, making a little scenery in this scene. Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 2-2. Details of the desk All the character graphs on the table legs acrylic are all redesigned and redrawn to fit the design of the table itself, and not just taken directly from official pictures. The hardest part of this must be the dragon tattoo on Hanzo. In order to achieve the best engraving effect, expanded graph of tattoos are found from the internet, overlaid onto the torso, and redrawn stroke by stroke. It’s quite some hard work, but the result of dragon tattoos turn out to be satisfying. Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 2-3. Laser engraved acrylic tabletop The double dragon on the tabletop is drawn with the same style as the Hanzo dragon tattoos on the table leg, but bigger. It’s also not from the official graphics, but they also turn out to match up pretty well. Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 2-4 Accessories I want not only the case itself ,but also the peripheral is modded with Overwatch theme. So I put in some effort on the side of the desk, the speakers, and keyboard. Acrylic fan shield with character skill icon from Hanzo and Genji Edifier S530D speaker with OverWatch Logo Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 Custom made keyboard DUCK LIGHT SAVER v2 This keyboard only comes with PCB and aluminum case. The switches and key caps needed to be soldered one by one. Cherry mx blue, green, and white are used for the keyboard. The selection of key caps originally is GMK, but soon changed to OverWatch themed key caps from MassDrop. In the end this keyboard costs around $1000 Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 3. Genji & Hanzo figures makeover Here comes the most important part of this PC build, the two figures of the main characters! Upon initial planning, considering the size and difficult, cute-version figures are decided. Making them with human scale would both be too time consuming, and they would look too small if to fit into a PC. In order to fit within the timeframe, modifying pre-made figurines is much more efficient than starting from scratch. (Which is common when prototyping) I started looking for templates from mainstream nendoroids from GSC, and finally came up with two. Kogitsunemaru from touken-ranbu (GSC#525), and Iron Man Mark 7 (GSC#284) from Marvel It just so happens that Iron Man figurines comes with Tony’s face, of which can be fitted on Kogitsunemaru as Hanzo’s face, and looks quite alike. However the hair for Hanzo has to start from scratch with putty. From Iron Man to Genji is pretty straight forward, only some slight modification is needed. Although the figurines themselves are adjustable, but due to the modification process they became static models. Link to comment Share on other sites More sharing options...
