Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 4. Water Cooling system setup This is the hardest and the most time-consuming part. Water loop needs to go through three areas: Animation scene, component area, and radiators. During the installation process, even though pipes are planned in advance, but when actually putting them together, problems occur so it’s not 100% connected according to plan, making the process both harder and takes longer. There are some difficulties when connecting hardline pipe between areas. Half of both areas needs to be finished first, get tested for any water leaks, and only if they are properly connected and sealed off, the following pipes can be installed. Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 Link to comment Share on other sites More sharing options...
Wtomike Posted May 3, 2017 Author Share Posted May 3, 2017 Finish Link to comment Share on other sites More sharing options...
