Inony Posted May 3, 2017 Author Share Posted May 3, 2017 This piece I use acrylic laser cutting. And bending it with heat. Link to comment Share on other sites More sharing options...
Inony Posted May 3, 2017 Author Share Posted May 3, 2017 Other parts below I also use the same heat bending. And keep it clean with sandpaper and putty Link to comment Share on other sites More sharing options...
Inony Posted May 3, 2017 Author Share Posted May 3, 2017 put Linear Motor and other. At base for m/b setting.After that,I Mod Cooler master Liquid pro 120 for feeling Sci-fi concept Link to comment Share on other sites More sharing options...
Inony Posted May 3, 2017 Author Share Posted May 3, 2017 After that I put everything together. Link to comment Share on other sites More sharing options...
Inony Posted May 3, 2017 Author Share Posted May 3, 2017 Link to comment Share on other sites More sharing options...
Inony Posted May 4, 2017 Author Share Posted May 4, 2017 After test it already and everything ok. I was back in the armor part .I raised it up with my linear motor.And management all cable.It's one of the projects I like so much.It's make me easy to maintain. Link to comment Share on other sites More sharing options...
Inony Posted May 4, 2017 Author Share Posted May 4, 2017 The next step in the armor around.I take a few days. How to make it move?.Finally, I tried the servo motor.It is a piece of radio control aircraft. Link to comment Share on other sites More sharing options...
Inony Posted May 4, 2017 Author Share Posted May 4, 2017 I spent several days on a trial and error with my friends.Finally, I did it. I wrote the C++ with arduino mainboard. I connected it according to my easy diagram.and write C++ with arduino M/B for Rotate 90 degrees Link to comment Share on other sites More sharing options...
Inony Posted May 4, 2017 Author Share Posted May 4, 2017 When it moved, it was attached to the case. Link to comment Share on other sites More sharing options...
Inony Posted May 4, 2017 Author Share Posted May 4, 2017 Link to comment Share on other sites More sharing options...
