Rakazone21 Posted April 24, 2017 Author Share Posted April 24, 2017 Helloo everybody,, Thankyouu keep stay on my worklog.. Here I have prepared acrylic at the beginning of the worklog, the part I want to do now is the side casing .. I will do the initial drilling, for the rotary hinge section using axles and bearings. Which then I deepened again about 2mm, So that the surface is flattened with the other parts After finishing the holder for the hydraulics, I made the installation of a rotary hinge for the hydraulic end of the swing and do not forget also to make persing to head bolt to surface flat with acrilic I will try to install the hydraulic with the bearing holder that I made earlier,, try it first with plywood .. I am afraid of wrong and choose to be careful, although I have measured and I make sure it. And also I do a test whether hydrolic can work as I expected or not. Next...... Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 24, 2017 Author Share Posted April 24, 2017 Progress still go on... Enjoy a process, love your work, and satisfaction you get More than hobby,, its anthusiast for me.. This is a transient result ,, my hydraulics set to open half course Half Opened Thermaltake ModX Fan Full Opened Link to comment Share on other sites More sharing options...
creative workshop Posted April 24, 2017 Share Posted April 24, 2017 Great idea with the doors from the lamborghini. Excellent !!! Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 25, 2017 Author Share Posted April 25, 2017 Thanks friends, for support and spirit .. your project is also pretty good to me .. very2 detailed process Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 25, 2017 Author Share Posted April 25, 2017 Thanks friends have followed my progress so far ,, Today I am planning on cutting back the main case, doing some painting items, and cleaning the components I suppose it's dirty. The first step, I remove the rivets with a drill, on the plate that I will not use later Then I will start cutting the part that I have measured to enlarge the space in pc And I smoothed the scrapbook with a miser I cut the acrylic sheet to make the top cover psu I made it with the right size so that the results fit and neat Because all my computer hardware is secondhand, so everything looks blurry, dirty, and dusty. Consequently I will do the cleaning on every component that I will plug in this rig. Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 25, 2017 Author Share Posted April 25, 2017 Next I will mod's the psu,, Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 25, 2017 Author Share Posted April 25, 2017 Hy friend's ,, i will unpack psu .. because psu long enough i wear and have aged .. so maybe a lot of dust there .. lol .. let's check .. Before I will close the corsair sticker with clear tape, so that later when I paint easy to remove it ,, and easy to find the curve part so that I can easily cut in accordance with the pattern Then I continue the work of unpacking the psu cover first with a screwdriver plus rusty and dusty everywhere.. Hahaha.... but it's working next, I took off the part I could take off After removing the cover, fan and others .. I will cover certain parts to avoid paint during painting process Next.. Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 30, 2017 Author Share Posted April 30, 2017 Hy friend, sorry I was late to post worklog a few days yesterday .. one day i got sick and the next day there was a family event so i could not work and also show some process i was supposed to do. And thank you for the visit in my worklog.. I will showcase for some work processes yesterday ,, including mod powersupply which I have done a few days ago.. This is the result of the inside of the psu that I have cleaned of dust and other dirt with brush, vaccum cleaner and oil WD cleaner Then i put back the psu cover Next is to prepare comb clip for cable Link to comment Share on other sites More sharing options...
Rakazone21 Posted April 30, 2017 Author Share Posted April 30, 2017 Again I play acrylic .. I will make a hole with the size of diameter 12cm for air flow powersupply, because I make a psu cover on the bottom psu .. if I do not make air holes powersupply will be hot and probably will reduce age and durability .. The process of staying a few more steps .. I hope will be completed on target .. Amin .. Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 1, 2017 Author Share Posted May 1, 2017 Hello Friend's.. Today I formed the legs for the casing, cut the net plate, bend the acrylic, and do some finishing stages Link to comment Share on other sites More sharing options...
