Peter Posted October 6, 2017 Author Share Posted October 6, 2017 Case and parts are nearing completion now just need to add in the tubing. We have decided to drop the hard tube and go back retro with soft tube. It is more in keeping with the "less than perfect future in which the bladerunner world is set and also matches the curves of the wiring. Link to comment Share on other sites More sharing options...
Peter Posted October 22, 2017 Author Share Posted October 22, 2017 A test fit of the PCIE cable just to check lengths, finishing the motherboard armour today and we are nearly ready to add water. Link to comment Share on other sites More sharing options...
Sunday Morning Posted October 23, 2017 Share Posted October 23, 2017 great touch man Link to comment Share on other sites More sharing options...
Peter Posted October 30, 2017 Author Share Posted October 30, 2017 Had some time between pumpkins and kids football this weekend to get some modding done. I set off doing the last of the cables 24 pin.. saving the most tedious for last! Dylan got to work rusting up the case, he did two shades of rusting to give it a weathered look. Now its dry I think it perhaps needs some chipping and some more shadow with some washed out black. He loved the rusting up watching him I think you could spend literally hours lost doing that. Link to comment Share on other sites More sharing options...
Peter Posted November 18, 2017 Author Share Posted November 18, 2017 Armour added still a lot more rusting and degrading to do but heading there at last, son is free tomorrow for the afternoon after football so hoping to get the soft tubes added and a test fill. Link to comment Share on other sites More sharing options...
Peter Posted November 25, 2017 Author Share Posted November 25, 2017 Leak test and system check before last details and some dye to the loop. Still quite a bit of rusting effects to add to the raining "too new" looking sections. Link to comment Share on other sites More sharing options...
