Coolone Posted October 24, 2018 Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 01By Coolone a. Name of mod: "LAN-Party RGB Laptop 2018" b. Description of my case mod: Idea For my "LAN-Party RGB Laptop 2018" Case Mod I will use an Black Aluminum Suitcase and some nice aluminums rods in "mirror like" finish for the Frame Structure combined with some nice wood. I will use some nice RGB components for my Case Mod. I will build it up in an modular way inspired by the modular way the Cooler Master MasterCase Series is made. If I build it up in an modular way the Case Mod will be something like an test bench. Module 1: The Aluminium Suitcase Module 2: The Frame Structure Design with nice wood Module 1 & Module 2 Module 1 + Module 2: Module 2 fits into Module 1 = For safe transportation Module 1 + Module 2: Module 2 fits on top of Module 1 = Test Bench = Portable High-end Gaming Case Mod c. Introducing Pictures: Some introducing pictures of my case modding project. Module 1: The Aluminium Suitcase TOOLMATE DT-932078 - 460 x 335 x 150 mmhttp://www.silvan.dk/ Module 2: The Frame Structure Design with Motherboard Tray Safe transportation: Module 2 fits into Module 1 Test Bench: Module 2 fits on top of Module 1 d. Test Bench: Some information and pictures about Test Bench. In hardware terms I think Test Bench is most of all used by Overclockers. "Test Bench" - Wikipediahttps://en.wikipedia.org/wiki/Test_bench A test bench or testing workbench is an (often virtual) environment used to verify the correctness or soundness of a design or model, for example, that of a software product. The term has its roots in the testing of electronic devices, where an engineer would sit at a lab bench with tools for measurement and manipulation, such as oscilloscopes, multimeters, soldering irons, wire cutters, and so on, and manually verify the correctness of the device under test (DUT). In the context of software or firmware or hardware engineering, a test bench refers to an environment in which the product under development is tested with the aid of software and hardware tools. The suite of testing tools is often designed specifically for the product under test. The software may need to be modified slightly in some cases to work with the test bench but careful coding can ensure that the changes can be undone easily and without introducing bugs. Cooler Master Test Bench v1.0https://eu.coolermaster.com/en/case/case-by-modularity/test-bench-v1/ ( Click on picture for large picture ) Cooler Master Test Bench v1.0 - Product Sheet Cooler Master LAB Test Bench v1.0 Review - Guru3Dcom https://www.guru3d.com/articles-pages/cooler-master-lab-test-bench-v1-review,1.html . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 02By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 03By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 04By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 05By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 06By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 07By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 08By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 09By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Coolone Posted October 24, 2018 Author Share Posted October 24, 2018 (edited) LAN-Party RGB Laptop 2018 Worklog - Part 10By Coolone Sorry but! A new LAN-Party case mod is under development. The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )". For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well. BR Coolone . Edited August 31, 2019 by Coolone Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
