TermudaSquare Posted August 26, 2019 Share Posted August 26, 2019 - I’m Nick with Termuda-Square-Tech and this is my first modding competition and actually my very first ever mod and would love to take my passion for pc’s a step further. I’m very detail oriented and am used to building custom cars, so for this build I wanted every millimeter and every aspect of this build to be modded and serve a purpose but yet something that could be seen as a practical system. My personal rule is, If it doesn’t look good from a inch away I will remake it until it does. - This build interior is based off a military type clean cut feel “stealth” so to call it. A reversal of contrast ! Bright on the outside ,dark on the inside. Pc Spec’s - Coolermaster Mastercase 5 - Coolermaster GPU support bracket - Coolermaster Accessory(top radiator bracket & cover) -Coolermaster vertical GPU mount - Asus z97 sabertooth mark 1/usb3 - 16gb Evga Memory - Intel i7 4790k - Evga RTX 2060 XC Ultra - Barrow RTX 2070 Waterblock - 6 x InWin crown 140mm fan’s - InWin commander III 800watt Desert Fox PSU - EKWB 420mm SE radiator - EKWB 280mm SE radiator - EKWB D5 PWM pump - Gscustomz cable extensions - 2 x Samsung Evo 860 ssd 500GB in Raid - Barrow Reservoir - Barrow pump top - Barrow pump shroud - XSPC 14mm petg - 12 x XSPC 14mm fittings - 2 x Barrow bulkhead fittings - 4 x Barrow 90 degree fittings - Extra sleeving & heat shrink from Gscustomz - Thermaltake Drain fitting (only reason for mix matching components and fittings- there wasn’t much available in matte black) - EKWB Supremacy Evo CPU waterblock - XSPC White fluid - Mayhems non stain yellow dye Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 16, 2019 Author Share Posted September 16, 2019 Posting build logs a bit late, but have been focused on modding. (each reply will be different days of work) - PAINT TIME !! - Figured i would start off with with a color for the case and begin with taking the case apart and prepping for paint and painting it. - Mixed paint from my paint bank and made my own color, Prepped, adhesion promoter, sealer, basecoat, clearcoat, dry time. All in a paint booth with a spray gun. Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 16, 2019 Author Share Posted September 16, 2019 - ACQUIRING THE TOOLS NEEDED!! - There were a few tools I knew I didn’t have. For example a heat gun , rotary tool, acrylic bender, working table for acrylic (ended up making one). Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 17, 2019 Author Share Posted September 17, 2019 - Frame Cutting Time !! - Figured I would need to make some room in the front of this case mastercase 5 for a 420mm radiator from EKWB. - After cutting I made sure to file edges and paint cuts. Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 17, 2019 Author Share Posted September 17, 2019 - Making more room for more cooling !! - Had to cut the frame a bit more to get 280mm radiator from EKWB to fit in the top as well as radiator mounting bracket. - Had to drill rivets for top handle as well in order to install radiator handle has to be re-riveted after radiator install. Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 18, 2019 Author Share Posted September 18, 2019 - Paint hold up !! - Had a little issue, the paint I was using was discontinued !! Luckily through my paint supplier I was able to get the last two cases in the country to finish this project. - Paint arrived, Painted cuts for top radiator. Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 18, 2019 Author Share Posted September 18, 2019 - Reservoir came and it was the wrong size and had to wait for replacement!! -After replacement arrived I decided to make a filler plate and assemble pump-res combo. (actually remade this filler panel 2 times to get it perfect) Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 18, 2019 Author Share Posted September 18, 2019 - Painting Reservoir filler panel & assembly of both - drilling of holes for reservoir mounting as well. ( Added my logo for a little TermudaSquare flare ) Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 18, 2019 Author Share Posted September 18, 2019 - Waterblock’o’clock - Decided to put a Barrow waterblock on my EVGA RTX 2060 XC Ultra ( my first waterblock install ever & nothing to go off of, have not seen other’s liquid cool this card yet ) Link to comment Share on other sites More sharing options...
Devin Posted September 18, 2019 Share Posted September 18, 2019 Looking good bro! Keep up the good work Link to comment Share on other sites More sharing options...
