TermudaSquare Posted September 22, 2019 Author Share Posted September 22, 2019 - Received a amazing package from GSCUSTOMZ!! - A package that was much anticipated by me was custom cables, and thankfully to GSCUSTOMZ I was able to add some extra flare to this build! - I was Lucky enough to receive a set of custom cable cables extension and more sleeving for the fans. And the quality is amazing even the connections are gold!! Link to comment Share on other sites More sharing options...
ad jago Posted September 24, 2019 Share Posted September 24, 2019 waiting for final results Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 24, 2019 Author Share Posted September 24, 2019 4 hours ago, ad jago said: waiting for final results Very soon Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 27, 2019 Author Share Posted September 27, 2019 - Wet sand and polish !! - Decided to wet sand with some 1500 then 2000 grit and polish the side panel with a high rpm buffer and wizards turbo cut compound to give it more of a mirror finish & wet look. (was done before vinyl stickers went on) Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 27, 2019 Author Share Posted September 27, 2019 - Test fitment ! - Decided to do a test fitment and try my hand at bending petg, so that way when I was done with the bends I could make final PSU cover and take it apart and swap it out. Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 27, 2019 Author Share Posted September 27, 2019 - My first PETG bends - For my first bends it actually didn’t go to bad. Ended up having to change with the heat gun temps, but ended up getting it. But little did I know I would have to remake them a second time. (more to come) Link to comment Share on other sites More sharing options...
TermudaSquare Posted September 27, 2019 Author Share Posted September 27, 2019 - A little GPU flare (Mounted with 2 face tape) Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 1, 2019 Author Share Posted October 1, 2019 - The dreaded !!!! - Decided to test fit some of the exterior and ended up having to cut a bit on one piece to get it to fit. Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 1, 2019 Author Share Posted October 1, 2019 - Not what I wanted !! - So my coolant arrived and it was UV yellow which I wasn’t happy with, so Ended up ordering some mayhems yellow dye to add to the xspc white. Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 1, 2019 Author Share Posted October 1, 2019 - The correct color !! - Got my correct dye for coolant, and was more then happy with the color. Link to comment Share on other sites More sharing options...
