Tpbmods Posted August 27, 2019 Share Posted August 27, 2019 Project Maple was designed to be the most Canadian thing imaginable; With its proud Red and white, assortment of maple leafs, and even golden maple syrup pumping thru its waterways. Its an honor to be entering into the 10th Anniversary, and I hope you enjoy Project Maple. Build List: Hardware: Mobo - Asus Maximus X Code - Painted CPU - i5 9600k @ 4.8ghz GPU - MSI 1080ti Aero OC Ram - TeamGroup T-Force Nighthawk 4x8gb 3200mhz SSD - TeamGroup T-Force 240gb PSU - Seasonic focus+ Gold 850w Case - Cooler Master MB530p with plenty of cosmetic mods.Watercooling: CPU - Swiftech Apogee SKF Prestige w/Iris ARGB GPU - Swiftech Komodo 1080ti w/CMWS19 painted backplate. Pump/Res - (Cut down to 170mm) Swiftech Maelstrom 200mm(170mm) d5 w/Iris ARGB Radiators - 3x Swiftech Hydrae GT(120/240/360) Painted Tornado red Compression Fittings - Nanoxia CF 16mm hardline painted Angled and extension Fittings - Swiftech Dual 45 rotary &15mm Drain - Dazmode Darkside Pushvalve Fluid - SwifTech "Mayhem" Dyes in distilled, and 1 drop of Dead WaterMisc: Fans - Swiftech Helix 120mm w/Iris ARGB Controllers - Swiftech Iris ARGB Eco Controllers Cables - Tpbmods created, using Telios Sleeving from Mainframe Customs Cable Combs - Nanoxia CF with splatter paint job Paint - BombingScience.Com Ironlak/Moltow/FlameBlueMB530p Shroud rework - 10hrs Basic shrouds just dont cut it for me, So I set out to make something Ive never seen done before. The 3D logo "Flag" came to me after a first attempt at simply painting on the logo, and it was just bland. Flannel top was always something I wanted to incorporate.MB530p glass replacement - 7hrs I wanted to keep the case as cosmetically stock as possible on the exterior, with the full focus on the internals. Originally I had planned to do the entire front, but 4 hours in, my back was in such agony from being hunched over the saw, I cut a leaf in the bottom right and cleaned it up. Off to paint.The chop chop bits - 6hrs Chop it up, make it fit. Chop it more, paint it! Fitment was one thing I didnt take into consideration with the MB530P. I wanted perfomance, not just appearance!A day of Color - 12hrs So many parts to paint, such un-opportune times to paint. Anyone whos ever tried to paint when its 35c+ out will know, its brutal Your paint will dry before it has a chance to hit the mating surface, and too close will cause big time runs. Painting had to be done first thing in the morning while it was a cool 20c and left to bake outside all day long. And at last, the final stages. - 20hrs After taking a break for LTX19, I came back to work on making my cables, start on some tubes that I had to make while the case was still apart, get to riveting the case all back together, and assembly. I spent the better part of every free moment I had trying to get this looking good. I am not the best at bending tubes freehand(only an insert) But I think it worked out well Link to comment Share on other sites More sharing options...
Tpbmods Posted October 30, 2019 Author Share Posted October 30, 2019 Im guessing people arent a fan of us canucks... Can I get some "EH!'s" in the comments? Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 30, 2019 Share Posted October 30, 2019 Lovely build buddy! It turned out amazing EH !! Absolutely love the Canadian theme. Link to comment Share on other sites More sharing options...
Tpbmods Posted November 24, 2019 Author Share Posted November 24, 2019 Link to comment Share on other sites More sharing options...
