Nicholas Falzone Posted September 27, 2019 Author Share Posted September 27, 2019 (edited) I wanted to refine the shape of the GPU bracket so I first started with a chamfer. I used my router table and chamfer bit to accomplish this: _9182797 by greensabbath911, on Flickr Next, I wanted to make a bracket to help hold the card on: _9182800 by greensabbath911, on Flickr I used some extra veneer covered aluminum for this: _9182801 by greensabbath911, on Flickr I used sandpaper to give the piece a brushed finish. I started with 80 grit and moved up to 220 grit. I will use this for the rest of the small parts: _9182808 by greensabbath911, on Flickr A couple stainless 6-32 screws will keep it in place: _9182809 by greensabbath911, on Flickr Edited October 15, 2019 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 27, 2019 Author Share Posted September 27, 2019 (edited) I wanted to put the case together to see how it was looking. Here is the current state of it assembled: _9192838 by greensabbath911, on Flickr _9192840 by greensabbath911, on Flickr Here we have the front and top panels and some hardware installed: _9192846 by greensabbath911, on Flickr _9192855 by greensabbath911, on Flickr One more view for now, the top/front panels: _9192853 by greensabbath911, on Flickr Edited October 15, 2019 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 27, 2019 Author Share Posted September 27, 2019 (edited) Next up is the case window side panel. For this, i wanted to incorporate brushed aluminum and inset it into an acrylic panel for a clean and cohesive look. I made two models in Fusion 360, one for the acrylic and one for the aluminum. If I was smart I would've done the aluminum first so I could perfect the fitment of it while the acrylic was still on the cnc table but instead I cut the acrylic first: _9152767 by greensabbath911, on Flickr I used a 1/4 inch single flute endmill to machine out the space for the aluminum to sit: Almost done! IMG_6517 by greensabbath911, on Flickr All done! _9152771 by greensabbath911, on Flickr IMG_6520 by greensabbath911, on Flickr I ran a finishing pass to clean everything up. Unfortunately the aluminum didn't fit so I had to remount it to the table in order to recut parts of it. Luckily Fusion 360 is awesome so I could pick which contours I wanted to be cut more. This took a bit of trial and error but eventually i got it to fit quite snuggly. Here's the aluminum part mocked up on the case: IMG_6521 by greensabbath911, on Flickr And here it is finally fitting into the acrylic: IMG_6530 by greensabbath911, on Flickr Mocked up on the case. I need to work on attaching it to the chassis: _9152775 by greensabbath911, on Flickr I aIMG_6461 by greensabbath911, on Flickr l also cut a piece of acrylic for the inside of the front window section: _9192850 by greensabbath911, on Flickr _9192852 by greensabbath911, on Flickr Edited September 27, 2019 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 27, 2019 Author Share Posted September 27, 2019 (edited) The case has an interesting power supply placement and holding solution that I liked so I wanted to incorporate a modified version of it. Here is the contact point transferred to the new motherboard tray. IMG_6462 by greensabbath911, on Flickr I made a little bracket to take up the space between the tray and the power supply carrage: _9182815 by greensabbath911, on Flickr I used sandpaper again to give the piece a brushed look. Here is where it mounts in the case. _9182794 by greensabbath911, on Flickr Soon I will modify the rest of the power supply shroud to more closely match the rest of the case. Edited October 17, 2019 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 27, 2019 Author Share Posted September 27, 2019 As part of the illumination in the case, I will be using ARGB light strips. These will be going in the two sides of the Res/Pump room along woth in the ceiling of the main compartment: Here: _9172779 by greensabbath911, on Flickr And here: _9182791 by greensabbath911, on Flickr I made a model and got to cutting: _9182792 by greensabbath911, on Flickr _9172786 by greensabbath911, on Flickr I needed something to hold the actual strips though so for this I decided to route out a 3mm deep channel in some 1/4 inch acrylic: _1012868 by greensabbath911, on Flickr _1012871 by greensabbath911, on Flickr _1012873 by greensabbath911, on Flickr Perfect fit: _1012874 by greensabbath911, on Flickr _1012877 by greensabbath911, on Flickr Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 28, 2019 Author Share Posted September 28, 2019 I thought about only watercooling the CPU but it made the most sense to watercool everything. I bought a reference Radeon 5700XT and the Ek Vector Waterblock to go with it: _1012859 by greensabbath911, on Flickr After installation: _1012862 by greensabbath911, on Flickr I also made a cover for the side of the case out of a piece of 1mm brushed silver aluminum, courtesy of A.C. Ryan. This covers the edges of the panels and gives the case a more finished look. _1012866 by greensabbath911, on Flickr Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 28, 2019 Author Share Posted September 28, 2019 Back to the feet. I wanted to carve the feet and add some chamfers to them to match the asthetics of the rest of the case. I used a band saw, file, sand paper and a router to do this. Basic design sketched out: _9252885 by greensabbath911, on Flickr _9252886 by greensabbath911, on Flickr _9252887 by greensabbath911, on Flickr _9262897 by greensabbath911, on Flickr The front needed extra attention to match the profile of the front panel: _9252892 by greensabbath911, on Flickr _9252889 by greensabbath911, on Flickr _9252893 by greensabbath911, on Flickr All sanded and ready for finishing: _9262902 by greensabbath911, on Flickr Starting the finishing process: _9262911 by greensabbath911, on Flickr 1 Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 30, 2019 Author Share Posted September 30, 2019 Next I wanted to make a wood accent piece that mimics the design of the case window and acts as a partition in the case. I modified the same file I used on the window to make it deeper and cut a test panel. I then mocked up the test panel in the case: _9252882 by greensabbath911, on Flickr _9242880 by greensabbath911, on Flickr I then milled some Walnut to the approximate size I needed. I paid special attention to the grain to ensure it would look cohesive. Here are the two pieces: _9252883 by greensabbath911, on Flickr Even without glue it is hard to see where each piece ends: _9252884 by greensabbath911, on Flickr After it was glued, I milled it to a bit over 1/2 inch thick and set it up on the wasteboard and got to cutting: _9262895 by greensabbath911, on Flickr _9262909 by greensabbath911, on Flickr All done but before sanding: _9262913 by greensabbath911, on Flickr All sanded and ready for finish: _9262916 by greensabbath911, on Flickr Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 30, 2019 Author Share Posted September 30, 2019 I finished the feet with a few coats of General FInishes Arm-R-Seal and now they are ready to mount to the bottom of the case: _9292949 by greensabbath911, on Flickr _9292950 by greensabbath911, on Flickr Checking the fitment to make sure the reveals are even: _9292952 by greensabbath911, on Flickr _9292953 by greensabbath911, on Flickr _9292955 by greensabbath911, on Flickr _9292956 by greensabbath911, on Flickr I fastened the case feet with four screws into each one. The feet have chamfers to help connect the lines of the case. Next, I turned my attention to the power supply shroud. I like the system that the case uses so I'm going to modify that. _9272921 by greensabbath911, on Flickr I have a bit of veneer aluminum still so I'm going to attach some of that to the shroud and blend it into the rest of the case: _9272918 by greensabbath911, on Flickr I wanted to make sure I had a nice mitered joint so I used some scrap wood to get the angles right: _9272922 by greensabbath911, on Flickr First piece cut, just making sure the fit is right: _9272924 by greensabbath911, on Flickr I cut the pieces close together to ensure the grain would carry over from one piece to the other: _9272929 by greensabbath911, on Flickr _9272930 by greensabbath911, on Flickr _9272931 by greensabbath911, on Flickr I also sanded the edges to give them a brushed look: _9272926 by greensabbath911, on Flickr With the panels attached to the shroud, I could mock it up with the Walnut panel I made last time. It has a couple coats of finish but is not entirely done yet: _9272935 by greensabbath911, on Flickr _9272936 by greensabbath911, on Flickr Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted September 30, 2019 Author Share Posted September 30, 2019 One of the last tasks before I could finally start putting the case together the final time was making the attachment points for the two window panels. Two of these I have previously made but the other two needed to be done using the existing structure of the case. In each corner is a little corner bracket made of steel but it is too thin to put threads in so I wanted to remake it out of aluminum. The piece to be made: _9272938 by greensabbath911, on Flickr I modeled it in Fusion 360 and cut out four of them at the same time: _9292941 by greensabbath911, on Flickr _9292942 by greensabbath911, on Flickr I drilled the screw holes and then made the counter sinks to match the case panels: _9292960 by greensabbath911, on Flickr _9292963 by greensabbath911, on Flickr I threaded the holes and they were good to go: _9292964 by greensabbath911, on Flickr Link to comment Share on other sites More sharing options...
