AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 Metal processing Stainless steel appearance 4mm test. Subsequent nickel plating. Link to comment Share on other sites More sharing options...
AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 (edited) Nickel plating Stainless steel 4mm and aluminum 10mm, 22mm nickel plated finish, the results are very satisfactory. Motherboard bracket Aluminum 10mm CNC. Walnut water tank bracket aluminum 10mm CNC. D5 water pump bracket aluminum 22mm CNC. Case external structure Stainless steel 4mm. Edited December 12, 2019 by AKMod Link to comment Share on other sites More sharing options...
AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 Internal Keep a simple design concept, perspective. The cable will be a big problem, so it took a lot of time here. Link to comment Share on other sites More sharing options...
AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 I made another group wire holders walnut. Link to comment Share on other sites More sharing options...
AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 (edited) Grinding and polishing Because the CNC's knife marks make the surface become matte The water tank section, using sandpaper #400 to start grinding. In order #600 #800 #1000 #1200 #1500 #2000 #3000 #5000 #7000 To the surface is completely transparent. Need a lot of time and patience. After polishing, finally, spray 3 layers of HS grade transparent protective paint to achieve complete sealing in the entire appearance. Edited September 26, 2019 by AK Mod Link to comment Share on other sites More sharing options...
AKMod Posted September 19, 2019 Author Share Posted September 19, 2019 (edited) D5 water pump bracket, using aluminum 22mm CNC, no extra fancy, keep simple design concept. Edited September 19, 2019 by AK Mod Link to comment Share on other sites More sharing options...
AKMod Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) Walnut water tank is about to be completed. Edited September 25, 2019 by AK Mod Link to comment Share on other sites More sharing options...
AKMod Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) Progress Walnut water tank finished. The parts are starting to assemble. Edited September 28, 2019 by AK Mod 2 Link to comment Share on other sites More sharing options...
AKMod Posted September 27, 2019 Author Share Posted September 27, 2019 (edited) Progress New design side panels, let the wood on the back of the tank be exposed. Start installing water pipe design. Edited September 28, 2019 by AK Mod Link to comment Share on other sites More sharing options...
AKMod Posted September 28, 2019 Author Share Posted September 28, 2019 Leather C700M classic four brackets will cover the leather. With the overall black design concept, the bracket is polished and sprayed with matt black paint. Make samples using paper, leave more than 5mm width on the border, subsequent drilling and sewing. 1 Link to comment Share on other sites More sharing options...
