AKMod Posted September 29, 2019 Author Share Posted September 29, 2019 Black nickel plating G.Skill Trident Z Royal's silver and gold are too gorgeous, so I have newly electroplated black nickel, laser engraving Logo processing. Link to comment Share on other sites More sharing options...
AKMod Posted September 29, 2019 Author Share Posted September 29, 2019 Detail GPU bracket Aluminum 10mm CNC to complete the suspension Because the whole interior is a hollow perspective design, so cable management is very difficult, I use the walnut side panel as the groove for the cable and walnut cable comb. I hope the cable looks clean. Top water injection hole design. The controller and part of the wire are planned above the casing. Piping design. Link to comment Share on other sites More sharing options...
AKMod Posted September 30, 2019 Author Share Posted September 30, 2019 Sewing The cut leather is trimmed and polished first. Then start punching, using the puncher and hammer, it takes a lot of time and patience to complete. The last waxed twine begins to be sewn. There is a piece of leather laser carved with the name of the work on it. Link to comment Share on other sites More sharing options...
AKMod Posted October 1, 2019 Author Share Posted October 1, 2019 Sewing The original stitching method results are not very satisfactory, so I have changed from another way to another stitching method. Use original leather, subsequent dyeing. Link to comment Share on other sites More sharing options...
AKMod Posted October 2, 2019 Author Share Posted October 2, 2019 Cable Ince the cable comb is a closed hole, so I need a custom cable to complete it. Includes USB, AC, 4PIN, ARGB cable, etc... Prepare to inject water and cold liquid. Link to comment Share on other sites More sharing options...
AKMod Posted October 2, 2019 Author Share Posted October 2, 2019 Some hardware Cooler Master MASTERFAN SF120M Link to comment Share on other sites More sharing options...
AKMod Posted October 3, 2019 Author Share Posted October 3, 2019 leather Leather sewing is finished, laser engraving Minimalistic words, I finally decided not to dye, I want to make the real effect of the long time and the old effect appear, so apply leather oil after a few days of sun exposure. Link to comment Share on other sites More sharing options...
AKMod Posted October 3, 2019 Author Share Posted October 3, 2019 Light box I pay attention to some details so I make a small light box that can block some light sources. Link to comment Share on other sites More sharing options...
AKMod Posted October 4, 2019 Author Share Posted October 4, 2019 Ready Photos and videos are in preparation. Link to comment Share on other sites More sharing options...
AKMod Posted October 5, 2019 Author Share Posted October 5, 2019 Shooting Coming soon. Link to comment Share on other sites More sharing options...
