louiguiallen@thetechallen.com Posted September 21, 2019 Share Posted September 21, 2019 Hello guys, this is my first time joining the CMWS and hopefully my entry will have a chance to compete on the other contestants. The concept is from the Dark Knight Rises and the mod will be mainly focused in modding the Storm Trooper Case. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 HARDWARE TO USE •Processor: AMD Ryzen 7 2700x •Motherboard: MSI X470 M7 ACK •RAM: Patriot Viper RGB RAM 4x8gb 3200mhz •GPU: ASUS ROG Strix Vega 64 OC •Power Supply: SuperFlower Leadex 1000w Platinum •Storage: Patriot P200 2x SSD's •Cooling: Bykski/Barrow Watercooling/Fans parts provided by Formulamod •Cables: Cablemod Pro mesh Carbon Extension •Case: Cooler Master Storm Trooper Case Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Watercooling parts to use Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Compelte parts to use Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 The case to be use Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Detaching the excess parts of the Case On this part, I'm currently removing the excess parts of the case that will not be use and needs to be removed to fulfill the concept inside and outside the case. And measuring acrylic pannels and acrylic cuts using Makita SJ401 Scroll saw. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Measuring the holes Currently measuring the holes for the passthrough pannel and attaching the radiator and fans and reservoir. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Measuring the holes Pt.2 Currently measuring the holes for the passthrough pannel and attaching the radiator and fans and reservoir and CPU Block. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Measuring the holes Pt.3 Currently measuring the holes for the passthrough pannel and attaching the radiator and fans and reservoir. And this time I will show you the installation of GPU Water block for the Asus Strix Vega64. Link to comment Share on other sites More sharing options...
