louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Measuring the holes Pt.4 This is where the motherboard and GPU will be installed and painting the passthrough panel and attaching some tubes and fittings and other components. On this photos that has been uploaded, as you can see the PSU shroud is already done but I mistakenly forgot to take some photos but it was cut into 2 rectangular shape and i spill an acrylic cement so that they will combine and then i added a 3d carbon sticker. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Finishing the interior Cooling Design, Connecting the RGB light cables to sync, Leak test: This is the part where the cooling system will be installed but not yet 100% stable as there may be some changes depends on the exterior design and to make sure that everything will be look great when the build is finish. Also, as you can see there are some soft tubes passing through the pannel from hard tube that connect simultaneously for the water flow. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Cutting Acrylic for Exterior Design: Will show you guys the process of cutting acrylic and adding designs(Paints, Cuts) for the case's exterior design Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Cutting Acrylic for Exterior Design Pt.2: Will show you guys the process of cutting acrylic and adding designs(Paints, Cuts) for the case's exterior design. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Cutting Acrylic for Exterior Design: Will show you guys the process of cutting acrylic and adding designs(Paints, Cuts) for the case's exterior design. Also, on this part i need to change the color of the acrylic design for a great and strength look that will match the color theme. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted September 21, 2019 Author Share Posted September 21, 2019 Arriving of GPU Backplate: I was actually about to create a backplate for my GPU(Vega 64), I already have cut some acrylics but the sponsor(Formulamod) decided to send their sample and own design to showoff in the build. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted October 10, 2019 Author Share Posted October 10, 2019 Changing PSU: This is a sad news as my Superflower PSU exploded and luckily Silverstone supported me on the other project and they gave me a PSU which i will use to replace the superflower. Link to comment Share on other sites More sharing options...
louiguiallen@thetechallen.com Posted October 10, 2019 Author Share Posted October 10, 2019 Acrylic cut designs Finishing the acrylic cut design for the outside aesthetic. Link to comment Share on other sites More sharing options...
