Coolone Posted October 8, 2019 Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 01By Coolone a. Name of mod: "LAN-Party RGB Case Mod 2020 ( Wood Edition )" b. Description of my case mod: Idea For my "LAN-Party RGB Case Mod 2020 ( Wood Edition)" case mod I will use an Black Aluminum Suitcase and some nice aluminums rods in "mirror like" finish for the Frame Structure combined with some nice wood. I will use some nice RGB components for my Case Mod. I will build it up in an modular way inspired by the modular way the Cooler Master MasterCase Series is made. If I build it up in an modular way the Case Mod will be something like an test bench. Module 1: The Aluminium Suitcase Module 2: The Frame Structure Design with nice wood Module 1 & Module 2 Module 1 + Module 2: Module 2 fits into Module 1 = For safe transportation Module 1 + Module 2: Module 2 fits on top of Module 1 = Test Bench = Portable High-end Gaming Case Mod Aluminium Suitcase TOOLMATE DT-932078 - 460 x 335 x 150 mmhttp://www.silvan.dk/ c. Introducing Pictures: Some introducing pictures of my case modding project. Module 1: The Aluminium Suitcase Module 2: The Frame Structure Design with Motherboard Tray Safe transportation: Module 2 fits into Module 1 Test Bench: Module 2 fits on top of Module 1 d. Test Bench: Some information and pictures about Test Bench. In hardware terms I think Test Bench is most of all used by Overclockers. "Test Bench" - Wikipediahttps://en.wikipedia.org/wiki/Test_bench A test bench or testing workbench is an (often virtual) environment used to verify the correctness or soundness of a design or model, for example, that of a software product. The term has its roots in the testing of electronic devices, where an engineer would sit at a lab bench with tools for measurement and manipulation, such as oscilloscopes, multimeters, soldering irons, wire cutters, and so on, and manually verify the correctness of the device under test (DUT). In the context of software or firmware or hardware engineering, a test bench refers to an environment in which the product under development is tested with the aid of software and hardware tools. The suite of testing tools is often designed specifically for the product under test. The software may need to be modified slightly in some cases to work with the test bench but careful coding can ensure that the changes can be undone easily and without introducing bugs. Cooler Master Test Bench v1.0https://eu.coolermaster.com/en/case/case-by-modularity/test-bench-v1/ ( Click on picture for large picture ) Cooler Master Test Bench v1.0 - Product Sheet Cooler Master LAB Test Bench v1.0 Review - Guru3Dcom https://www.guru3d.com/articles-pages/cooler-master-lab-test-bench-v1-review,1.html . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 02By Coolone e. Hardware: Description of the hardware I have use for my case mod. Motherboard ASRock Fatal1ty B450 Gaming-ITX/achttps://www.asrock.com/mb/AMD/Fatal1ty%20B450%20Gaming-ITXac/index.asp Processor AMD Ryzen™ 7 2700X Desktop Processor, Cores 8, Up to 4.3GHz, Cache 16MB, Socked AM4https://www.amd.com/en/products/cpu/amd-ryzen-7-2700x CPU Cooling AMD Wraith Prism Coolerhttps://www.amd.com/en/technologies/cpu-cooler-solution ( Click on picture for large picture ) Memory ADATA XPG SPECTRIX D60G DDR4 3600MHz 8G *2 Titanium Gray DDR4 LED Dual Channel Series Memory Kit DDR4-3600 PV4-28800 8GB x 2 CL18-20-20 1.35V Tungsten Greyhttps://www.xpg.com/en/feature/606/ Graphics Card Hard Drive Western Digitalhttps://www.westerndigital.com/https://shop.westerndigital.com/en-us/wd SSD M.2 SSD XPG SPECTRIX S40G RGB PCIe Gen3x4 M.2 2280 SSD 256GBhttps://www.xpg.com/en/feature/610/ External SSD Power Supply Seasonic PRIME Ultra 1000 Titanium - Fully Modularhttps://seasonic.com/prime-ultra-titanium/ ( Click on picture for large picture ) Cooling 4 pieces Case Fan 120mm & 4 pieces Case Fan 120mm . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 03By Coolone e. Hardware: Description of the hardware I have use for my case mod. Mouse, Keyboard & Headset Logitech Webcam Monitor AOC AG273QCG 27” curved TN panel, 2560x1440, 165Hz, 1ms, NVIDIA G-SYNC.https://us.aoc.com/en/gaming/products/ag273qcg/ TV-Card Sound Card Microphone HyperX QuadCast™https://www.hyperxgaming.com/us/microphone/quadcast-gaming-microphone . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 04By Coolone f. Build Phase: Pictures of the Build Phase of my case mod. Build Phase 01: Workshop and Tools Build Phase 02: Materials I have used some nice aluminums rods in "mirror like" finish for the Frame Structure combined with some nice wood. Aluminums rods in "mirror like" finish. And some awesome looking floorboards. . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 05By Coolone g. Build Phase: Pictures of the Build Phase of my case mod. Build Phase 03: The Modular Build 01 - Creating it in the Modular Way Module 1: The Aluminium Suitcase Module 2: The Frame Structure Module 1 + Module 2: Module 2 fits into Module 1 = For safe transportation - Ready to Go Module 1 + Module 2: Module 2 fits on top of Module 1 = Test Bench = Portable High-end Gaming Case Mod - Using it like a Test Bench . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 06By Coolone g. Build Phase: Pictures of the Build Phase of my case mod. Build Phase 04: Creating the Frame Structure Design I have used some nice aluminums rods in "mirror like" finish for the Frame Structure combined with some nice wood. Frame Structure with aluminums rods in "mirror like" finish. Awesome looking floorboards for Frame Structure Design. Aluminums rods in "mirror like" finish combined with awesome looking floorboards. Cutting out some more space for the motherboard. The Finished Frame Structure Design . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 07By Coolone g. Build Phase: Pictures of the Build Phase of my case mod. Build Phase 05: Positioning - The PSU in the Frame Structure Build Phase 06: The Modular Build Module 2 fits into Module 1 - Position Down - For safe transportation - Ready to Go Build Phase 07: The Modular Build Module 2 fits on top of Module 1 - Position On Top Of - Using it like a Test Bench - Portable High-end Gaming Case Mod . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 08By Coolone i. Case Mod Finished Inside: Pictures of the inside of the finished case mod. ( Click on picture for large picture ) . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 09By Coolone g. Case Mod Finished Outside: Pictures of the outside of the finished case mod. ( Click on picture for large picture ) ( Click on picture for large picture ) . Link to comment Share on other sites More sharing options...
Coolone Posted October 8, 2019 Author Share Posted October 8, 2019 LAN-Party RGB Case Mod 2020 ( Wood Edition ) Worklog - Part 10By Coolone j. Case Mod Finished Running: Pictures of the running finished case mod. ( Click on picture for large picture ) . Link to comment Share on other sites More sharing options...
