CustomrigsDe Posted December 15, 2020 Share Posted December 15, 2020 I KNOW WHOS WINNING !!!! Link to comment Share on other sites More sharing options...
mayhem modz Posted December 24, 2020 Author Share Posted December 24, 2020 now guys it's getting serious. preparation of the slats that will be positioned inside the side panels. 2mm thick acrylic interspersed with 4mm acrylic painting of the side panels that will hook onto those already made previously preparation of the air outlets that will be positioned at the bottom .. lots of patience.... we assemble everything. the paint is fantastic but will be worn and YAIBA graphics applied Link to comment Share on other sites More sharing options...
mayhem modz Posted December 27, 2020 Author Share Posted December 27, 2020 http://themodzoo.com/forum/uploads/monthly_2019_05/337146839_mayhemmodzFBcopia.thumb.jpg.36b3b8f5ab18175d860c186d78e10afb.jpg Members 14 216 posts Report post Posted 2 minutes ago When a problem is created, the solution is a must, but sometimes it happens that the ripiuego proves to be better than the initial idea, as in this case. The fan of the 200 mm coolermaster takes up a lot of space on the back and therefore I don't know where to fix the controller what remains is right, the cables, so how to do? I lack space so I have to create it ... the ek waterblocks controller (I know it has software problems and its sale has been suspended, so we look forward to the new release ...) I place it on a low, I create a crankcase to emulate the oil pan of the motorcycle, we will apply finishing wear and logos at the end, since it needs specific measures I build it from scratch. I fix everything with glue and finish with fiberglass to consolidate everything. and here it is, primer coats, grouting with metal filler, and when the surface is good enough and smooth anthracite gray coat I will also pierce the lower fairing. he casing will be hooked from below and will contain the controller and the related rgb and fan power cables ... Link to comment Share on other sites More sharing options...
Gusts Posted December 27, 2020 Share Posted December 27, 2020 What a nice job! You're putting a great effort in this mod! Link to comment Share on other sites More sharing options...
mayhem modz Posted December 29, 2020 Author Share Posted December 29, 2020 construction of the partial turbine cover added threaded bolts on the master cooler fan for easy installation. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 4, 2021 Author Share Posted January 4, 2021 realization of the last upper front and back cover panels I do all the tests on paper when everything is in measure for the folds I prepare the acrylic sheet that will be folded, puttyed and fixed to the case with M3 countersunk screws bending the second one, back.. now fixing with fiberglass filler and then for metal bodywork. install thermo applicable threaded bolts further modification. wear application with sandpaper. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 the work was a lot I did not have time to post new photos but here is the work at what point it has come. let's take care of the memories intel i7 9700kf 3.6 ghz 12 mb cache processor installed by PCHUNTER Link to comment Share on other sites More sharing options...
mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 led assembly 200mm master cooler fan Link to comment Share on other sites More sharing options...
mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 360 mm radiator positioning with 6 fans, 3 in and 3 out waterblock ek mounting on INNO3D RTX 2080 TWIN X2 video card waiting for the cable riser cooler master to arrive I do some tests, it fills well ... EK combo positioning on the top Link to comment Share on other sites More sharing options...
mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 processing and conclusion of the lower panel Link to comment Share on other sites More sharing options...
