modLab Posted January 22, 2021 Author Share Posted January 22, 2021 It's update time Finally the last parts were also painted... And the used look is done too, with black paint and an old shirt and I like the way it looks. What do you think hot or not ? Tomorrow I will add better pictures, my old phone has died so unfortunately some photos have been deleted... I also printed the base for the glass bottle 3d and stuck the label on the bottle and glued the connector. In addition, the LED is soldered to add some special effects... On my Instagram profile i have a short video about the light effects. The Vault-Tec logo also gets its lights. I use 3mm LED and a 91 ohm resistor to be able to operate everything with 5 Volt of the power supply. And of course I'll use a nice power supply from Cooler Master. More content soon, so stay tuned Link to comment Share on other sites More sharing options...
modLab Posted January 27, 2021 Author Share Posted January 27, 2021 I started to mod my GPU, first mounting the new frame for the Block. Then I designed a hybrid cooling system so that a fan is attached to the back of the GPU that pulls air forward through a few tubes. After sanding, glueing and bending the tubes i started to paint... The color theme should be like the Fusion Core you know from the game, if not this is one And this is my GPU I also added some LEDs to let it shine... and some red color accents are missing but this is my final design of a GTX 1650... Next update soon. I don't have much time until the deadline ends ... xD Link to comment Share on other sites More sharing options...
modLab Posted January 28, 2021 Author Share Posted January 28, 2021 Hello Community I finished my custom keyboard from looks to software and is ready to mount. To compare before and after the keycaps should also look a bit used And the final product. I also finished painting the Terminal. For the the front, I am using a sponge and one component putty so i imitate the structure like the original. More updates tomorrow ... Link to comment Share on other sites More sharing options...
modLab Posted January 30, 2021 Author Share Posted January 30, 2021 There was a lot of work in the last few days, but finally I'm done ... To cool the CPU and the GPU, I choose an Alphacool Eisbaer Aurora. This is the first time I've been using this pump / block combo. And after installing it on my board I realized that this is a bit close to the GPU ... It was difficult, but I was able to bend a tube to connect the pump to the block. You can see the bended tubes in the next few pictures. All the bends are done, all the lights are installed and tested and I had a lot of trouble putting it in to the Terminal but now i am excited to show you the final results ... This are the final pics of my Projekt: +1 Hacking-Skill required Specs: Board: ASUS ROG STRIX B-360 I-GAMING CPU: Intel Core I5-8400 GPU: Gainward GeForce GTX 1650 Pegasus OC 4GB GDDR6 SSD: Samsung Evo 970 NVMe SSD Ram: G.Skill Trident Z RGB DDR4-3000 16 GB PSU: Cooler Master V750 Gold V2 , 80 Plus Gold Cooling: Block/Pump/: Alphacool Eisbaer Aurora Reservoir: Custom made glass bottle. Radiator: 2x EK-Coolstream PE 240 GPU-Block: EK-VGA Supremacy Fan: 4x Noctua Chromax Low profile Keyboard: DZ60 custom made with Cherry Mx blue switches Mouse: USB-Touchpad Screen: SUNFOUNDER 10.1’’ IPS Monitor Everything is inside and works like a real PC. You can play games like Fallout with it or hack it like a real terminal, but only with Windows as the operating system... xD The specs are not the same as other mods or the best gaming rigs, I understand, but this is all about the terminal itself and manufacturing, the hardware is secondary here. Thank you for for taking the time to read my work log, i wish you a nice weekend and see you in the final Link to comment Share on other sites More sharing options...
modLab Posted February 7, 2021 Author Share Posted February 7, 2021 It was a long way... Link to comment Share on other sites More sharing options...
retro PC mods Posted February 8, 2021 Share Posted February 8, 2021 This is super cool, I love this mod, well done! Link to comment Share on other sites More sharing options...
