AKMod Posted November 5, 2020 Author Share Posted November 5, 2020 (edited) Hardware AORUS Z490 XTREME AORUS GeForce RTX 3080 MASTER 10G AORUS P850W 80+ GOLD Modular AORUS RGB Memory 3200MHz GIGABYTE NVMe SSD 1TB COOLER MASTER MASTERFAN SF120M COOLER MASTER ATX 24 Pin 90° Adapter Standard GL ALPHACOOLEiszapfen Laser Fitting With 4pin Molex Water cooling Bitspower Edited December 16, 2020 by AK Mod 4 Link to comment Share on other sites More sharing options...
Sa mod Posted November 11, 2020 Share Posted November 11, 2020 Wow bro 1 Link to comment Share on other sites More sharing options...
modLab Posted November 11, 2020 Share Posted November 11, 2020 Nice Hardware 1 Link to comment Share on other sites More sharing options...
AKMod Posted November 28, 2020 Author Share Posted November 28, 2020 (edited) Modify 3D drawing file Because the game is not yet on the market, the information is very limited! After the previous file was printed, it was found that there were some problems with the structure, so the new version has been revised, and the part that contains 3D printing needs to be restarted!!! The original metal exoskeleton is a separate part, modified into one body, and then displayed with lines. Edited March 7, 2021 by AKMod 1 Link to comment Share on other sites More sharing options...
AKMod Posted November 28, 2020 Author Share Posted November 28, 2020 (edited) Components I am looking forward to combining these parts together! Military aviation connector for cables. VFD display module. LCD. EL light strip. Inductive switch. Edited November 29, 2020 by AK Mod 4 Link to comment Share on other sites More sharing options...
AKMod Posted December 1, 2020 Author Share Posted December 1, 2020 (edited) Deconstruction table Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing. Repair countertops will include integrated distribution plates. The material will be 75mm, 40mm aluminum pillar, 10mm, 20mm, 30mm aluminum plate and 20mm acrylic. Edited December 1, 2020 by AK Mod 3 Link to comment Share on other sites More sharing options...
AKMod Posted December 3, 2020 Author Share Posted December 3, 2020 3D printing 3D printing and re-drawing is completed, a total of 32 parts are divided and printed. Print with SLA It takes about 12 days to complete it. 1:1 ratio presentation Mantis Blade 770mm Arm connection palm 600mm. 2 Link to comment Share on other sites More sharing options...
AKMod Posted December 5, 2020 Author Share Posted December 5, 2020 Detail Acrylic 5mm light guide RGB strip. 1 Link to comment Share on other sites More sharing options...
AKMod Posted December 6, 2020 Author Share Posted December 6, 2020 Deconstruction table Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing. Check the concept of the countertop design, Will combine with Mantis Blades. 1 Link to comment Share on other sites More sharing options...
AKMod Posted December 10, 2020 Author Share Posted December 10, 2020 Deconstruction table Use 20mm thick acrylic, 850mm X 500mm size as the deconstruction table. Repair countertops will include integrated distribution plates. The construction part needs double-sided processing, and the D5 pump is below. 2 Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
