Jump to content
Cyberpunk 2077 - Deconstruction
AKMod
 Share
Mantis Blades
The restarted 3D printed part is complete!
Began to polish it like crazy.... #240~#600 sandpaper, after finishing, you can spray primer.
1:1 size.
Part of the hand approximately 600mm.
The part of Mantis Blades is approximately 770mm.
Edited by AK Mod
  • Like 4
Link to comment
Test assembly
Polishing took five days to complete it.
Because of the structural bearing problem this time, a hot melt nut was used to strengthen the fixing method.
After testing that there is no problem with the assembly, start the next step and spray the primer.
  • Like 2
Link to comment
Spray paint
First coat of primer spraying.
After spraying, continue to fill the soil and then spray the second primer after polishing.
Btw, because there is no time to finish the spray booth!!!😂
So only simple homework hahaha....
Edited by AK Mod
  • Like 4
Link to comment
Spray paint
After the sanding is completed, the second primer is sprayed.
Then you can spray the metal plating primer.
I am accustomed to stacking the old effects from the inside to the outside to show make real.
Sanding filling primerx2, metal electroplating primer (reducing the bottom layer of the metal exoskeleton), peeling effect paint, metallic white finish paint, scratched aging, acrylic paint aging treatment, transparent protective paint.
Edited by AK Mod
  • Like 2
Link to comment
Distribution plates top cover
The upper cover uses 10mm acrylic processing, and the surrounding corners are processed.
Manual tapping.
Bracket cover
Edited by AK Mod
  • Like 1
Link to comment
Deconstruction table
Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing.
The design progress is roughly 80% completed, the concept of repairing and deconstructing Mantis Blades is getting closer!
  • Like 2
  • Upvote 1
Link to comment
Spray paint
Metal electroplating paint spraying, restore metal texture,
then spray the pearl white finish of the metal exoskeleton, and you can start the aging effect after finishing.
The bracket part is sprayed with metallic iron gray.
Edited by AK Mod
  • Like 3
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
 Share
  • Create New...
Important Information
