R1chard Posted October 14, 2020 Share Posted October 14, 2020 Hi, my name is Ricardo from Argentina and this is my first time in a contest. The project will be based on a triangle. Soon I will update with screenshots of the process. Cheers. Link to comment Share on other sites More sharing options...
R1chard Posted October 15, 2020 Author Share Posted October 15, 2020 I share with you a bit of how the project is going after the last weeks. two sketches and I decided on the second because it felt very wide. Link to comment Share on other sites More sharing options...
R1chard Posted October 15, 2020 Author Share Posted October 15, 2020 then I started the frame construction. the materials are 6 meters of steel bars that were cut and then welded. Link to comment Share on other sites More sharing options...
R1chard Posted October 15, 2020 Author Share Posted October 15, 2020 then it was the turn to match the welds, this work took me partly about ten days due to bad weather Link to comment Share on other sites More sharing options...
R1chard Posted October 15, 2020 Author Share Posted October 15, 2020 the frame construction is ready for now. before and now Link to comment Share on other sites More sharing options...
R1chard Posted October 24, 2020 Author Share Posted October 24, 2020 after rainy days I'm moving a little slow. Link to comment Share on other sites More sharing options...
Italian Extreme Modders Posted October 31, 2020 Share Posted October 31, 2020 it's a really cool design Link to comment Share on other sites More sharing options...
R1chard Posted November 11, 2020 Author Share Posted November 11, 2020 Small update. I started making the base for motherboard and psu, I used the base from my old stainless itx case. Link to comment Share on other sites More sharing options...
R1chard Posted December 4, 2020 Author Share Posted December 4, 2020 Sorry for the update delay. Calculation errors and custom pump and reservoir manufacturing. Link to comment Share on other sites More sharing options...
R1chard Posted December 14, 2020 Author Share Posted December 14, 2020 sorry for the delay due to a few long days, here's an update. Link to comment Share on other sites More sharing options...
