Sa mod Posted October 25, 2020 Share Posted October 25, 2020 wow awesome bro Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 26, 2020 Share Posted October 26, 2020 17 hours ago, Devin said: So I told myself I I didn’t want to do anything crazy for this build as I am pushed for time with 2 other projects but the more I am messing with this case the more possibilities I find. I started working on the inside of the case. While only being able to use photos for reference it make it’s a little more difficult. The bottom part is actually going to be the water distribution block from bitspower and I really likes the angles so I designed a panel to match it on the top then I started thinking what if the motherboard had the same angle. With this case being completely modular it wasn’t hard to test it out. The components are just for testing. Looking good buddy , excited to see this come alive. Link to comment Share on other sites More sharing options...
Derek Wilson Posted October 27, 2020 Share Posted October 27, 2020 Yes !! Can't wait to see more of this mod man glad you have signed up! Link to comment Share on other sites More sharing options...
Devin Posted October 31, 2020 Author Share Posted October 31, 2020 Finally had time to get some painting done today. The printed parts are actually for both this build and a separate build. I was able to get all the printed parts sprayed with automotive clear first which helps fill in the layer lines instead of trying to sand each individual part. I will hopefully be able to get them painted tomorrow. The panels turned out exactly how I wanted, will add some damage effects tomorrow and get them cleared. Also I decided not to cut the front panel and just leave it solid. That’s it for today, back at it tomorrow 2 Link to comment Share on other sites More sharing options...
Devin Posted November 2, 2020 Author Share Posted November 2, 2020 Was able to get most the painting finished this weekend, still a lot to do and still waiting for parts but satisfied with how it’s coming along. 2 Link to comment Share on other sites More sharing options...
TermudaSquare Posted November 11, 2020 Share Posted November 11, 2020 On 11/1/2020 at 7:18 PM, Devin said: Was able to get most the painting finished this weekend, still a lot to do and still waiting for parts but satisfied with how it’s coming along. Damn ! Looking good bro 2 Link to comment Share on other sites More sharing options...
Derek Wilson Posted November 26, 2020 Share Posted November 26, 2020 Looking epic man !! Now this is definitely a TekRed Mod !! Helll yah Link to comment Share on other sites More sharing options...
Devin Posted January 30, 2021 Author Share Posted January 30, 2021 So I had issues with a project that had a prior deadline to this build and didn’t have much time to do everything to this build that I wanted. Then after receiving all the parts I realized the distro I wanted to use for this build was unavailable due to stock, so I had to think quickly and change up the interior design completely. Decided to mount the hardware in the normal position. Link to comment Share on other sites More sharing options...
Devin Posted January 30, 2021 Author Share Posted January 30, 2021 I then wrapped some parts in carbon fiber. Link to comment Share on other sites More sharing options...
Devin Posted January 30, 2021 Author Share Posted January 30, 2021 (edited) Then I thought about how I want to do the loop. Since I was unable to use the c700 distro I decided to use the bitspower cuboid reservoir I had. Honestly I really love the look it has inside this case, it fit perfectly. For the loop I wanted to try something different and do a parallel loop but using black tubing with only have the gpu to cpu tubes clear. The tubes are not painted, all tubes are acrylic tubing from bitspower which offers many colors. After getting the loop together I leak tested it for 30 minutes without any leaks Edited January 30, 2021 by Devin Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
