MA Modified Posted October 31, 2020 Share Posted October 31, 2020 Hi, my name is Mads Alexander i live in Denmark, and I'll be making an innovative PC drawer in beautiful oak wood. This build has been in the design phase for a year now, so I'm very excited to finally start production! Join me on my adventure to make the first fully functioning PC Drawer. Link to comment Share on other sites More sharing options...
MA Modified Posted November 22, 2020 Author Share Posted November 22, 2020 A lot of cool things happening next week! STAY TUNED! - MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted December 5, 2020 Author Share Posted December 5, 2020 About 80 % dont with the woodwork. But the best part is yet to come.. ASSEMBLY! The metal brackets you see under the desk is two "T" steel beams that is helping to remove some of the tension in the wood. The aluminium USB cover is a prototype. Overall im very pleased with the build so far, and looking forward to completing it soon. Feel free to ask any questions you might have. - MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted December 26, 2020 Author Share Posted December 26, 2020 Final sanding, oiling and assembly. The hole rear end of the drawer actually split in two during assembly of the drawer. Managed to glue it back together afterwards tho, so we are all good! 99 % percent done with the woodworking part of the build. Pc installation is going to be so satisfying haha. Merry Christmas & a Happy New Year! - MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted January 12, 2021 Author Share Posted January 12, 2021 Ladies & Gentlemen. Can we make it in time? I sure hope so! Final assembly has happened, and it looks stunning!! Here you so the polycarbonate sheet getting installed and sealed with silicone. The drawer getting assembled, sanded down, sprayed with cleaner to get the wood ready for oil. The oil i use is Rubio Monocoat Pure 2C, which is a two-component hardening oil. Lastly i fitted the support bracket in the right place and made sure everything was running smoothly. Still testing a lot of smaller things before we can begin installing the PC. But there is much more awesome to come! It's the final countdown! MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted January 31, 2021 Author Share Posted January 31, 2021 Hey everyone. EK Water Blocks didn't deliver my fittings and waterblocks on time. . . . So i unfortunately can't make it. I have been working my :) off for months on end, and now I'm a few days delayed because of delivery issues due to the pandemic. If possible, I'll keep working, posting and finishing, even if I'm not in the competition any more. If I'm out, I completely understand! But i really hope i could get some kind of extension. This issue is only because of the pandemic and because deliveries are insane at the moment. What a nightmare haha, I'm so sad. - MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted February 7, 2021 Author Share Posted February 7, 2021 Hello again. As i wrote in my last post, due to covid-19 i got my EK WB parts 3 weeks later than expected.. But the show must go on! I will finish my build!! Aiming to finish the build this week. Link to comment Share on other sites More sharing options...
MA Modified Posted February 12, 2021 Author Share Posted February 12, 2021 Looking good so far Here you se the install of the dustfilter, silicone backcover, GPU support bracket, MB standoffs and passthrough fittings with hidden soft tubing. Link to comment Share on other sites More sharing options...
MA Modified Posted February 18, 2021 Author Share Posted February 18, 2021 Just a few more days left and it's done! Waiting for a few more parts to arrive (delayed by a month due to Covid)... Notice only two diagonal holes connects to the radiator for easy removal and maintenance. Pass through fittings with soft tubing to reposition the hardtubing which is gonna line up with the reservoir. The idea here is to make a sort of reservoir out of hardtubing. It prevents air bubbles from being formed, which would happen if it was a regular cylinder. Front USB cover has been polished and is now installed. Doing a foto shoot on monday so it'll be done by then and final pictures coming. - MA Modified Link to comment Share on other sites More sharing options...
MA Modified Posted February 25, 2021 Author Share Posted February 25, 2021 Well, im way overdue.. But what can you do when parts never arrive. Nevertheless, here it is!!! I'm very proud to present to you The Wooden Desk PC Drawer: - Passiv air intake through the bottom of the drawer. - The bottom is made of 2 layers: 1st layer is where the MB is located on top. 2nd layer has the dustfilter attached and is removable for easy accesse to cable management. - The radiator is an X flow rad which prevents airbubbles from being trapped and making noise. - The Pump/Res combo unit is lowered through the 1st bottom, with just the right height to stay clear of the tabel. - PSU is from CoolerMaster and is flipped on it's head to allow the cable to disappear into the cable room. - On the wall dividing the two rooms i've mounted a GPU support bracket to prevent the card from sagging. - The MB standoffs are 20mm in height to allow cables to flow underneath. Giving the build a clean look and cooling of the MB. - On the back of the drawer i've glued a silicone membrane into the hole for cables to exit. This is to prevent hot air leaving the rad from being sucked back into the system. - In a drawer it's hard to use a reservoir for display purposes, this is because a reservoir mounted horizontally traps air bubbles in the top part. Instead of a "normal reservoir" i've used hard tubing to make my own on the right side of the drawer where no bubble are trapped. It's connected underneath with soft tubing. - 4mm holes are drilled for handmade cable sleeving to exit the bottom and attach seamlessly with the MB, matching the Black/Silver theme. - And ofc. a THICK 60mm Rad. from Alphacool to cool everything down and mitigate the heat. Paired with High performance fans from Noiseblocker. Specs: - Asus 570X -E - Ryzen 7 5800x - Radeon RX 6800 XT - TridentZ Neo 4x8 GB DDR4 3200 Mhz CL-16-18-18-38 - 1 TB NvMe - 2 TB SSD - 3 x Noiseblocker eLoop B12-PS Fans - Cooler Master SFX 650V - Pump/Res combo from Swiftech - Triple Rad. 60mm from Alphacool - Handmade Cabel Sleeving - Water cooling by EK Water Blocks Link to comment Share on other sites More sharing options...
