Jump to content
"Low Rider"
WiP PC Modz
Hi! I am John Patrick Sy Wong of WiP PC Modz from Baguio City, Philippines.  I've been modding PC since 2013 and been joining local competitions and Rig Shows around our place. PC Modding has been my passion and hobby, that until now, I am still learning and developing my skills. I love exploring different techniques and making unique projects/builds. I have joined #CMWS for the past 3 years, and every year, I keep on learning a lot. Gives me that "push" to strive harder and work harder. You may visit my Facebook page (https://www.facebook.com/WONGinPROJECT) and Youtube channel (https://www.youtube.com/c/WiPPCModz) to see some projects and builds that I've done. :)
In this year's competition, I am joining the scratch build category. A brief intro on this project I will be working on is based on some vintage cars, particularly the concept of a Chevy 60's Impala. The project will be named: "Low Rider".
Be sure to stay tuned for updates. Enjoy the mods and good luck to all :) 👍
Link to comment
✴️Part 1 - The Plan✴️
Sorry I have no idea on using drawing softwares so I just made a sketch on how the project would look like. :)  👇
This scratch build is not just a system unit, but a complete set-up with a built-in monitor and speakers on it's trunk at the rear. 👇P1160555.thumb.JPG.daf309cc0cd12379e18bfce2d78e2972.JPG
When you pop the hood, here you can see the hardware located. 👇
And under the chassis, I will be integrating actuators to replicate the hydraulics of the real "Low Rider" :) 👇
Now all you need is a keyboard and mouse, then you're ready to play games or even have a party with the sound system on it's trunk :D 👍
This project is made possible by MSI, Team Group & Cooler Master. Huge thanks to our partners! ❤️
HARDWARE LIST:
MSI MPG Z390 Gaming Pro Carbon AC
MSI MECH RX 5500XT
Team Group T-Force Night Hawk 8gb x 4 (32gb)
Team Group T-Force Delta Max 250gb
Cooler Master MasterLiquid ML240L
Cooler Master MWE Bronze 550w
Li-Heat PCIe Risers
AOC E1670Swu Monitor
Intel Core i5-9400f
P1150690.thumb.jpg.1e1eb073459e20a4a2e7ac50eb0c813b.jpgP1150692.thumb.jpg.ceb43a0409a0d4d041df818b89411e2d.jpg
P1160026.thumb.jpg.c527f6f4a8e00c3acfa906e8e1ae48d4.jpgP1160012.thumb.jpg.3a255d731d420e3d729393dab6beaa8e.jpgP1160025.thumb.jpg.87a1ff4c9d6f8839a0c6cccec4a70137.jpgP1160015.thumb.jpg.16ce037ce347348c439c0e3a5d6e60ea.jpgP1140521.thumb.JPG.adec94ca1b7e05cbab5b45e6223a5622.JPGP1140525.thumb.JPG.bebd09f3d8048441e5adf30e65dab38f.JPGP1140530.thumb.JPG.7073e64d070cf3045c33f50a1d90c511.JPGP1140749.thumb.JPG.21ee2c7ce48a80c62a9448944614f13b.JPG
P1140757.thumb.JPG.5755497c8c7a6f952dff3d400f0e5eb3.JPGP1140753.thumb.JPG.25e611deb2fdefb6f6378f9fd055cc39.JPGP1160592.thumb.JPG.b371795c8224bb40c0e4c8fee9e133b3.JPGP1160596.thumb.JPG.03893463cf7a3beef3d6e12cdb4ce627.JPGP1160608.thumb.JPG.3c91b49aa9e69860ef5f744791b79664.JPGP1160614.thumb.JPG.2d116a71d7e32a249bc36516972cd93f.JPGP1040346.thumb.jpg.51cd986147d7bad8a9fc016941e64f31.jpgP1040372.thumb.jpg.6616ee9538eee8a5f85db544043546bd.jpg
P1040356.thumb.jpg.f9bc260c21d3a5e842440d805131ba08.jpgP1040351.thumb.jpg.61f76c011df3b5d5f2a7abd15022cf4f.jpg
P1040433.thumb.jpg.d3d0bd797e888734bd3bb546d5f0d2ab.jpgP1040471.thumb.jpg.49741e58012b3bd38c99e6744a2747b3.jpg
P1160615.thumb.JPG.00a061450f15c8adb25f93b1b2420615.JPGP1160618.thumb.JPG.8b95859b525aadbb562c31e0b6eb5ef3.JPG
Link to comment
  • 1 month later...
✴️Part 2 - The Chassis ✴️
In building a car, we usually start with the chassis. This marks the beginning of our project.
I ordered a metal sheet with checkered pattern, together with 4 actuators to be used on 4 wheels that I bought on our local hardware store.
Starting from scratch, I made a sample using a folded paper, this is to easily determine the exact measurements and guide me where I should cut out some parts on the metal sheet.
I measured, cut and folded the metal sheet using combination square, triangle ruler, angle grinder, mini hammer and pliers.
424813836_P1160667(000193)2020-12-04-17-49-09.thumb.JPG.e39d6b6c3572c8f02676643f2cf167bd.JPG
401031630_P1160664(006974)2020-12-04-17-52-41.thumb.JPG.5718f913b5916297da1978b1218b641b.JPG
1326122290_P1160667(008490)2020-12-04-17-56-09.thumb.JPG.18daacde763a40be642fbc9c47b3f686.JPG
1049910681_P1160667(007952)2020-12-04-17-55-22.thumb.JPG.1e6cfc8a52e55a67299ff2002c781a7f.JPG
I don't have a welding machine around my work area, so to join the edges together, I used a drill, vise grip (to hold the portion where I made some holes, and a riveter.
164346140_P1160671(000824)2020-12-04-18-04-05.thumb.JPG.70f1cd2f5a59200e5d704d5c50b37e11.JPG
1732271757_P1160673(000526)2020-12-04-18-05-33.thumb.JPG.4ba8595d14223e7680d65760355c9121.JPG
The part where I will install the actuators needs to be reinforced so I used an old case (side panel), folded it to the right size and portion plus some scrap aluminum bar to hold them together.
1534866485_P1160675(000125)2020-12-04-18-12-10.thumb.JPG.5ece0bb4546ae2d8ff1f11a69c1f676f.JPG
1105177639_P1160681(003886)2020-12-04-18-13-39.thumb.JPG.62f25f0ba29202237b3c879ad5d5f6fc.JPG
472681828_P1160683(002322)2020-12-04-18-15-34.thumb.JPG.adb2aac553229630acae97b3043206b3.JPG
776192803_P1160683(006959)2020-12-04-18-16-07.thumb.JPG.82d945b5220b98012078e204addc81e8.JPG
Next is to cut some opening at the back for the placement of the trunk (cover). On the sides for the doors, and on the front, where the radiator of the Cooler Master MasterLiquid 240L will be mounted.
1121188723_P1160695(005774)2020-12-04-18-23-01.thumb.JPG.3ac54b40edaedfc9239cfe41aaa76b09.JPG
813187968_P1160703(001819)2020-12-04-18-27-14.thumb.JPG.9c4fcff4829a1d7205241f9af8074d2e.JPG
Now the metal work is done, it's time to sand and file the chassis to remove the sharp edges, rust and to smoothen the surface.
I wanted this chassis to be chromed out. Actually the shop where I ordered this patterned metal sheet offers a stainless(shinny) variant, but it's way out of the budget. Stainless is very expensive 😅
Chrome dipping is also expensive on automotive shops, so I think of a cheap solution on how to make this chromed, a metallic sticker :D 💡.
I used a lacquer thinner to clean the grease, dirt and particles on the surface so the sticker would stick on it firmly.1591101414_P1160786(003433)2020-12-04-18-55-43.thumb.JPG.b2e54879d512942889bde953388df4b0.JPG
With the help of a heat gun, it made the sticker soft, enough to mold on to the checkered pattern design of the metal sheet.
2002118859_P1160793(000721)2020-12-04-19-01-26.thumb.JPG.80003fd85d84fdf6db84d16c2708b589.JPG
792813763_P1160795(003557)2020-12-04-19-01-56.thumb.JPG.f84c59953740b1323b9890b02c11fffe.JPG
103238844_P1160796(005909)2020-12-04-19-02-46.thumb.JPG.e111e0b1c95dc36ad4c3cbdd7e768812.JPG
Not bad with the result right? :)
1274884566_P1160802(000143)2020-12-04-19-05-29.thumb.JPG.9bd55db4b6cede9812c0d6329472a9a4.JPG
Next is the actuator installation. I cut the mounting hole/brace of the actuator on the bottom part because I want to install it fixed on the chassis without any other movement except up and down only.
1055832938_P1160705(006389)2020-12-04-19-12-41.thumb.JPG.86df146019fb00ecc26be569b3f67c86.JPG
6734065_P1160706(000001)2020-12-04-19-13-49.thumb.JPG.9b6f45e9b99a11bbab23987db43137d6.JPG
Before wrapping the chassis with metallic sticker, I pre-drilled some holes where the actuators will be positioned. (also added few holes on the front and back part of the chassis because I want the hood and the trunk to lift up and down automalically, so a total of 6 pcs of actuators will be installed.)
1226559459_P1160713(000710)2020-12-04-19-16-48.thumb.JPG.edd68fd79598e883494ad645744133aa.JPG
1239612397_P1160713(003824)2020-12-04-19-17-02.thumb.JPG.7e43d0e71e27838dd5cce59e6289b6cb.JPG
1865752273_P1160713(004829)2020-12-04-19-17-38.thumb.JPG.d466ee5f3fe017faca25e127791affa0.JPG
721901558_P1160804(008156)2020-12-04-19-20-49.thumb.JPG.e3cb878ffb03651d3a7a1bcd01686aca.JPG
819424139_P1160807(000772)2020-12-04-19-21-15.thumb.JPG.8e47e4838c506ca64d28f7b5b3d054b6.JPG
Next are the wheels installation. But before that, in order for the actuators not to split later on when this car mod is finished while it goes up and down, we need to make a frame at least to hold them in position, just to be sure on the quality and sturdiness of this project we are making. We don't want this base to be broken later on when we finished installing everything. :D
To make this frame, I used a full threaded rod, S-hook, nuts, stainless tubing, eye bolt and thick cable ties.
Again, because we don't have a welding machine, I improvised on how to join the full threaded rod and an eye bolt together using thick cable ties.
1893945660_P1160840(000600)2020-12-04-20-44-42.thumb.JPG.94fb650e08361f49f451696bdfa2a98d.JPG
1093771336_P1160840(003974)2020-12-04-20-44-57.thumb.JPG.2b935b592cae7200d9a6202f793c6a2c.JPG
1021413010_P1160841(000113)2020-12-04-20-45-21.thumb.JPG.d8127789da622cbad247b68a10ab2194.JPG
I have tested the strength of these by pulling a heavy object, just to make sure everything is in place and it won't pull off easily when forced. The thread of the eye bolt and threaded rod holds each other together specially when it is tightly compressed. Now, the purpose of the stainless tubes is to conceal the ugly look of the threaded rod, plus it serves as a double lock on the cable ties as it adds grip when inserted to the stainless tubes.
1222641406_P1160838(000524)2020-12-04-20-46-41.thumb.JPG.29091ae6d9a406e98bec70b03705b526.JPG
616953719_P1160838(001709)2020-12-04-20-57-27.thumb.JPG.ad35635b533601de7199d57720ff4d99.JPG
Next, the S-hook. Because it is impossible to install the threaded rod directly to the actuator's mounting hole, we needed a "daisy-chain-like" mount so that the actuators can freely move whenever they are activated. I bent the S-hook 90 degrees and locked them to the eye bolt we installed on the threaded rod using this bench vise.
989785805_P1160842(000299)2020-12-04-20-58-32.thumb.JPG.99d7ed2af06a56b0cc5d13e9bf2658d1.JPG
1695349663_P1160842(003479)2020-12-04-20-58-50.thumb.JPG.16bc4ed85c235cf53b33e50050266d11.JPG
346747606_P1170006(000102)2020-12-04-21-08-02.thumb.JPG.bc7651929addb0e1ac493f5fa99f183d.JPG
Now the frame is done, it's time to mount it on the actuators using threaded rod that I cut earlier and nuts.
1170405138_P1170004(000053)2020-12-04-21-06-28.thumb.JPG.41380dd75933d23892a9b109f3051e2b.JPG
1404458892_P1170006(001547)2020-12-04-21-07-33.thumb.JPG.9ecd38d8b2f2f78ced2deb0aeaeb653f.JPG
Now the wheels installation..
1036010154_P1170012(000873)2020-12-04-21-13-54.thumb.JPG.1865d5566bd998aac966caab93fb203a.JPG
763324216_P1170013(002500)2020-12-04-21-14-23.thumb.JPG.f793b8ac95290ab698ed671d72b6a139.JPG
858731320_P1170013(004034)2020-12-04-16-25-32.thumb.JPG.49864c941dde18af411c07803e65912c.JPG
1297710982_P1170013(004184)2020-12-04-16-26-08.thumb.JPG.a277a25092b3e3c8d4783d7683566be0.JPG
Now we are done on the under part, It's time to move on to the actuator's switches. Using acrylic sheet, we made a custom control box, imitating the design of a real hydraulic control box from Low Riders.
705671948_P1170015(002397)2020-12-04-21-20-49.thumb.JPG.a374ea27f24c4841d17a0b94e13d6afc.JPG
2015541861_P1170017(005317)2020-12-04-21-21-32.thumb.JPG.bb1096d2f4cc1743814fced98fc923a4.JPG
1764937275_P1170014(002954)2020-12-04-21-24-21.thumb.JPG.0f6a4c95e9a5af45d5736e8113fc1a99.JPG
2126118418_P1170018(001684)2020-12-04-21-22-01.thumb.JPG.54b807d589ea9aee607d5a426d5e8f15.JPG
By the way, that silver 👆, irregular shaped thing on top of the acrylic are magnets. It will be useful later on when mounting the controller to it's place.
And now some painting and stickers 👇
991097224_P1170022(000269)2020-12-04-21-29-56.thumb.JPG.32baf55712f408ce3fe0750e17b1078b.JPG
1719311624_P1170041(008877)2020-12-04-21-30-30.thumb.JPG.0b07256999660a68e6fd10f0b399f59f.JPG
Wiring setup..
500884954_CMWS20part2(012540)2020-12-04-21-41-09.thumb.JPG.054fa294c9fb9ec0c6a864ecd6b752c9.JPG
574722184_P1170045(000014)2020-12-04-21-54-27.thumb.JPG.767587e6b87e55ed4143996c0e0dccb6.JPG
1777111012_CMWS20part2(013053)2020-12-04-21-41-41.thumb.JPG.5fc93678a578f3cb0a61bb8a2616e471.JPG
687465535_P1170046(000245)2020-12-04-21-55-31.thumb.JPG.83e31d74e3923c8fe61b6307e8cdb85e.JPG
430711269_P1170048(000080)2020-12-04-21-55-59.thumb.JPG.30a14f841b6a69f662860b6d4eeb0d12.JPG
1659300203_P1170048(009057)2020-12-04-21-56-10.thumb.JPG.fdbc707bc9fc95487797f9412652e3a3.JPG
1081814102_P1170052(000043)2020-12-04-21-56-48.thumb.JPG.a2808c6a927154d77a9c95de81189466.JPG
1532572907_P1170073(000075)2020-12-04-21-59-47.thumb.JPG.6a2015f1f953ddf7ffd03365951ea95c.JPG
All wires done. The Switch, USB 3.0 hub and 6 toggle switches all connected. Before finalizing the design, I added another aluminum bar on the mid front part of the chassis. this aluminum bar is installed with piano hinges ( for the hood mounting) and some magnets also to hold the controller we made.
1758673676_P1170071(000099)2020-12-04-22-09-02.thumb.JPG.32684f27a35bd4bd6e89aa2138686103.JPG
38923606_P1170074(000042)2020-12-04-22-09-49.thumb.JPG.231a103e6a30ea1dd20d1ded944a65bf.JPG
Now for the final touch of the controller, we cut a sticker using Silouhette Curio with WiP PC ModZ old english font.
764585160_P1170064(000134)2020-12-04-22-13-48.thumb.JPG.ece3dcc56846a87bc497f569c8237d7f.JPG
1657844607_P1170065(002066)2020-12-04-22-14-08.thumb.JPG.74f6eec68da33ba5af9879e8f8ba219f.JPG
1391225208_P1170066(001665)2020-12-04-22-14-41.thumb.JPG.93922a7fa73caddf265137e0b2918165.JPG
1604358165_P1170073(001970)2020-12-04-22-15-15.thumb.JPG.a0cf7f1e9cd7cd43f0be4542638c563c.JPG
And there goes our controller. :) 👍
Now the Chassis is done, here's some still photos testing out our "Low Rider" 👇😎
1770045794_P1170085(000170)2020-12-04-22-21-16.thumb.JPG.a280973337deded9fbc3657a86af3635.JPG
1753340330_P1170091(000029)2020-12-04-22-23-26.thumb.JPG.5c5d69bfec06357a172caf105080b729.JPG
883411711_P1170091(001070)2020-12-04-22-24-14.thumb.JPG.b5f65c3ac8aeea57d3b539e746ab0a5f.JPG
2042785867_P1170091(001274)2020-12-04-22-23-38.thumb.JPG.5bd5a1e49178d8eb5ce3cecc66f55c04.JPG
1146003612_P1170091(001604)2020-12-04-22-23-47.thumb.JPG.e988a230c58457dd9b0940f317d58ecb.JPG
1259658369_VID_20201203_174647(001940)2020-12-04-22-21-52.thumb.JPG.cc37841b0304c8a8672d0d03d8bf7c9f.JPG
So, this ends our part 2 work log. Be sure to check out the video link to see the live action process of this chassis :)
Link to comment
  • 5 weeks later...
✴️ Part 3 - The Trunk ✴️
On our third part of this project, it's the Trunk part. As we all know, Lowrider cars are mostly customized. Their trunks usually contains LCD monitors, amplifiers and speakers instead of grocery items or baggages. 😅 So we replicate that kind of setup. To begin with, I cut a portion of the metal sheet on the chassis. The purpose of this is to make the back part a little bit lighter.
1241887743_P1170098(002861)2021-01-08-02-08-28.thumb.JPG.8170b547015d4fe9d2600f7a44d9d5fd.JPG
1303884900_P1170100(000119)2021-01-08-02-09-42.thumb.JPG.a053c9eab7f056a23a126e97a591592f.JPG
1359621064_P1170100(000389)2021-01-08-02-10-14.thumb.JPG.27b1b4cc847bc4fd077fe2bdc1ebf609.JPG
Then I made 2 mounting holes for the power cable extensions. One for the power supply, the other one is for the mini amplifier.
1557951215_P1170104(002214)2021-01-08-02-14-04.thumb.JPG.445b7f4e779c3aef755594f991cd1645.JPG
13528818_P1170105(000790)2021-01-08-02-14-40.thumb.JPG.d90000ba575d2de52967ef6efede4895.JPG
283996256_P1170105(002232)2021-01-08-02-15-22.thumb.JPG.be50167a35f6a6d975bdb88ba47daf47.JPG
1155670281_P1170106(008683)2021-01-08-02-15-48.thumb.JPG.16816185e3052353c9273d22572e463a.JPG
1314194152_P1170106(009473)2021-01-08-02-16-22.thumb.JPG.463bab45daec025e7d69dcf53cf827eb.JPG
1526258634_P1170107(002750)2021-01-08-02-16-44.thumb.JPG.851c2c438834d8b9977b94516eb52d19.JPG
The speakers I used are the old, damaged ones lying in our storage. I just managed to repair it, rewired some ran off wires, took off the mini amplifier from it's original case then remade a compact one.
1902381386_P1170147(000089)2021-01-08-02-25-14.thumb.JPG.6977bc6d9cedffbda19c3711354bf399.JPG
642771233_P1170150(000196)2021-01-08-02-32-14.thumb.JPG.37afe00e57efe01e34b6479674175372.JPG
330542852_P1170151(000230)2021-01-08-02-32-46.thumb.JPG.d15f47fcde590aa2a9b0fe37ac91895a.JPG
992426993_P1170151(001859)2021-01-08-02-33-09.thumb.JPG.8399a0c13bf0135dccb32ad053cc50cd.JPG
Next is the mount of the power supply to the chassis. here I used an old PSU bracket then mounted it on the chassis. By the way I am installing here a Cooler Master MWE Bronze 550w power supply.
783532522_P1170152(000047)2021-01-08-02-36-53.thumb.JPG.f3e3976cf51e601c42501fd6884fbaee.JPG
 1546803005_P1170152(001484)2021-01-08-02-37-09.thumb.JPG.51d3eb62dbdea217b99581a8d402b59a.JPG
23266686_P1170152(002084)2021-01-08-02-37-33.thumb.JPG.50f54d54c8fe05b0a1e40ab300f465a9.JPG
Beside the power supply, is the mini amplifier.
1869076407_P1170155(000408)2021-01-08-02-40-09.thumb.JPG.ce60d992eda289949d420c1ba5ac8922.JPG
561187730_P1170155(000614)2021-01-08-02-40-18.thumb.JPG.fcd5720d7d2ba08870c88ab358e6fa81.JPG
782152444_P1170155(001349)2021-01-08-02-40-39.thumb.JPG.e063e05547bc7cdee12d517ad396a84e.JPG
650451829_P1170156(000163)2021-01-08-02-40-57.thumb.JPG.7050a005ce8bdcbcf000d51da9d66e6c.JPG
And then for the covers, I used sintra board. Why sintra board? because it is light weight. :D Plus it's easy to cut, then easy to stick it with velvet cloth. Yes I won't be painting it, I will be covering it with velvet cloth, just like a real car trunk texture. :)
866695978_P1170158(000110)2021-01-08-02-51-19.thumb.JPG.2f73d3f0377939729047a5e9413aea2d.JPG
1264388595_P1170159(003403)2021-01-08-02-52-13.thumb.JPG.f24c5527e49793e06ed250cf23ef48a7.JPG
322695961_P1170159(005894)2021-01-08-02-52-47.thumb.JPG.6e884e2eb2fd77854beff5ef64c141da.JPG
497337288_P1170160(000187)2021-01-08-02-53-07.thumb.JPG.3a005aa30d419d036131fc4a90f878ef.JPG
81248766_P1170162(000226)2021-01-08-02-53-25.thumb.JPG.6566110c8234baafe84fed2e0f93a458.JPG
670872935_P1170165(000196)2021-01-08-02-54-39.thumb.JPG.92da06ae31742b595aae2e28df0ba5ed.JPG
1317160664_P1170164(000394)2021-01-08-03-00-15.thumb.JPG.f675e96deb722aced12e7945b3811a1d.JPG
For the part that I cut earlier on the chassis, I will be covering it with purple acrylic. I also installed rubber door guards on the edges of it.
1234395776_P1170216(001244)2021-01-08-02-58-35.thumb.JPG.0c10e59d543ffdce55fd32cceead5c52.JPG
1909817412_P1170217(001930)2021-01-08-03-05-08.thumb.JPG.d7f9c9708150f992447b6342fecf4648.JPG
2071402304_P1170229(000820)2021-01-08-03-05-53.thumb.JPG.7b4151f6ef627d4781e5060d9483a06d.JPG
1166778264_P1170229(003014)2021-01-08-03-06-03.thumb.JPG.fb300cb9776ef00617565794be7b849e.JPG
Next are the speakers. I also took them off from their original case then made a custom box using also sintra board.
597683145_P1170171(000060)2021-01-08-03-16-12.thumb.JPG.b2bf7cc95eb3452d119e8d03401f866f.JPG
1699794803_P1170171(002069)2021-01-08-03-16-22.thumb.JPG.8e0d72e97122a10222ef0a4f6b6da1b3.JPG
194311743_P1170173(002164)2021-01-08-03-17-10.thumb.JPG.d334846ce5a945f5f5e7eee1145e49e7.JPG
473448385_P1170173(004887)2021-01-08-03-17-21.thumb.JPG.c845122188b67bcdb776fbbe39bcdbf7.JPG
123757338_P1170175(002049)2021-01-08-03-18-14.thumb.JPG.c1384600634ba3c4e59189f308cc862b.JPG
Some Super Glue to bond it...
19288332_P1170177(001183)2021-01-08-03-18-30.thumb.JPG.db84b93c9042f0e53203c0efef112670.JPG
824385915_P1170179(001127)2021-01-08-03-19-37.thumb.JPG.721c3972874712fa51b334fd1ec520ab.JPG
1302579114_P1170180(002294)2021-01-08-03-19-57.thumb.JPG.b1b4e1f09b427d4f91ac15bb1d04191d.JPG
2128210512_P1170188(000125)2021-01-08-03-20-49.thumb.JPG.5b873a966f8e9959dee1267d71a54360.JPG
1307870963_P1170218(000075)2021-01-08-03-22-00.thumb.JPG.ed5db4626bdaafa96523feda0e7fd51f.JPG
373971089_P1170220(000252)2021-01-08-03-22-27.thumb.JPG.807535806ed19b740945ed94220c7a97.JPG
461827174_P1170222(001332)2021-01-08-03-23-01.thumb.JPG.9f85c5fd1159a9de61fcc0e02d58957f.JPG
943627764_P1170222(001782)2021-01-08-03-23-10.thumb.JPG.450b09e5031e0dd74e341c03d35d8856.JPG
After cutting and shaping the sintra boards, time to cover them with velvet cloth. I used rugby to stick the cloth. :) Color purple to match the color of the exterior, as I am planning to paint my low rider purple.
1685551249_P1170190(001236)2021-01-08-03-33-42.thumb.JPG.b2c7e1093d376719fffa9d0f12a63ed4.JPG
502182168_P1170230(001842)2021-01-08-03-34-25.thumb.JPG.e83f97d3144ef1d43d97d60379f519be.JPG
1296590275_P1170230(003299)2021-01-08-03-34-35.thumb.JPG.4f1ca37162caeba84289e34b892464c9.JPG
929742274_P1170231(000269)2021-01-08-03-34-57.thumb.JPG.a36a67cf964542c2a2a09a4a2a2e5b82.JPG
313287354_P1170231(003149)2021-01-08-03-35-15.thumb.JPG.d1232587268f153517a6d6fd374bccc0.JPG
399010776_P1170232(003328)2021-01-08-03-35-30.thumb.JPG.c60004ee7bfa002f01ff6caccc1c3cdc.JPG
1509935410_P1170233(002181)2021-01-08-03-35-49.thumb.JPG.0e66e7110ce7bbe3a0fbef9a1c86fb56.JPG
2099845479_P1170181(003442)2021-01-08-03-38-36.thumb.JPG.a72756d73950f54ecce03df9a1ac3b0e.JPG
320598633_P1170181(009104)2021-01-08-03-38-53.thumb.JPG.4b7048d8e5331a5ad0b13c122593d9db.JPG
1473091468_P1170183(001206)2021-01-08-03-39-24.thumb.JPG.bf7990632cd1ddfebdfc9e11323690d9.JPG
640566531_P1170187(000085)2021-01-08-03-39-55.thumb.JPG.6972dfa1eebd923344cf9c9da85be0fe.JPG
1327705531_P1170224(000182)2021-01-08-03-40-22.thumb.JPG.0ab8ee1e3a5b9d7aaeeb2e1ba7145114.JPG
1670254352_P1170225(002937)2021-01-08-03-41-09.thumb.JPG.ba806b3395987f4d82399b1976f87ccb.JPG
1499344054_P1170226(004257)2021-01-08-03-41-51.thumb.JPG.61341265762139dc251d6563d620b5e9.JPG
Before installing the speakers, I reinforced the inside of the sintra board/boxes with body filler/putty.
913986930_P1170191(000063)2021-01-08-03-47-14.thumb.JPG.63dfa3497da6bcafc5f73c3f8577cff5.JPG
510381879_P1170191(008294)2021-01-08-03-47-28.thumb.JPG.a4b6a2e9b0d06085754ccc2680c62c6e.JPG
353622758_P1170192(006918)2021-01-08-03-48-11.thumb.JPG.592dc282b522a6a8197d4dc49a97c09d.JPG
Then repainted the speakers to matte black..
1247460573_P1170195(000162)2021-01-08-03-57-48.thumb.JPG.e89f3b8d950b488feebc3ee6a1ab50f4.JPG
When the body filler has cured and the paint has dried up, it's time to rewire and install the speakers.
983916137_P1170204(001650)2021-01-08-03-58-27.thumb.JPG.8ccef3eb27ec087889ea27270d7be783.JPG
858383196_P1170205(007782)2021-01-08-03-58-50.thumb.JPG.3de58ecf401786211d1e2f2556d6f72d.JPG
1686437472_P1170207(000441)2021-01-08-04-00-50.thumb.JPG.6c28fad78a416d33f322d22411b503c3.JPG
2026171576_P1170208(000334)2021-01-08-04-01-18.thumb.JPG.915e6963f0a4693f72b3bd0e19d711c5.JPG
1961099700_P1170209(000316)2021-01-08-04-01-49.thumb.JPG.709691292416810dc94abfa3bf297784.JPG
1933326343_P1170210(000959)2021-01-08-04-02-35.thumb.JPG.56342352ca299ab13d3e1780d832bd69.JPG
415965243_P1170211(000075)2021-01-08-04-02-50.thumb.JPG.5c6fd5413b2dcb4ef5a9ef226bc640cb.JPG
1129054397_P1170212(001346)2021-01-08-04-03-14.thumb.JPG.b794bcdda59a7ca7d610ab08db317bb6.JPG
1234214461_P1170213(003099)2021-01-08-04-04-07.thumb.JPG.351092d1225d5b5a98ded621732cd395.JPG
507997783_P1170228(000058)2021-01-08-04-05-45.thumb.JPG.9eff8fa944cb83eea3beb486ef7e8581.JPG
Now all the speaker boxes are done..
1385593981_P1170234(000133)2021-01-08-04-13-45.thumb.JPG.403a4555df7fbf04d79213d6a07b3e7b.JPG
634216721_P1170235(000059)2021-01-08-04-13-58.thumb.JPG.2cef25b884f833e5ff5b81ae321e5a6d.JPG
It's time to install them all to the trunk :)
1756238506_P1170236(004355)2021-01-08-04-15-49.thumb.JPG.459360136ec5d1f0c7c1143a7957ae64.JPG
1377909814_P1170237(000811)2021-01-08-04-16-18.thumb.JPG.e4ced6815e9897cf9c5dca0d9831b8b8.JPG
1761321472_P1170237(002082)2021-01-08-04-16-32.thumb.JPG.b7ea3028c830307287587924e0079431.JPG
621720215_P1170237(006207)2021-01-08-04-16-52.thumb.JPG.fd382bc974d51fe5ba56dc4d72e814eb.JPG
1813790780_P1170238(001452)2021-01-08-04-17-37.thumb.JPG.f1d6391b7c850ffdfd273d820b357ae4.JPG
1354499225_P1170239(000463)2021-01-08-04-17-55.thumb.JPG.66ac28a117bf68d006ee7bc36d1a8048.JPG
1955533596_P1170239(000732)2021-01-08-04-18-11.thumb.JPG.cc9f727b5fe39a9e96e1bb939f12f930.JPG
Lastly, time to fix the cover on top of the power supply and the mini amplifier..
345242908_P1170240(003213)2021-01-08-04-22-48.thumb.JPG.e049a4d8fd1cb703f3ef626d8c6c2180.JPG
1262582731_P1170241(002039)2021-01-08-04-23-47.thumb.JPG.891b24f3a5c9f3dc94dc5db7480cbd76.JPG
1102518494_P1170242(000472)2021-01-08-04-24-33.thumb.JPG.095c39dbd2a96446bd71cd0d65c2396e.JPG
1287077692_P1170242(001767)2021-01-08-04-24-45.thumb.JPG.2384e62a2534c708ba6559c4ac74e936.JPG
Clear acrylic for a window to show off the power supply :)
2009830708_P1170243(000554)2021-01-08-04-25-16.thumb.JPG.44e31d3aa2a0d006a1d293c5e5220a5f.JPG
1832608206_P1170243(001092)2021-01-08-04-25-29.thumb.JPG.bbba3f626366fc5f632ae8db1aebc6fd.JPG
1542349273_P1170243(001662)2021-01-08-04-25-47.thumb.JPG.4269e91e2c940b912d7be14947b401e6.JPG
704454519_P1170244(000163)2021-01-08-04-26-06.thumb.JPG.27628a169cf4df503c41abd74b87ac25.JPG
Alright we're done on the trunk part! :)
Check out also the video link embedded above for a time lapse on how this trunk was finished. :) See you guys on part 4! ;)
Link to comment
✴️ Part 4 - The Engine ✴️
A car won't run when there is no engine. Same goes with computers, so for the part 4 of our project, we have installed all the hardware that will boot up our Low Rider.. But before we start assembling the components, we made some covers "under the hood", this is to avoid any contact on the metal parts of the chassis to our precious components that may cause ground/damage. Starting off with this divider that serves as "dashboard" on the interior part. :)
808175909_P1170270(000212)2021-01-08-17-28-57.thumb.JPG.45013e6ecf67c604876ce3ce2331082c.JPG
1054560604_P1170272(000029)2021-01-08-17-30-27.thumb.JPG.754119912d496793b0beb0af68fd6e71.JPG
115189355_P1170273(000228)2021-01-08-17-33-41.thumb.JPG.469b7381e879734271b07720e7773c0e.JPG
Bent it using heat gun, then cut parts where cables will pass through using rotary tool.
1390599551_P1170279(001416)2021-01-08-17-34-15.thumb.JPG.4634efe2e10a5792998c7750a89907ff.JPG
Painted it with matte black..
683116777_P1170280(000149)2021-01-08-17-35-26.thumb.JPG.eb81cb44fd761c19baea4e9807d6ea9b.JPG
Then covered the other side with white leather..
1506144903_P1170569(001191)2021-01-08-17-43-11.thumb.JPG.47f148cfa69137487ee2338d5d3d835d.JPG
1177054797_P1170281(000264)2021-01-08-17-43-48.thumb.JPG.4721a9ba23cc697e7128b9726106e24f.JPG
367067289_P1170281(002189)2021-01-08-17-44-25.thumb.JPG.453775e9a1fd8b1f9cd3853408cd14fb.JPG
2130750535_P1170285(001125)2021-01-08-17-45-25.thumb.JPG.1a95655d0c3bcc82281650510fcff2a6.JPG
1787869992_P1170285(005727)2021-01-08-17-46-34.thumb.JPG.3ac796fef11d95cc9141ed2a5e0f7a9f.JPG
Installed it with blind rivets..
846282806_P1170286(000837)2021-01-08-17-48-00.thumb.JPG.342d5a397fbc2e54a420af2dbd609154.JPG
343282774_P1170286(002907)2021-01-08-17-48-27.thumb.JPG.6d27254b9f4b54a54ea766760ac88916.JPG
1005030089_P1170290(001175)2021-01-08-17-49-36.thumb.JPG.9ef8a1abb1f2f2086cced91ed0e765be.JPG
1598255627_P1170290(001717)2021-01-08-17-50-20.thumb.JPG.9c4cdef231ce72bcfc0dbde274726024.JPG
Next are the sides. Again I used sintra board. Then instead of painting it, I used vinyl carbon stickers. This is to match the design of the motherboard.
1927718799_P1170293(000223)2021-01-08-17-55-25.thumb.JPG.87a94dd955d283804b346af4e9f12e16.JPG
744065531_P1170293(000803)2021-01-08-17-54-59.thumb.JPG.6247cd77501062057437fddc52a531ef.JPG
109963909_P1170293(004362)2021-01-08-17-55-34.thumb.JPG.ec0da53ab595de1c0350963d30e62dba.JPG
410319429_P1170295(000045)2021-01-08-17-55-56.thumb.JPG.0b0e0f02cd36cbf846369201853e5146.JPG
1087883490_P1170295(000222)2021-01-08-17-56-11.thumb.JPG.c2928c4a5cbbe5a919eba50c7eecc264.JPG
1844645807_P1170295(001047)2021-01-08-17-56-23.thumb.JPG.6ebe643af7b6ea02fdf15f0dc1a42b6f.JPG
1026815199_P1170297(000302)2021-01-08-17-57-35.thumb.JPG.6381f91e8baf03926422452245b2d9e0.JPG
1691674745_P1170297(001934)2021-01-08-17-57-45.thumb.JPG.e483e66319dd9837cb4c19a04935f41e.JPG
1189502173_P1170298(000330)2021-01-08-17-58-05.thumb.JPG.69109ca3c949da9c21a307fd9a3181e6.JPG
2053723040_P1170298(000599)2021-01-08-17-58-13.thumb.JPG.d52f8fd22338ca320160a7f3c2dc1f3a.JPG
130502076_P1170298(001094)2021-01-08-17-58-22.thumb.JPG.a697b92add47552cebe3cef4901b3210.JPG
1995465668_P1170535(000556)2021-01-08-17-58-54.thumb.JPG.ec44b5f440863f05f7901b63e4b7bedb.JPG
255492420_P1170536(000526)2021-01-08-17-59-20.thumb.JPG.ba9c99fa7ead2e2220ee5c78244efc0b.JPG
Next is the motherboard tray. Here I used 3mm thickness clear acrylic.
542734478_P1170537(000417)2021-01-08-18-02-42-Copy.thumb.JPG.e1aa673fa907acc715b40ca51f636403.JPG
1480585616_P1170538(000264)2021-01-08-18-02-54-Copy.thumb.JPG.82dedfb2da43527887bacc19927d0860.JPG
1911122111_P1170540(000383)2021-01-08-18-04-10.thumb.JPG.a73e00c8afdd178d8662e738430fe698.JPG
1712435142_P1170540(000464)2021-01-08-18-04-18.thumb.JPG.e9618f966bc3768ca298f949d0e37fa1.JPG
854117125_P1170542(001274)2021-01-08-18-05-26.thumb.JPG.1c6bcddf70bc96bde7110c63233729df.JPG
Test fitting the MSI MPG Z390 Gaming Pro Carbon AC.
665603733_P1170542(001501)2021-01-08-18-08-14.thumb.JPG.3f36ae5cef52cd14c789dc0beaa6e574.JPG
Installing the intel core i5 9400f...
1012900473_P1160622(000600)2021-01-08-18-11-07.thumb.JPG.01ef1a99d7ac053e75f0c542c10bf98e.JPG
Affixing the motherboard/motherboard tray "under the hood"..
278715729_P1170544(000302)2021-01-08-18-13-13.thumb.JPG.38aeb48a75628eddfccab3fe2c779001.JPG
697849382_P1170543(001240)2021-01-08-18-14-14.thumb.JPG.416a2e724b540cd3ae8198a09bba94f1.JPG
1906863194_P1170546(000072)2021-01-08-18-15-34.thumb.JPG.641ef9a2f7622da6cd2e48cae8f76fa6.JPG
Next, the Team Group T-Force Night Hawk ram installation..
33144442_P1160628(000961)2021-01-08-18-19-28.thumb.JPG.1411765b6d458955deb36858b8af698b.JPG
1362972818_P1160628(001770)2021-01-08-18-19-53.thumb.JPG.4fd4b41299d383104656e50675e3d8f5.JPG
For the cooler, I modified the Cooler Master MasterLiquid ML240L. Changed the tubes to silver color then reduced the length to make it exact where I will be mounting it.
(video worklog on how I changed the tubes is embedded above :) )
Installation of the cpu block, fans and mounting of radiator 👇
624822403_P1170547(000315)2021-01-08-18-28-14.thumb.JPG.d4024c60c0cd183c346374047359bb91.JPG
760623102_P1170548(000178)2021-01-08-18-29-11.thumb.JPG.6ee8c6bfe7b8ceead473f27768522a5e.JPG
821485594_P1170549(000636)2021-01-08-18-30-16.thumb.JPG.131954dde372de259ef69cc3e273b4c6.JPG
398918423_P1170549(002264)2021-01-08-18-30-37.thumb.JPG.07d27de01c22e6fd2c6ba52cbbf7875f.JPG
103377151_P1170550(001066)2021-01-08-18-33-47.thumb.JPG.62cb7ad248d3a527176f34c0dbd6a6c3.JPG
By the way, before I fixed everything on its position, I connected a 12v RGB connector going outside just in case I would install led strips later on on the exterior part of the car. :)
601471200_P1170551(000059)2021-01-08-18-37-16.thumb.JPG.b97d1592c102183e4a5937e886e5339b.JPG
886114462_P1170551(001394)2021-01-08-18-37-35.thumb.JPG.5b4a471de8534ad8dae75f9d8115728b.JPG
Next, the MSI Mech RX 5500XT installation.. Not the regular mounting on the PCIe slot, I used a Li-Heat PCIe Riser so I can place the GPU turning upside down, with the PCIe on top so we can make and install a custom shroud/cover, showing off our sponsors. :)  Before that, I removed the bracket that is installed on the GPU to save up some space.
798921044_P1170552(000638)2021-01-08-19-28-32.thumb.JPG.c755cca1d655e361cbb49996748e8ff6.JPG
897375292_P1170553(000097)2021-01-08-19-28-50.thumb.JPG.49e7607a3d056dd1c2189f33298eaff9.JPG
1685779761_P1170553(000179)2021-01-08-19-28-59.thumb.JPG.18db41b25dc64f8238e713a8b85ebeb2.JPG
1211828434_P1170554(000207)2021-01-08-19-30-29.thumb.JPG.0bede18433428b1d27a775a86bfc5bdb.JPG
977326736_P1170554(000777)2021-01-08-19-30-48.thumb.JPG.6e5c2c8b984bd8823d0b4a38d1fd8ac7.JPG
526810020_P1170554(001257)2021-01-08-19-31-09.thumb.JPG.27860448bb2149476702421f94f30c90.JPG
1520673683_P1170554(001782)2021-01-08-19-31-22.thumb.JPG.05efdc5d519fd521227d33c182b54cf2.JPG
77176107_P1170555(000062)2021-01-08-19-32-31.thumb.JPG.e2b3bef880c4766a4cc060be6b9b2e0d.JPG
For the shroud/cover of the PCIe riser, I bent acrylic, cut and painted it to purple..
1697728687_P1170789(000123)2021-01-08-19-35-27.thumb.JPG.adb8fb88c646931ccaf6673e2c01df5f.JPG
641952047_P1170790(003752)2021-01-08-19-36-09.thumb.JPG.69bf763b0be8f231cdf1fdcf7e0db8ca.JPG
1646215843_P1170790(006792)2021-01-08-19-36-36.thumb.JPG.dbd232cef1faf49a4446fd1a27976f0e.JPG
292013755_P1170793(000042)2021-01-08-19-37-21.thumb.JPG.afd58100a00acc6852f7dfa504a484e6.JPG
I Used Silhouette Curio for the logo and letterings..
1664279022_P1170795(000080)2021-01-08-19-39-22.thumb.JPG.8096a5e982f0e7eaa3918153888dbce9.JPG
1257681490_P1170796(000105)2021-01-08-19-39-36.thumb.JPG.32a69c37c510408d1360f6480a76ec60.JPG
1124694372_P1170797(000299)2021-01-08-19-40-12.thumb.JPG.a7278cb8794708a11b8ec26af8dc4b40.JPG
1775554173_P1170798(003158)2021-01-08-19-40-51.thumb.JPG.d3c2eba3562f4cd96b83f41d5b639f39.JPG
1111885247_P1170800(000250)2021-01-08-19-41-39.thumb.JPG.97066506fb9c61153bc0d766d28c6fcf.JPG
758796168_P1170800(001289)2021-01-08-19-41-48.thumb.JPG.28f2815b19fe23268b8b9e0a8af3441b.JPG
2053079479_P1170801(000443)2021-01-08-19-42-12.thumb.JPG.b50ee57abdfd03d21ad6c5f57d048a9e.JPG
Okay so everything is installed. here are some snap shots of the "Engine" 👇
If you are tired scrolling and reading, I made a time lapse video that is embedded above. :D keep modding! Do what you love to do and see you guys on part 5! :)
Link to comment
✴️ Part 5 - The Interior ✴️
Alright so we're done with the chassis, the trunk and the engine, here in part 5, we'll be doing the interior of our low rider! :)
First off, the installation of the Team Group T-Force Delta Max SSD on the "dashboard".
1705872551_P1170562(000260)2021-01-09-03-21-06.thumb.JPG.9a4ed6c29f4eaef87d73fb35bb5e9a4d.JPG
400157855_P1170562(001184)2021-01-09-03-21-45.thumb.JPG.7548c0695b3d12f6c81f47c07613e622.JPG
2036328868_P1170562(002024)2021-01-09-03-22-15.thumb.JPG.84c0cb258f98acb123288565fa1c1400.JPG
Then some managing of cables before we cover it..
455512714_P1170566(000959)2021-01-09-03-27-30.thumb.JPG.4ced62248bbce54225ed9c798726c5e3.JPG
1932267509_P1170566(002294)2021-01-09-03-27-47.thumb.JPG.68db80d61535673bf406c29b7a12e1dd.JPG
10123924_P1170567(000014)2021-01-09-03-28-16.thumb.JPG.65ca8eca43459576fbf59b22f49c3157.JPG
1211033317_P1170567(000104)2021-01-09-03-28-26.thumb.JPG.7ffa7758169a4fa0a2964ffe6c45501a.JPG
Next, the wrapping of the edges with white leather.. I still used rugby to stick the leather on to the surface.
1823743794_P1170569(001783)2021-01-09-03-32-59.thumb.JPG.9567e38e811d150d21c99bbec7fb4b3e.JPG
828551650_P1170569(002009)2021-01-09-03-33-04.thumb.JPG.c22d34d5cc6f66539321e1c46f6a3d59.JPG
953267823_P1170570(000108)2021-01-09-03-33-17.thumb.JPG.16091bcc5c7c15cf06fa6516f902122b.JPG
76801546_P1170570(001724)2021-01-09-03-33-29.thumb.JPG.978826fb836ab114cdec4ed99dbb9cc4.JPG
2039740701_P1170571(001469)2021-01-09-03-33-51.thumb.JPG.db013e1f7b1dfcd7d4ecc635d9634b94.JPG
1381729847_P1170572(001242)2021-01-09-03-34-17.thumb.JPG.9812d8ecfb4d1be4ae82262ec3d85a88.JPG
2036362739_P1170580(000111)2021-01-09-03-37-06.thumb.JPG.86e3f6746e461671d68189c2844b18b1.JPG
Also I used chrome door guards, for added design/accent, plus it helps hold the leather on hard to stick corners.
1814231976_P1170574(000540)2021-01-09-03-34-42.thumb.JPG.cc4e53bd8bef33a0a5f629347be33a0f.JPG
1598204845_P1170575(001255)2021-01-09-03-35-14.thumb.JPG.252331b7c4ea13904aa424971550b35b.JPG
747464942_P1170575(002009)2021-01-09-03-35-28.thumb.JPG.14c2f7bd5c6565756bc54283d70e8deb.JPG
1629841223_P1170577(000215)2021-01-09-03-36-04.thumb.JPG.d2093f28731a18d78eb16873be41665b.JPG
184896207_P1170577(000777)2021-01-09-03-36-14.thumb.JPG.76aa2e24f90a484453e901784cdee1f3.JPG
1638212859_P1170577(006192)2021-01-09-03-36-33.thumb.JPG.b5f6f6444c2be6efa3f1ddcdef853106.JPG
2130958301_P1170578(000072)2021-01-09-03-36-52.thumb.JPG.f9d3ac89bde7b7b1b3b7cc86fd951eb3.JPG
1670585130_P1170581(000175)2021-01-09-03-37-28.thumb.JPG.84387f47c7df8a853402c4acc8f6a9f7.JPG
596689903_P1170581(000824)2021-01-09-03-37-34.thumb.JPG.0d0f9c72079287df3843a7f9a13d661d.JPG
1342957437_P1170581(001754)2021-01-09-03-37-48.thumb.JPG.7800f9dbfbbfb13747219f69a0f40149.JPG
For the floor matting, I still used sintra board and covered it with purple velvet cloth to match the design/color of the trunk. Plus it adds contrast to the white leather.
648348503_P1170582(000160)2021-01-09-03-45-34.thumb.JPG.6e50e5f8f74ae8204f5b1282a7b0587c.JPG
1426719880_P1170582(001784)2021-01-09-03-45-47.thumb.JPG.3cd72c810def685746a4be2e47a8b499.JPG
1127945637_P1170583(000585)2021-01-09-03-45-59.thumb.JPG.1a3bfdc109255f2157ca2c5e4a4871cb.JPG
490433054_P1170583(001437)2021-01-09-03-46-06.thumb.JPG.822e8fa706390b18266e75c88268c2ac.JPG
191256194_P1170584(000183)2021-01-09-03-46-20.thumb.JPG.26c1e92137e7ef6c09118649ec9739aa.JPG
774096380_P1170584(000357)2021-01-09-03-46-26.thumb.JPG.cc3f51a5a1e147d1496ed1945f1f5330.JPG
Next are the car seats. Still I'm using sintra board to make the frame of the seats, then covered it with white leather. I used staples as an alternative for gun tacker to attach the leather.
1447614504_P1170586(000621)2021-01-09-03-51-40.thumb.JPG.61cfa632a24ddbd77fb4ee18758dffee.JPG
1094994742_P1170587(002192)2021-01-09-03-51-57.thumb.JPG.804c43c27ba4ad4d6166476833ef83f5.JPG
741160001_P1170587(003582)2021-01-09-03-52-04.thumb.JPG.cdec6e268db750933f2dd0d45e75cd6d.JPG
1642680959_P1170589(000614)2021-01-09-03-52-26.thumb.JPG.37ade8adaa39979c27e71d93aec9f9b2.JPG
1767117330_P1170591(000166)2021-01-09-03-52-59.thumb.JPG.c8f8681da3f339ef3cc80eaa8936e6a9.JPG
2111152424_P1170592(000275)2021-01-09-03-53-47.thumb.JPG.d945153fe5d202aafb6a94677329ffdd.JPG
1519772895_P1170593(000178)2021-01-09-03-54-05.thumb.JPG.ae8edb87bf10301642ae2739a9f80716.JPG
137827406_P1170593(000764)2021-01-09-03-54-28.thumb.JPG.92080f0061baeac2b4d84098abbbbefe.JPG
1721378999_P1170593(007754)2021-01-09-03-55-01.thumb.JPG.6c79eb664a5f0a3874b0a09dd8c53da2.JPG
1755168771_P1170593(009693)2021-01-09-03-55-38.thumb.JPG.c393ae4b3b8df9544a3a6d39516cc8e6.JPG
28640102_P1170594(003627)2021-01-09-03-56-51.thumb.JPG.6ca289573ed1f45c4c73f0833865f497.JPG
1778422198_P1170594(004985)2021-01-09-03-57-22.thumb.JPG.f60777f8a6f614c52eee2c7dd24949c4.JPG
357259340_P1170594(005085)2021-01-09-03-58-11.thumb.JPG.62e7f01a5bd4b7de8173dd3d8ac7b0fb.JPG
1656486405_P1170595(004873)2021-01-09-03-58-30.thumb.JPG.d3b828f1b89aec837af4f2763768192d.JPG
1956797946_P1170595(009554)2021-01-09-03-59-33.thumb.JPG.16656161da4b3f005d6fdb403febe974.JPG
841712596_P1170595(010012)2021-01-09-03-59-12.thumb.JPG.a25aaa4304b61c323732ccc3a13428c4.JPG
When test fitting is done, I affixed the seats with scrap aluminum angle bar and screws.
583890659_P1170599(000177)2021-01-09-04-07-34.thumb.JPG.a6a73ce9e5fda5dadb947c57c4b7eb8a.JPG
193316524_P1170599(000402)2021-01-09-04-08-08.thumb.JPG.149d277b0e380fbdb6fca9192e6629ef.JPG
1217981880_P1170601(000059)2021-01-09-04-14-23.thumb.JPG.cf826e90be423880b12c66148af1eb1f.JPG
1350751666_P1170601(001782)2021-01-09-04-15-30.thumb.JPG.ef0be169afc2b84f7b15266f32239210.JPG
1293352191_P1170601(005017)2021-01-09-04-16-20.thumb.JPG.1e16dbcad69dee6b032375483678793c.JPG
Next, I filled it up with foam..
699651690_P1170603(002444)2021-01-09-04-19-27.thumb.JPG.8ade333edc55b8a03fede85d0d7c8a7f.JPG
156723965_P1170603(002654)2021-01-09-04-19-38.thumb.JPG.156ce1e8e2920a44ce04f088aeff1952.JPG
925165875_P1170603(002909)2021-01-09-04-19-46.thumb.JPG.54ff5b8f5e29b8bd933b80b9b93ea185.JPG
1660547105_P1170603(003501)2021-01-09-04-20-01.thumb.JPG.258dd3593e1215a4e627cb1126f7b600.JPG
And the leather seats are done.. 👇
41771114_P1170604(000056)2021-01-09-04-20-14.thumb.JPG.1122bec44e44cca2e45e434c6699bc7d.JPG
844666324_P1170605(000061)2021-01-09-04-20-27.thumb.JPG.2ee8eac913f5e5819fd9dd57be2eb272.JPG
281252005_P1170611(000242)2021-01-09-04-24-58.thumb.JPG.bc2206331c3c6af60522146d719bc3ba.JPG
173497046_P1170611(000284)2021-01-09-04-25-12.thumb.JPG.951a25d6d2ea939e357e6924024e63df.JPG
808716212_P1170611(000599)2021-01-09-04-25-24.thumb.JPG.dd7c3b3c30a269bfe817cdcb70142557.JPG
What else are missing? Steering wheel and auto gauges :)
I made some with the use of acrylic. I copied the Team Group logo on the steering wheel to match the SSD.
1576985065_P1170826(000320)2021-01-09-04-29-44.thumb.JPG.d858856ed41f52cdb5140cfd5e6653bf.JPG
1470726717_P1170828(004699)2021-01-09-04-30-10.thumb.JPG.d04bb074b1873a09e006f744ac530548.JPG
440911015_P1170828(008072)2021-01-09-04-30-34.thumb.JPG.c8de673101eede5b004d8153e9a46e4e.JPG
866875291_P1170829(000612)2021-01-09-04-30-55.thumb.JPG.fc9eeca59644c822b4120711a20aadc6.JPG
211344981_P1170831(002759)2021-01-09-04-31-20.thumb.JPG.61c9e10b74ae37367fc72a4a62eea609.JPG
978584297_P1170832(000139)2021-01-09-04-32-45.thumb.JPG.399a3948afe709b2eb95d3eeb3e6305f.JPG
5878097_P1170833(002284)2021-01-09-04-33-09.thumb.JPG.9add61dc68987823b20a8416bba885ec.JPG
2100105054_P1170834(000942)2021-01-09-04-33-47.thumb.JPG.7ac223b7011271624101454bd5552185.JPG
465183815_P1170835(001140)2021-01-09-04-34-02.thumb.JPG.eac78d9802068377256b55c1be40ffe1.JPG
201564937_P1170835(002487)2021-01-09-04-34-29.thumb.JPG.7050c3977ac4c23b714e7874461c43e3.JPG
1953194083_P1170836(000044)2021-01-09-04-34-39.thumb.JPG.788c3be5eff155499c196a18e4bd6ca4.JPG
Painted them with gloss white..
1265034428_P1180001(000059)2021-01-09-04-54-15.thumb.JPG.06ea31bece46a46b9027bc494967df5c.JPG
For the gauge, I painted the circles purple, then attached some "bling bling" to replicate the dials. :D
540457989_P1180002(000172)2021-01-09-04-57-06.thumb.JPG.af1fa7ec3f2a0aa5638d2e3394a8b00f.JPG
1049280857_P1180030(001424)2021-01-09-04-57-36.thumb.JPG.a6584c229ac802be1a286accba0fc32d.JPG
577247999_P1180030(003299)2021-01-09-04-57-45.thumb.JPG.2f3ff795e859c50315425911fc6490b1.JPG
681063171_P1180031(002610)2021-01-09-04-58-05.thumb.JPG.f0be20d698521beb899f10b800f270ce.JPG
1677193494_P1180032(000209)2021-01-09-05-01-41.thumb.JPG.e3f23df2563c591063a5a8b295d8d0e0.JPG
216340306_P1180033(002953)2021-01-09-05-00-01.thumb.JPG.607ec547a3ae88cabef5cb368266084d.JPG
1826879646_P1180034(000178)2021-01-09-05-14-41.thumb.JPG.b0cd4fb9a24610baa5273fb14f0a009e.JPG
Then for the steering wheel, I attached it to a stainless rod with rubber stopper and screw on the tip which will serve as the stand/mount..
343258118_P1180035(000246)2021-01-09-05-15-54.thumb.JPG.010d7e0c85b3d3a55837d68ff378842b.JPG
1443158570_P1180035(000719)2021-01-09-04-35-44.thumb.JPG.3a8081c0d117fc194249809ffa966fa1.JPG
380841253_P1180035(000944)2021-01-09-05-16-27.thumb.JPG.031bafbceeb4304cbcfa3d10e6c1b7d9.JPG
1539172479_P1180037(002291)2021-01-09-05-19-12.thumb.JPG.7644521ccee9b46170e073d1924bd638.JPG
Lastly, the installation..
1840797940_P1180036(000180)2021-01-09-05-18-22.thumb.JPG.66721d086e47dd94e02254150dfff0bf.JPG
462872715_P1180036(001499)2021-01-09-05-18-37.thumb.JPG.34e12263ab34b9ecb7b84afe9036eedd.JPG
1253851619_P1180037(002780)2021-01-09-05-19-34.thumb.JPG.9a7cac9fe67358afe18bf92fa49fea4b.JPG
569744346_P1180037(004484)2021-01-09-05-19-44.thumb.JPG.f874029c01e45a6748bd1abdb1543529.JPG
95825554_P1180037(007484)2021-01-09-05-20-04.thumb.JPG.4a8feeb9291e5c6457c104c5642ba2a0.JPG
1986889032_P1180042(000108)2021-01-09-04-50-33.thumb.JPG.d93d44907d095f5d7ebdf2ca6efdee9f.JPG
And this ends the part 5 of this work log. See you on our part 6! :)  Mod on!
Link to comment
  • 4 weeks later...
✴️Part 6 - The Body Kit✴️
This is the last stage of our worklog, the making of the body kit of this Low Rider project. For the body kit, I mainly used acrylic instead of sintra board like on the interiors of the build. Why acrylic? simply because it is more rigid than sintra board, it is paintable and can be bent using a heat gun. The bending is important because it will show the shape of the car and emphasize the design. So to begin with, I started on the trunk cover.
I used chloroform to stick the acrylic together, I made a frame to make the trunk cover reinforced because this will serve as the monitor mount.
Sand,prime then top coat... The color that I chose to paint it is a metallic blue violet.
When the paint dried up, I added some decals to camouflage the mounting screws.
Then proceeding to the installation...
Next, the rear fenders.
In order to install these fenders, I made some "sliders", in this manner, I can easily remove the fenders whenever I want to repaint it or if I will change some parts inside the Low Rider.
Next, the doors and the front fenders..
After installing the fenders and the doors, next is the hood.
Now the windshield...
Now we're getting close, time to make the tail lights. I bought some bike reflectors then used a chrome spray paint's cap to make it as the holder of the reflectors, in this way, it will replicate the design of the Low Rider car's tail light. :)
Then the rear bumper. I wrapped it with chrome stickers to make it shine :)
To mount the bumper, I used a car plate number holder.
Next, the Headlights and the grill.. Same as the tail light, the cover I used are bike reflectors then house it on a chrome wrapped grill. then for the grill itself, that's a stainless BBQ grill scrap that I cut out.
Next, the front bumper.
Body kits are set. I added some chrome trims (door guard) under the fenders for added highlights.
Lastly, the decals, emblems and tire painting/lining.
ALRIGHT WE ARE DONE!! it's so fulfilling and satisfying to complete a project.. :) will post outdoor and final shots later on. Thanks for following our project from beginning til' now. :)
be sure to also watch the worklog video linked above for some live modding action time lapse :)
Link to comment
✴️ #CMWS20Finals ✴️
So we've come to the end of our 3-month hard work on this project. It's good the project turned out as planned, and finished just exactly before the deadline :D. Once again, I would like to thank Cooler Master for this opportunity for us to showcase our humble talent all over the world. Also thank you to our sponsors, MSI, Team Group and Cooler Master who supported this build.
Now I proudly and humbly present you, my "LOW RIDER"! :) enjoy and goodluck to all!
Check out the video link above for a live action on how the hydraulics a.k.a actuator gimmick works! :)
Link to comment
  • Create New...
Important Information
