Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) Its a bit nerve wracking making more holes into something I have so much time invested but I figured it would be easier and safer than hand drilling: Luckily no surprises. I did not have any black button head screws so I made some: Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) Next up was a wiring harness and cover that will go next to the pump distro and keep the wiring tidy. First I needed to figure out how big it would be and then I started modeling it in cad: When I had a design that seemed to make sense I cut out a practice version: Then I started milling some more Wenge to make it out of. To start with, I used my bandsaw to resaw a piece of Wenge. This will make the top and bottom of this assembly and the grain should match perfectly: I ran these through the drum sander to get them nice and flat then put the actual dimensions into the cad model: Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 With my stock cut to thickness and the model adjusted I started cutting out the real thing. I used a double flute 1/4 inch bit: From here I started on the cover piece. I used a 2mm Single Flute bit and a 1/4 inch bit for this: I forgot about the pump wire cover so at the last minute I added it into the model and cut it out of the same piece: And both together: To attach the two halves I made threads in the Wenge. I tested this first to make sure the threads would work well: From there, I hand drilled some holes into the acrylic to attach it to the main plate: Lastly I did a V-Carve of the Kanji for Ikigai: Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) A monumental moment came when I could finally glue up the big wood pieces. I started by sanding the insides of the pieces to be glued. I mixed some wood glue and dye together to make a dark glue just in case the joints weren't perfect. I did the same for the PSU caddy: Then it was time to start gluing: Once the glue was dry I sanded the joints smooth Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) With everything sanded I could start the finishing process. I used Danish Oil then a top coat over that with everything being a wipe-on then wipe-off kind of finish. Making progress! Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) My CNC machine made a decent but not perfect finish on the acrylic edges. To clean this up I just used sandpaper. I do not want a polished edge as I like how the polish/satin look together so I'm just aiming to get an even matte surface. I put some sheets of 220, 320, and 600 grit sand paper on my table saw, since it is a flat surface, and went to town. How it started: After 320grit: After 600grit I used a Wenge sanding block for some of the smaller pieces: Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 19, 2021 Author Share Posted January 19, 2021 (edited) I decided to add some black A.C. Ryan mesh on the outside where the Kumiko covers the fans, for the extra contrast. This might hurt performance a little, but it looks slick so its an acceptable trade-off. At first I tried to machine it on my CNC but since it is steel, and a bit wavy at that, it went about as well as I expected. Instead I decided to use some tin snips and this worked great: Once cut to size, I used a template I made for the radiator shroud to mark and drill the holes to allow the bolts to go through: I'll have a photo of this in the case later. Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 20, 2021 Author Share Posted January 20, 2021 (edited) I went back and forth on whether to make a shroud for the radiator and fan setup and decided to do it since it would clean up the inside of the case a bit. I made a model to make sure it would work with the other components. It would be made out of a combination of Wenge and brushed black aluminum from A.C.Ryan. I resawed some Wenge on the bandsaw and ran it through the drum sander to make it smooth: I then cut the pieces to length: For the joinery I wanted something simple but strong so I decided on one big dovetail. I did these the same way I did the ones on the PSU holder. Test fitting: Looking good: One last piece of CNC machine work on this. I needed to route a relief area for fan wires: Dovetails all done and tested with the practice piece: Glueup started after that: While the glue was drying I went to work on the aluminum part of the shroud. This attaches to the radiator itself. Ready to go. This is a 3/16 inch single flute bit: Tested with the Wenge, it is a snug friction fit: Edited January 31, 2021 by Nicholas Falzone 1 Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 21, 2021 Author Share Posted January 21, 2021 (edited) I wanted a bit of Pizazzzz in the center acrylic panel so I decided to route a groove and add an Alphacool LED strip in there. Luckily these are super thin so the groove could be small. I used the router table with a spiral carbide bit: Edited January 31, 2021 by Nicholas Falzone Link to comment Share on other sites More sharing options...
Nicholas Falzone Posted January 21, 2021 Author Share Posted January 21, 2021 Watercooling: I chose 12mm clear PETG for this case, using some bends also. I have not done bending before so this was a new challenge and I have more respect for people who do this often, its not easy. I first laid out all the fittings to see where they'd need to go. And got my tools ready: I used a cheap Barrow tubing cutter and a Primochill tube trimmer to get all the tubes dialed. Luckily I bought lots of extra tubing since there were a few misshaps, especially on the double bend. I got it though and it turned out pretty good. Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
