RenzParas Posted December 13, 2020 Share Posted December 13, 2020 (edited) Hi, I am Renzo Paras (20Yrs Old) of RenzMods from the Philippines this is my First Time to Participate in  Cooler Master World Series. i Join to Gain Experience and Learn more in CaseModding also to See the Work/Art of other participants across the Globe. Edited January 18, 2021 by RenzModz 2 Link to comment Share on other sites More sharing options...
RenzParas Posted December 13, 2020 Author Share Posted December 13, 2020 (edited) Step 1: Making a 3D Design of my CMWS2020 Entry Using Sketchup and Vray for Rendering. My Concept are Combination of CarbonFiber Vinyl , CamoFlauge Vinyl , Mettalic Black , BlackGray Mettalic with a touch of RGB in major Components i named it RGBlack because majority of the color are Black and the lightings will be RGB. i also making Grills made of 6mm Acrylic with a Combination of CarbonFiber Vinyl and Mettalic Black in the Front,Top,Rear Pannel of my Case. for this Project i will be using a CoolerMaster Case Pro 3. the case are old but the Structure of the case are amazing because of its Modular and Unique Design Edited December 13, 2020 by RenzModz Link to comment Share on other sites More sharing options...
RenzParas Posted January 2, 2021 Author Share Posted January 2, 2021 Making a Layout using CorelDraw for LaserCutting the Grills , Grills Mount , MoBo Tray , PSU Shroud , etc  1 Link to comment Share on other sites More sharing options...
RenzParas Posted January 4, 2021 Author Share Posted January 4, 2021 Time For Sanding to Remove UnWanted Lines from Laser Cutting. i manually Sand the 120+ Pcs of Grills this is the most time consuming in my project design Link to comment Share on other sites More sharing options...
RenzParas Posted January 18, 2021 Author Share Posted January 18, 2021 Making Top Pannel Grill also putting CarbonFiber Vinyls to make the Grills Noticeable Coz if i leave it As Black it will look Boring so i made a different style of Grills 1 Link to comment Share on other sites More sharing options...
RenzParas Posted January 20, 2021 Author Share Posted January 20, 2021 Making MotherBoard Tray Mount and Threading For StandOffs Link to comment Share on other sites More sharing options...
RenzParas Posted January 30, 2021 Author Share Posted January 30, 2021 Wraping the MotherBoard tray with a 6D Carbon Fiber Vinyl Link to comment Share on other sites More sharing options...
RenzParas Posted January 30, 2021 Author Share Posted January 30, 2021 Making The PassThrough for watercooling Link to comment Share on other sites More sharing options...
RenzParas Posted January 30, 2021 Author Share Posted January 30, 2021 Sanding before Painting with Mettalic black for chassis and mettalic gray for pannels  Some of photos taken was accidentally deleted Link to comment Share on other sites More sharing options...
RenzParas Posted January 30, 2021 Author Share Posted January 30, 2021 Painting the Fittings with mettalic gray i prefer mettalic gray to match with chrome tubes Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
